Ford Rear Badge
5 replies to this topic
#1 greggp
greggp
  • Budding Enthusiast
  • 274 posts
  • Ford Model: Focus 2008 1.8 petrol Titanium
Posted 23 December 2011 - 04:41 PM
Just noticed today when closing my boot that behind the badge there is a black rubber seal and it looks like it has come loose as is protruding from around the badge but not equally all the way round. Anyone else had this problem? Too dark now but will have a proper look tomorrow! Not sure if u can remove the badge or not dont really want to have to!
Have something to contribute?
#2 Preee
Preee
    Ford Fruitcake
  • 4,340 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3.5 | Fiesta Zetec Mk7
  • Year: 2015
Posted 23 December 2011 - 06:10 PM
Hi greggp if you take a look at my guide i did for fitting a rear light behind the badge HERE , you will see that there is no rubber seal behind the badge on a mk2.5 the badge is actually stuck to the boot lid handle , so not sure what might be lurking behind yours , but the boot lid section is pretty easy to get off if you want to explore it
#3 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 17,790 posts
  • Name: Clive
  • Year: 2015
Posted 23 December 2011 - 06:28 PM
Whats hanging loose could probably be the sticky pad on the badge peeling.
#4 greggp
greggp
  • 274 posts
Posted 23 December 2011 - 06:39 PM
Thanks preee.
Will take a look tomorrow.
Would u happen to know when the boot panel is removed can you access the number plate lights also? Need to replace one of the housings as i damaged it when changing bulb last week.
Cheers
Gregg.
#5 Preee
Preee
    Ford Fruitcake
  • 4,340 posts
  • Name: Paul
  • Year: 2015
Posted 23 December 2011 - 08:24 PM
Thanks preee.
Cheers
Gregg.
yes you can Greg , the Double sided Sticky that Ford use to hold down the badge is very strong , if its a bit of that sticking out be very carefull trying to remove it as the badge is only about 1mm thick and can easily bend
#6 greggp
greggp
  • 274 posts
Posted 24 December 2011 - 01:25 PM
All done! Nice and simple to remove boot panel and chrome badge strip. Turned out to be a piece of the black seal had come loose behind chrome strip.
Not what you're looking for?
