Been For A Diagnostics Test Today
12 replies to this topic
#1 1djspikey
1djspikey
  • New Member
  • 60 posts
  • Name: johnathan
  • Ford Model: ford mondeo estate ghia 2.0 tdci
  • Year: 2002
Posted 20 January 2012 - 08:57 PM
Hi all :)
been for a Diagnostics test on my 2002 mondeo estate ghia 2.0 tdci euro 3 that goes into limp mode and glow plug flashing heres the codes ive been given :(
U1900 CAN Communication Bus Fault
P0100 Mass or Volume Air Flow Circuit Malfunction
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P1665 Injection pump control module communications
P1664 pump control module malfunction
P1211 Injector Control Pressure Sensor Above / Below Desired engine running
P0251 Injection Pump Fuel Metering Control A Malfunction
i also had a vacuume pressure test on the EGR and was working well plus i did clean it all out a few weeks back so this problem was wiped off the list
the turbo is vacuume actuator as been tested and is running fine and turbo is not that old by the looks of it pretty clean B)
as anyone got any ideas and thoughts ?? :unsure:
regards spike ;)
Have something to contribute?
#2 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,577 posts
  • Name: Clive
  • Year: 2015
Posted 20 January 2012 - 09:17 PM
You might find all those faults are caused by one sensor or connection playing up.
I'm wondering if a CANBUS error is the root?
I'm sure someone will be able to shed light on this.
#3 TDCiST
TDCiST
    No Smoke No Poke... Unless you have a DPF!
  • 1,682 posts
  • Name: Dave
Posted 20 January 2012 - 09:34 PM
oooh CANBUS fault! not seen that before...
Thats a lot of faults, surely if there is a CANBUS fault, it cant report other errors?? I'm confused!?!?
#4 1djspikey
1djspikey
  • New Member
  • 60 posts
  • Name: johnathan
  • Year: 2002
Posted 20 January 2012 - 09:50 PM
the car runs sweet till you need to boot the turbo in 3rd and 4th gear heres the print out
oh for got to mention ive put half a tank of diesel in and forte advanced formula diesel treatment in tank as made response better but still goes limp
#5 TDCiST
TDCiST
  • 1,682 posts
  • Name: Dave
Posted 20 January 2012 - 09:53 PM
2002 diesel isnt it??
It could be that its not CANBUS compliant... My 2004 focus wasnt, would only do OBDII or whatever the other protocol was
#6 1djspikey
1djspikey
  • New Member
  • 60 posts
  • Name: johnathan
  • Year: 2002
Posted 20 January 2012 - 10:05 PM
yeah it`s 2002 euro 3 got all the vacuume valves on and egr right handside at the back
#7 stef123
stef123
  • Management
  • 5,866 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 20 January 2012 - 11:54 PM
Can you get those codes cleared and see what reappears?
#8 1djspikey
1djspikey
  • New Member
  • 60 posts
  • Name: johnathan
  • Year: 2002
Posted 21 January 2012 - 10:52 AM
Hi steff
The codes was reset 2weeks ago so these are resent codes over the past 2weeks if you know what i mean
spike
#9 1djspikey
1djspikey
  • New Member
  • 60 posts
  • Name: johnathan
  • Year: 2002
Posted 21 January 2012 - 01:34 PM
can you just replace FORD MONDEO MK3 TDCi FUEL METERING VALVE SENSOR
plus fuel pump tempeture sensor or do you have to recode them also can you just replace the top rail sensor or is the a recode :huh:
spike
#10 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,559 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 21 January 2012 - 04:46 PM
diesels did not become eobd untill 2004 so unless they have the correct reader it could throw up all sort of codes hence the canbus error.
#11 gmac187
gmac187
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Ford Model: Mondeo 2.0 TDCi Ghia
Posted 15 August 2012 - 07:15 PM
Hey guys... Got a P2263 turbo/charger boost system performance fault.
Flashing glow plug but no ECU light
It's a 53 2.0 TDCi Ghia.. In limp mode at moment... Had egr off and cleaned. Been reading lots about this just wondered if anyone has had that same code before? If so, what is the best course of action? Thank you ...
#12 stef123
stef123
  • Management
  • 5,866 posts
  • Name: Stefan
  • Year: 2006
Posted 15 August 2012 - 07:38 PM
have you checked the hoses for splits?
#13 piper
piper
    Member
  • New Member
  • PipPip
  • 28 posts
  • Ford Model: mondeo estate 2ltr TDCI
Posted 15 August 2012 - 09:50 PM
Going for a diagnostic test tomorrow with pretty much the same problem , glow plug light comes on when i put my foot down (hard) and then the car goes into limp mode.
It will re-set it self when i turn the engine off.
It will be interest to see what come up, not much i hope.
Not what you're looking for?
