Start Problem - Engine Malfunction, Immobiliser Active- Help Please.
#1
Posted 02 January 2012 - 06:17 PM
I have a Ford Mondeo Titanium 2.0 litre engine, TDCI, 58 registered. I bought it just 2 months ago from my friend who had it as a company car. I believe it was well maintained with required servicing. But now I encountered a problem. I am rather new to Ford cars, so I would appreciate any your help with the following issue.
I used my car 2 days ago without any problem. But today, I tried to start the car but the dashboard says: Engine malfunction, Immobiliser active. The engine does not want to start.
For couple of weeks I have been getting dashboard messages like: Stop Bulb Fault but all lights were ok. Other message was Low Battery when using a radio even for a short time but I assumed that the battery is OK as the car used to start without any problem.
About a month ago I had to change a fuse for a cigar lighter. Now I checked visually all fuses in engine and under glove compartments but found no blown fuses. I also tried the spare car key to start the engine but without success.
Now I have no idea what could have happened.
I believe I have read all threads regarding immobiliser issues on this forum but still did not find any useful hint for my issue. I would like to avoid going to unknown garage or usually expensive service by a Ford dealer.
I appreciate your help with solving this issue.
Thanks a lot.
#2
Posted 02 January 2012 - 08:41 PM
Hi Everyone
Thanks a lot.
it could be a faulty Ignition ring sensor my mate has a 2010 fiesta and he had it 3 days from the garage brand new and the ignition ring sensor went on him,
he had drove to work no problem then went to drive home again and the car wouldnt star showing the same fault on the dash and the red light flashing like a strobe.
but your symtoms of blowing fuses could be down to a loose earthing point in the cars electric system, if possible try and find a diagram that displays all of the cars earthing points so as you can visualy check, they are usualy in the corners of the front footwells and on the engine block connecting to the chassie, also the main negative connection to the battery itself ensure the ignition is off before doing anything with the battery though mate
#3
Posted 03 January 2012 - 01:00 AM
Hi Lenny
Thanks a lot for your help. I will try check it tomorrow. I searched internet for wiring diagram but so far without success.
Cheers,
Robert
Latest Comments
More
