Non-Running 2010 Ford Focus
25 replies to this topic
#1 zu11y
zu11y
    Newbie
  • New Member
  • Pip
  • 9 posts
  • Name: zulfiqar
  • Ford Model: Focus
Posted 17 January 2012 - 08:19 PM
hii all, i have a ford focus 1.6 tdci mk2 on a 2010 plate, the car had a under dash fire and previous owner changed the wiring loom, ecu, key and ignition barrel
the issue is ... the immobilizer light is flashing when ignition is on, car is not communicating with diagnostic scanners. the car does not turn over at all, and displays the following on the lcd display
'Transmission Failure' ( the car is manual)
we've checked all fuses, relays and wiring plugs with no issues to report..
just wondering if anyone on here can help me solve the problem...
thanks in advanced
Have something to contribute?
#2 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,958 posts
  • Name: James
  • Year: 2007
Posted 18 January 2012 - 06:29 AM
so, 2010 car, and it had a fire under the dash, but only the one wiring loom was replaced?
Sounds to me like there is more wire damage within, or possibly component damage to the rear of the dash sending a few duff signals...
How did the fire occur? whilst the car was moving? whilst asleep? I would be concerned that if the car was in use at the time, that a power surge / excessive heat melted the wires causing the fire, but that damage most likely would have spread to the likes of the fuseboard / other relays causing untold damage...
#3 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,077 posts
  • Name: Clive
  • Year: 2015
Posted 18 January 2012 - 06:50 AM
Methinks it is knacked.
It is dead, bereft of life, it rests in peace, It is an ex car.
Sorry, another long busy night shift. <_<
Totally agree, someone did a shoddy repair job on the wires.
Probably got melted insulation and carboned earth points all over the place.
I'd also reckon that the ECU is buggered too.
#4 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,958 posts
  • Name: James
  • Year: 2007
Posted 18 January 2012 - 02:05 PM
Would suprprise me at all...! zu11y - how much did you pay out for the car? cant you take it back?
#5 zu11y
zu11y
    Newbie
  • New Member
  • Pip
  • 9 posts
  • Name: zulfiqar
  • Ford Model: Focus
Posted 18 January 2012 - 04:10 PM
im nt quite sure how the fire started however everything under the dash has been replaced, ecu and all the start gear was replaced, everything else seems to be working, i.e. headunit , lights, heaters ive checked the fuse box, everything electrical and all seems fine
#6 alkyz89
alkyz89
  • Budding Enthusiast
  • 375 posts
  • Name: Aaron
  • Ford Model: focus zetec S
Posted 18 January 2012 - 05:44 PM
sorry i cant really offer any advice, but surely if it is 2010 plate it would still be under warrenty? can you not just take it in to ford??
Or is the service history not complete?
#7 Preee
Preee
    Ford Fruitcake
  • 4,365 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3.5 | Fiesta Zetec Mk7
  • Year: 2015
Posted 18 January 2012 - 06:20 PM
There must be more to it than just the ECU , there are other parts i'm sure that all need to sync With the ECU before it will start ,has it been into Ford For the ECU to be set to the Car
#8 zu11y
zu11y
    Newbie
  • New Member
  • Pip
  • 9 posts
  • Name: zulfiqar
  • Ford Model: Focus
Posted 18 January 2012 - 08:46 PM
hi really appreciate the advice but i think the issue needs some clarification.
after the fire the car has had the following items from a donor vehicle
ecu
transponder
key
ignition set up
fuse box
wiring loom
and the clocks
everything else on the car works fine, all the lights inside and out, central locking, windows, radio etc all work
so i am pretty lost as to why the car still refuses to start, its as if the immobilizer is switched on and not turning off
#9 Preee
Preee
    Ford Fruitcake
  • 4,365 posts
  • Name: Paul
  • Year: 2015
Posted 18 January 2012 - 08:50 PM
Do you know if the car was exact same model? , I'm still sure its not as easy as just a straight swap of parts.
Also the Immob would need to be set to the key wouldn't it ?
just posing a few questions that might trigger an idea
#10 zu11y
zu11y
    Newbie
  • New Member
  • Pip
  • 9 posts
  • Name: zulfiqar
  • Ford Model: Focus
Posted 18 January 2012 - 09:03 PM
yes the parts were taken from the same model focus, as far as i am aware the key doesn't need programming as the ecu, immobilizer, clocks, transponder, ignition barrel all came from the running donor car
#11 alkyz89
alkyz89
  • 375 posts
  • Name: Aaron
Posted 18 January 2012 - 09:57 PM
surely if you disconnect the ecu system, when re-installing would you not need to program it all in again evan if your putting back in the same car?? sort of like a computer, are you sure its not been restored to factory settings so to speak??
it might just be a case of popping into ford and getting them to programe it???
again just an idea
#12 Stoney871
Stoney871
  • Super Mod
  • 18,077 posts
  • Name: Clive
  • Year: 2015
Posted 18 January 2012 - 10:04 PM
I'd reckon the ECU and PATS2 units need recoding.
Are the keys the originals or from the donor car?
Sounds like the immobiliser
Isn't recognising the transponder chip in the key.
#13 zu11y
zu11y
    Newbie
  • New Member
  • Pip
  • 9 posts
  • Name: zulfiqar
  • Ford Model: Focus
Posted 18 January 2012 - 10:53 PM
the key is from the donor as well mate
#14 zu11y
zu11y
    Newbie
  • New Member
  • Pip
  • 9 posts
  • Name: zulfiqar
  • Ford Model: Focus
Posted 18 January 2012 - 10:57 PM
any chance you could give me the location of the PATS2
#15 Stoney871
Stoney871
  • Super Mod
  • 18,077 posts
  • Name: Clive
  • Year: 2015
Posted 18 January 2012 - 11:21 PM
The PATS2 receiver is a ring around the ignition barrel. As to the immobiliser unit I'm not totally sure.
Someone here will know for sure.
Not what you're looking for?
