soulman123 Posted January 15, 2012 Share Posted January 15, 2012 I have finally located a strange churp best discribed as a chidrens toy with low battery. Basically when I turn the headlight on the drivers side makes a lot of chirping/whurring noises. I was changing a blown bulb and when I tested it I heard the noise as I was standing there with the bonnet up. After the lights are turned on if sometimes makes the noise for a few seconds then stops, but if you move the headlight adjuster dial next to the headlight switch the noise kicks off which I guess means the gizmo that moves the light is faulty or soemthing ? Is this common or a known fault ? Does this mean I need a new headlight or is the offending part replaceable ? Although when I turn the lights on no idea why the motor/adjuster would activate as I have no touched the adjustment dial, odd. I did have a look at the aim compared to the passenger light, the drivers light beam is a smidge lower, although not very accurate and I guess it will all need aligning after the fault is fixed. Any help/info much appreciated ... fingers crossed for a cheap fix Quote Link to comment Share on other sites More sharing options...
dezwez Posted January 15, 2012 Share Posted January 15, 2012 I have finally located a strange churp best discribed as a chidrens toy with low battery. Basically when I turn the headlight on the drivers side makes a lot of chirping/whurring noises. I was changing a blown bulb and when I tested it I heard the noise as I was standing there with the bonnet up. After the lights are turned on if sometimes makes the noise for a few seconds then stops, but if you move the headlight adjuster dial next to the headlight switch the noise kicks off which I guess means the gizmo that moves the light is faulty or soemthing ? Is this common or a known fault ? Does this mean I need a new headlight or is the offending part replaceable ? Although when I turn the lights on no idea why the motor/adjuster would activate as I have no touched the adjustment dial, odd. I did have a look at the aim compared to the passenger light, the drivers light beam is a smidge lower, although not very accurate and I guess it will all need aligning after the fault is fixed. Any help/info much appreciated ... fingers crossed for a cheap fix theres a little motor in the headlight it sounds like it come out of it fiting if you take out the light unit you will see where it go,s Quote Link to comment Share on other sites More sharing options...
soulman123 Posted January 15, 2012 Author Share Posted January 15, 2012 theres a little motor in the headlight it sounds like it come out of it fiting if you take out the light unit you will see where it go,s Thanks for the reply :) I see will I be able to see and adjust this motor ifI just remove the plastic back or does the whole headlight have to come off to get at it ? Thanks Quote Link to comment Share on other sites More sharing options...
