Intermittent Starting Problems
5 replies to this topic
#1 nawaz
nawaz
    Newbie
  • New Member
  • Pip
  • 6 posts
  • Ford Model: Focus Climate Zetec
Posted 22 November 2011 - 05:48 PM
Hello everyone,
I am having this problem with a 2007 petrol ford focus zetec which has about 38K on the odometer. I have had it for a year and it has been great so far. But it has started to have this weird intermittent starting problems after some short journeys. When I turn the ignition, the starter motor turns, the engine tries to start but does not start. After 3 or 4 tries out of no where it starts as if nothing has happened.
It only happens when the engine is still warm after a short journey. The garage tried but there are no stored codes. So far I have changed the crankshaft position sensor and the spark plugs. They also tested the battery and it looks fine. There was some rusty residue in two (driver side) spark plug wells indicating that at some point some water had crept in there. I have changed the washer jets to make sure that it doesn't happen again.
Any suggestions where to look to diagnose this problem? Would appreciate any help.
Cheers
Have something to contribute?
#2 btmaldon
btmaldon
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,581 posts
  • Name: Bruce
  • Ford Model: BMW 320i Coupe M Sport, KA Luxury
Posted 22 November 2011 - 07:57 PM
Are you using the throttle to help start the car when it is warm? Ford say you should and included that in the handbook for some of my cars. Im not sure if the instruction is in the latest one though.
#3 Preee
Preee
    Ford Fruitcake
  • 4,342 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3.5 | Fiesta Zetec Mk7
  • Year: 2015
Posted 22 November 2011 - 08:28 PM
Sounds a little like fuel problem , maybe a small air leak and when its switched off and back on its sucking air and then starving it , then a few turns of the engine re-primes it back up to pressure. Can you smell petrol under the bonnet?
Just an Idea.
#4 nawaz
nawaz
    Newbie
  • New Member
  • Pip
  • 6 posts
Posted 22 November 2011 - 10:00 PM
Thanks btmaldon for the suggestion. I usually don't use the throttle to start it. However, when it is refusing to start I use it but it doesn't seem to help.
#5 nawaz
nawaz
    Newbie
  • New Member
  • Pip
  • 6 posts
Posted 22 November 2011 - 10:04 PM
Thanks Preee for the suggestion. I have looked under the hood a few times (even when it is warm) and there is so petrol smell. But I would keep it in mind and check again.
Just an Idea.
#6 dicodread
dicodread
    Member
  • New Member
  • PipPip
  • 20 posts
  • Ford Model: 2006 focus sedan
Posted 25 February 2012 - 10:45 PM
I have the exact same problem. First thing in the morning is always fine but during the day between trips it is like rolling a dice when it comes time to start.
Is there any ideas on what is causing this?
Not what you're looking for?
