dougdevos Posted December 6, 2011 Share Posted December 6, 2011 I've got a 1998 55 diesel van that has an occasional starting problem. Sometimes the key start doesn't operate. I've changed the key switch, changed the starter motor, & wired the starter solenoid on a direct switch. When this switch is operated it turns the starter but the engine doesn't fire. Is there a security device in the ignition cicuit which disables the fuel cutoff solenoid & so stops the engine starting, even when the starter is operated directly? Quote Link to comment Share on other sites More sharing options...
mickmk6 Posted December 13, 2011 Share Posted December 13, 2011 yeh sounds like some thing i had with the key and the coding failing on it eventually got new barrel+key+coded=doorlocks to match for 100 Quote Link to comment Share on other sites More sharing options...
dougdevos Posted December 14, 2011 Author Share Posted December 14, 2011 yeh sounds like some thing i had with the key and the coding failing on it eventually got new barrel+key+coded=doorlocks to match for 100 Thanks ha! guessed it would cost money! Quote Link to comment Share on other sites More sharing options...
