Abs Light On
17 replies to this topic
#16 blueovalcraig
blueovalcraig
    Member
  • New Member
  • PipPip
  • 23 posts
  • Ford Model: 2009 Ford Focus Zetec S 1.8 TDCi
Posted 26 February 2012 - 09:03 PM
I had same problem with mine and put the diagnostic computer on, no signal from N/S/R sensor. swapped N/S/R with O/S/R and still had no signal from N/S/R. After a bit of investigation, I noticed one of the wires on the loom between N/S/R sensor and chassis had a slightly swollen bit on it. I peeled the outer cover off the wire and found the wire was corroded. Connected both ends with a crimped terminal, problem solved.
How did you get on with yours?
Have something to contribute?
#17 MARLEY
MARLEY
  • New Member
  • 75 posts
  • Name: PAUL
  • Ford Model: MK2 FOCUS 2.0 TDCI GHIA
  • Year: 2007
Posted 26 February 2012 - 10:17 PM
to be honest i have got no further with the problem, really i need to get on ramp or have it plugged in to find fault,
Regards
Paul
#18 MARLEY
MARLEY
  • New Member
  • 75 posts
  • Name: PAUL
  • Year: 2007
Posted 01 March 2012 - 09:53 PM
Breaking News
Just had my car plugged in and the rear nearside wire to the sensor is corroded about 2 or 3 inch down the line, repaired and working, GOOD RESULT. Happy Days :D :D :D
Regards
Paul
Not what you're looking for?
