Cant Open Bonnet.help!!!
7 replies to this topic
#1 markyd
markyd
    Member
  • Budding Enthusiast
  • PipPip
  • 15 posts
  • Name: mark
  • Ford Model: FOCUS
  • Year: 2006
Posted 22 January 2012 - 03:29 PM
ive got the so 'common' problem with my focus. bonnet lock seems to be damaged.
i have removed the grill and have tried all sorts to try and get the bonnet open. where are the 2 x 10mm which i need to remove to get the bonnet open???
ive tried to 'click the white cyclinder back in but no joy.as you can see the outer part of the cylinder has broken off in me doing this.
thanks
Have something to contribute?
#2 STEADS
STEADS
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,108 posts
  • Name: NEIL
  • Ford Model: FOCUS 1.8 TDCI TITANIUM AND 2.0 TDCI
  • Year: 2009
Posted 22 January 2012 - 03:48 PM
Hi what year is your focus if its about 2005 all you have to do is remove the lower panel from under the bumper reach up and remove the black gromet from the front of the latch to expose a white ring get a long bladed screw driver and through the grill pref dead centre above the badge place the blade on the white ring (might be easy to see with the aid of a torch) and give it a firm push this should put it back worked for me you don,t have to remove the six plastic rivets from the plastic panel as in earlier posts or pull the grill forward and remove key lock. takes literally 10 mins
hope this helps steads
#3 markyd
markyd
    Member
  • PipPip
  • 15 posts
  • Name: mark
  • Ford Model: FOCUS
  • Year: 2006
Posted 22 January 2012 - 03:52 PM
cheers ive tried pushing the white plastic ring in but it doesnt seem to 'click' back in.....nothing seems to happen..ive given it a firm bash with a screwdriver but not working.
#4 STEADS
STEADS
  • PipPipPipPipPip
  • 1,108 posts
  • Name: NEIL
  • Year: 2009
Posted 22 January 2012 - 04:00 PM
hi sorry to quick off the mark didnt read post properly or look at photo the 2 10 millys appear to be above the latch in your
photo just had a quick look at mine and there are 2 10 millys inside the under the bonnet as well so i cant see how removing the 2 outer ones would really help can not try putting the key in the barrel and with some help as someone turns the key you try to push the white barrel into position .
#5 STEADS
STEADS
  • PipPipPipPipPip
  • 1,108 posts
  • Name: NEIL
  • Year: 2009
Posted 22 January 2012 - 04:04 PM
photo just undo them and it detaches the catch from the bonnet.
steads
#6 markyd
markyd
    Member
  • PipPip
  • 15 posts
  • Name: mark
  • Ford Model: FOCUS
  • Year: 2006
Posted 22 January 2012 - 04:05 PM
yeah i put the key and and it just makes a grinding noise like its going to bit then doesnt.anyway to remove the lock? i have a brand new assembly kit to go on,,,
#7 alz
alz
    Serial Poster
  • 459 posts
  • Name: Alan
  • Ford Model: Ford Focus LX 1.8 TDCI
  • Year: 2005
Posted 22 January 2012 - 08:54 PM
Hi There are two clips on the link rod, press them both and it should pull out, then you can open the bonnet latch..
#8 markyd
markyd
    Member
  • PipPip
  • 15 posts
  • Name: mark
  • Ford Model: FOCUS
  • Year: 2006
Posted 23 January 2012 - 01:47 PM
many thanks.all sorted now.
Not what you're looking for?
