john5 Posted January 15, 2012 Share Posted January 15, 2012 Hi When I unlock the doors, if I don't put the key in the ignition and close the door, after a little while it locks itself. Very good idea if I had forgotten to lock it when parked, but a nightmare if I left the key on the seat or somwhere, as I have no spare key. I wondered if it's possible to program it to stop this happening. cheers John. Quote Link to comment Share on other sites More sharing options...
Preee Posted January 15, 2012 Share Posted January 15, 2012 it's usually the other way around , if you unlock the door via remote or key , only if you don't open the door should it re-lock . If you open the door then it should not auto lock. The system will not or should not auto lock when you get out and walk away from the car Quote Link to comment Share on other sites More sharing options...
artscot79 Posted January 15, 2012 Share Posted January 15, 2012 confirmed if you unlock the doors with remote and dont open them excluding the bonnet and boot then the doors will relock but if you open a door then close it again the car should not relock itself Quote Link to comment Share on other sites More sharing options...
john5 Posted January 16, 2012 Author Share Posted January 16, 2012 Hi Thank you both for your replies you were both right. I had it looked at and it was caused by a connection, no problems now. cheers John. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted January 16, 2012 Share Posted January 16, 2012 a nice easy fix then mate Quote Link to comment Share on other sites More sharing options...
