iano Posted January 11, 2009 Share Posted January 11, 2009 Hi there.. I'll worry next why the coolant level dropped 2 litres of fluid over the last six months - the immediate concern though has to do with curing a suspected airlock preventing the heating system working. Even though I've topped up the coolant. The 'net throws up solutions involving running the engine until hot with the coolant cap off + turning the heating dial to hot + squeezing the "top" hose repeatedly to shift the airlock But which hose(s) do they mean? The engine coolant circuit hoses get hot but the hoses to the heating valve and beyond into the car remain cold. It's low mileage '96 1.3l model Thanks in advance iano Quote Link to comment Share on other sites More sharing options...
SierraYankee99 Posted January 11, 2009 Share Posted January 11, 2009 I can cure one worry and make the other worse. Sounds to me like you havent got an air lock pal.......now the bad bit.....it sounds like your heater matrix has a small leak in it. Would explain both symptoms. Quote Link to comment Share on other sites More sharing options...
iano Posted January 11, 2009 Author Share Posted January 11, 2009 I can cure one worry and make the other worse. Sounds to me like you havent got an air lock pal.......now the bad bit.....it sounds like your heater matrix has a small leak in it. Would explain both symptoms. If the matrix had a small leak it would indeed explain the drip-drip loss of coolant. What it wouldn't explain is why the heating isn't working after replenishing the coolant. Like I say, I'll worry about the source of the leak after I cure my immediate concern re: chilly driving conditions. :) Quote Link to comment Share on other sites More sharing options...
SierraYankee99 Posted January 11, 2009 Share Posted January 11, 2009 Heater knob link is broken so heaters on cold all the time. Quote Link to comment Share on other sites More sharing options...
iano Posted January 11, 2009 Author Share Posted January 11, 2009 Heater knob link is broken so heaters on cold all the time. Could be it also. But given the serious lack of coolant + the frequent web references to "Rid yourself of airlock associated with low coolant levels, so as to get the heating working again", I'm inclined to plump for an airlock being the best first port of call. Quote Link to comment Share on other sites More sharing options...
stepheno Posted January 13, 2009 Share Posted January 13, 2009 i'd but money on that its the heater control valve, very common fault Quote Link to comment Share on other sites More sharing options...
