Carl0s Posted October 22, 2013 Share Posted October 22, 2013 got the elm-config, but now when i try to read the PCM i get error: http://imageshack.us/f/13/p4xl.jpg/ Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 22, 2013 Share Posted October 22, 2013 any success Carlos? you switched it on yet? Quote Link to comment Share on other sites More sharing options...
Carl0s Posted October 22, 2013 Share Posted October 22, 2013 any success Carlos? you switched it on yet? Nope, got stuck whit that error code when trying to read the PCM... So far i think its becose im using bluetooth ELM and it cant work waster the 9600kbs (acording to the speed test) and the pcm reading requires 115000. Now im figuring if i could hookup a better USB-Serial converter to the serial lines of the BT chip :D But sofar ive been able to get only some scrable trough Quote Link to comment Share on other sites More sharing options...
Carl0s Posted October 22, 2013 Share Posted October 22, 2013 Yeap, i think its becose the bluetooth elm adapter can't work fast enough for the PCM... Searching for USB-lead and if im lucky, il get one in my hands by the weekend. Meanwhile, i did "Cruise control buttons Mark 2" whit tactile switches. Mark 1 were basic red pushbuttons on connection box just for testing. Also, found out that the resistance needs to be accurate! 300ohm is not "standard" resistor, so had to take 310ohm instead. Did the GEM button test, and noticed that it did not work... So did it whit 120 and 180omh resistors. Now all i need to figure out is how i get them to fit inside the radio remote neatly, whitout ripping out the remote electronics. There is some spare room, but i think i might need to make some extra :/ Quote Link to comment Share on other sites More sharing options...
adder360 Posted October 22, 2013 Share Posted October 22, 2013 I am getting the same issues as carl0s. also getting this when trying to read on the pcm page 2. im using a wired elm connector I've got 2 and tried both and get the error message both. on the speed test they both show are able to connect at 500000. is any one able to shed any light on this. mine is a 1.6 tdci I read on other pages that this was not supported in previous version of elmconfig. thanks Quote Link to comment Share on other sites More sharing options...
Carl0s Posted October 23, 2013 Share Posted October 23, 2013 I am getting the same issues as carl0s. also getting this elm.PNG when trying to read on the pcm page 2. im using a wired elm connector I've got 2 and tried both and get the error message both. on the speed test they both show are able to connect at 500000. is any one able to shed any light on this. mine is a 1.6 tdci I read on other pages that this was not supported in previous version of elmconfig. thanks 1.6 TDCi here also. I wonder if it has something to do whit that, what does the "info" show you on the PCM module (version, fw etc) Quote Link to comment Share on other sites More sharing options...
Carl0s Posted October 23, 2013 Share Posted October 23, 2013 !Removed! it, bought IDS... I report back in 3-5 business days when i get my hands on the package :) Quote Link to comment Share on other sites More sharing options...
Richiemac Posted October 23, 2013 Share Posted October 23, 2013 Where did you buy......what seller ? I have found the supplier of the best VCM's.....these use the same board types as the original. Beware of the FLY type units.......they are rubbish and are only good for clearing DTC's...........can also corrupt modules ! Quote Link to comment Share on other sites More sharing options...
Carl0s Posted October 23, 2013 Share Posted October 23, 2013 Where did you buy......what seller ? I have found the supplier of the best VCM's.....these use the same board types as the original. Beware of the FLY type units.......they are rubbish and are only good for clearing DTC's...........can also corrupt modules ! http://www.cardiag.co.uk/vcm-metal-box-ids-v80-jlr-v131-new-vcm-release-1382.html Any experiences ? Quote Link to comment Share on other sites More sharing options...
Richiemac Posted October 23, 2013 Share Posted October 23, 2013 Ask them to send you pictures of the 2 boards inside........ Its the only way to identify the good from the bad. Quote Link to comment Share on other sites More sharing options...
Carl0s Posted October 23, 2013 Share Posted October 23, 2013 Actualy, i started second guessing since in there first one had no mention about PCM programming. Send email to the vendor if it would be possible to switch the unit to http://www.cardiag.co.uk/ford-vcm-ii-diagnostic-tool.html Quote Link to comment Share on other sites More sharing options...
Carl0s Posted October 23, 2013 Share Posted October 23, 2013 Ask them to send you pictures of the 2 boards inside........ Its the only way to identify the good from the bad. Based on quick google pic search: http://i00.i.aliimg.com/img/pb/351/979/671/671979351_215.jpg Quote Link to comment Share on other sites More sharing options...
Richiemac Posted October 24, 2013 Share Posted October 24, 2013 Have a look here and compare...... http://mhhauto.com/Thread-China-VCM-s-guide Quote Link to comment Share on other sites More sharing options...
Carl0s Posted October 24, 2013 Share Posted October 24, 2013 Have a look here and compare...... http://mhhauto.com/Thread-China-VCM-s-guide Good thing i changed the product... Acording to the mhhauto: "Not suitable for module programming (can corrupt/lock PCM,TCM)" :D The new one atleast says on the function list: * Programming & Installation of new ECUs (PCM, ABS, Instrument Cluster, Air Bag, Fuel Pumps, etc.) * Set, Adjust or Remove Speed Governors So i think it should do the trick... :) Quote Link to comment Share on other sites More sharing options...
Richiemac Posted October 24, 2013 Share Posted October 24, 2013 Been there with the sh**ty FLY VCM's, they can do serious damage to modules.....only good for clearing DTC's. Its still a lottery what you'll get really, but the one i got from ADK is spot on so far. Good luck. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 24, 2013 Share Posted October 24, 2013 do you have a link to your trusted purchase Richard? Quote Link to comment Share on other sites More sharing options...
Richiemac Posted October 24, 2013 Share Posted October 24, 2013 http://www.adkautoscan.com/ Make it clear what you want....no rubbish and preferably get pictures of the PCB's sent to clarify. Never any guarantee with China sellers....... Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 24, 2013 Share Posted October 24, 2013 they have everything from a $20 cable to an $800 kit. I guess you would have gone for the mid range area? Quote Link to comment Share on other sites More sharing options...
Richiemac Posted October 24, 2013 Share Posted October 24, 2013 This one. http://www.adkautodiagnostic.com/top-quality-ford-ids-vcm-version-a-freeship-ford-vcm-ids-scanner-customer-review-289.html?zenid=abd936443a58a44d134e088647635ea6 It's also important to install the software to a clean partition on your hard drive. Nothing else on the drive, just the operating system and the IDS software. I only use Ford software, i didn't install JLR as i don't use it. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 24, 2013 Share Posted October 24, 2013 I wish I had that much burning a hole in my pocket! lol I think I would be happy to pay a nominal amount and rent someones rather than buy it all myself! Quote Link to comment Share on other sites More sharing options...
adder360 Posted October 24, 2013 Share Posted October 24, 2013 just got my cruise control activated after over 6 months of trying with elm config. were it says pcm type I selected the 1.6 tdci option from the list, hadn't done this before and it gave me an error did it not and it read no problem. finally got it sorted after wasting 40 quid at a ford dealer for them to plug it in buying 2 elm readers both modded and working at 500,000 if any one would be looking to buy one send me a message. Quote Link to comment Share on other sites More sharing options...
simmaren_1 Posted October 25, 2013 Share Posted October 25, 2013 I saw the new write to PCM option in the configuration page of PCM and hoped that it would "fix" my CC flag. But when hitting write all looked good until the very end when it said, "there is an empty block... -> must to a firmware write..." Back to square one again :( So near but so far from a working CC :( Quote Link to comment Share on other sites More sharing options...
Carl0s Posted November 6, 2013 Share Posted November 6, 2013 edit: Yeah, so i got my IDS VCM today, and when i go to "Toolbox", "Module Programming" it throws me error: "Selection not available"... ?! What should i do? Quote Link to comment Share on other sites More sharing options...
Richiemac Posted November 6, 2013 Share Posted November 6, 2013 What version you running? Needs patching to enable programming. Quote Link to comment Share on other sites More sharing options...
Carl0s Posted November 6, 2013 Share Posted November 6, 2013 What version you running? Needs patching to enable programming. 84 there was ome patch on the DVD's that came whit it :/ Quote Link to comment Share on other sites More sharing options...
