simon_20 Posted January 17, 2009 Share Posted January 17, 2009 I have a 1.4 zetec focus and was thinking about changeing the engine and putting a 1.6 zetec engine in. Will it be a quiet straight forward swap over or will it require all new gear box and driveing gear as well as ecu units? Quote Link to comment Share on other sites More sharing options...
damocl Posted January 17, 2009 Share Posted January 17, 2009 I have a 1.4 zetec focus and was thinking about changeing the engine and putting a 1.6 zetec engine in. Will it be a quiet straight forward swap over or will it require all new gear box and driveing gear as well as ecu units? unless you can do it yourself.. your better of buying a 1.6 focus and selling the 1.4 Quote Link to comment Share on other sites More sharing options...
simon_20 Posted January 17, 2009 Author Share Posted January 17, 2009 unless you can do it yourself.. your better of buying a 1.6 focus and selling the 1.4 I can do it my self but i am just wondering if it is just a straight swap over? or do i need all new drive gear and gearbox.? Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 17, 2009 Share Posted January 17, 2009 I can do it my self but i am just wondering if it is just a straight swap over? or do i need all new drive gear and gearbox.? you will need the ecu from the 1.6 anyways. possibly the gearbox for the 1.6 as the ratios may be different. Quote Link to comment Share on other sites More sharing options...
simon_20 Posted January 17, 2009 Author Share Posted January 17, 2009 you will need the ecu from the 1.6 anyways. possibly the gearbox for the 1.6 as the ratios may be different. So its queit a big job then ? Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 17, 2009 Share Posted January 17, 2009 So its queit a big job then ? if you are comfortable with fitting it yourself then go for it. having to source all the different parts wouldnt put me off. While the new engine is out you would probably be better to fit a new clutch and timing belt kit aswell. Quote Link to comment Share on other sites More sharing options...
simon_20 Posted January 17, 2009 Author Share Posted January 17, 2009 so if it is going to be hard to change engines over is there any advice and tips to tune up my engine as it is really sluggish as the cars body is far to big for a 1.4 engine think ford should of started building the focus's wih 1.6 engines. Als it is not easy for me to just swap cars and buy a bigger liter car. Quote Link to comment Share on other sites More sharing options...
simon_20 Posted January 17, 2009 Author Share Posted January 17, 2009 Yeah i would be happy to do it but wat i dont want to happen is that i take out old engine then cant put other engine in due to needing loads of parts. Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 17, 2009 Share Posted January 17, 2009 so if it is going to be hard to change engines over is there any advice and tips to tune up my engine as it is really sluggish as the cars body is far to big for a 1.4 engine think ford should of started building the focus's wih 1.6 engines. Als it is not easy for me to just swap cars and buy a bigger liter car. theres not alot of tuning that can be done to such a small engine to be honest, nothing that will give you a huge difference anyway. Have you had a look at prices for the 1.6 engine with gearbox? If you have the space and tools it should be a good weekend job with help from a good mate. I think to convert the engine you will need the gearbox, ecu, engine mounts and possibly driveshaft and also all the other bits like the alternator and such. you will probably need to change the downpipe to the exhaust too. If the money to do it isnt a major issue then I would go for it by all means. Quote Link to comment Share on other sites More sharing options...
simon_20 Posted January 17, 2009 Author Share Posted January 17, 2009 Ok i will have a lil shop on eBay and see whats avaliable thanks for your advice. Got alot of thinking and callculations to do. Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 17, 2009 Share Posted January 17, 2009 Ok i will have a lil shop on ebay and see whats avaliable thanks for your advice. Got alot of thinking and callculations to do. getting your hands on a donor car would be the best thing but that might be too pricey, whats your budget? with a donor car you would have absolutely everything you need from ecu to driveshafts. would be especially good if you have never done anything like this before. Quote Link to comment Share on other sites More sharing options...
