Guide Fitting Cruise Control Focus Mk2 & Mk2.5 And Ford C-Max
Thats the wrong connector. Try the one in the passenger footwell lol
  • Replies 902
  • Views 524.1k
  • Dan, I'm 95% sure that you're dealing with a faulty adapter. I've been there myself, thought I had a great adapter, until I learned the opposite. I had the same kind of unpredictable behaviour and al
  • The borrowed adapter has resulted in success and Eve is now equipped with Cruise Control. Thanks to everyone who has previously contributed to this epic thread - this forum is awesome! Time to give C
  • FatLadZ & int0x13, as Igor said, those buttons are designed for the 4 spoke steering wheel. They could be fitted to a 3 spoke wheel, but I'm on the same side with Igor about this, in my opinion it
:huh: :D
was that a homer "doh" moment i detected there?? lol
:iim: . Now that I found it , I am most :( ... no wires in pin 10/18.
should be a brown and white wire. you may have missed it...there are two blue connectors on the fusebox...Well mine did anyways lol
Its the one where you pull the fuse box down and as you look at it top left.
I can remember seeing somewhere that a ford tech has never seen a car without them
John H,
I think this is the one right ? This time I hope I am wrong.
Btw, the brown and white wires, are they just the ones that directly run into the plug behind the steeering wheel ? If yes, I am wondering running the 2 cables separately would work.
However, I noted that there is the 2 switches on the brake pedal.
Since my car is an Auto Transmission (Powershift), I didn't check for the clutch switch.
looks as though you have a few wires missing there. Yeah thats the switches - you wont have clutch one if its an auto.
Check under the steering wheel on the connector there...Is there a brown and white wire?
Just to keep everyone informed. I now have cruise control in my focus :D i spent £10 on the componants for the buttons
Programming software for PCM with ELM327. http://ffclub.ru/topic/302511/go_post/14136868/ 4ffb266a7e2a.jpg
ELMCOMFING 0.2.8b PCM work but only petrol
I used IDS to activate and recalibrate the modules for cruise. Im willing to do this for anyone in tyne and wear and durham area
Has anyone got this working on an ST yet?
  • 3 weeks later...
Hi, Using EML config 0.2.7b to configure the PCM for Cruise Control is it the box 'Integrated Speed Control' which has to be ticked?
Finally got out and checked my wiring, I think the wiring is there, but if anyone can clarify...
Wires going to the steering wheel column, I believe all the wires are here:
yep they there, look at both solid brown and solid white wire.
now just get your head under near the pedals and check for two switches on brake and one on clutch
Yeah already checked the pedals and they are definately there :D getting really excited now!!!
Well just to let yous all know ive managed to get this activated on a 2010 1.6 focus. Turns out, according to the sneaky russians ;) ford decided to lock the software down to stop this but using older versions of the software sorts it out. So i downloaded a 2011 version and viola he now has cruise in his car
Would it work on an ST?
Can it only be activated by a main dealer?
In all honesty mate i couldnt tell you. Best bet is to check all wires above and if so should be able to activate it.
As for dealers, give em a ring and ask i know the ones up here will tell you to do one lol but if you dont ask you dont get lol
I'll check the wires in the morning. Wish my car had cruise control.
Does it have to be the 2011 software? That could be a problem. Wish I was closer to you.
Yeah it just has to be the earlier version to bypass the locks but after you can recalibrate to a new version ;)
Check wires and let us know if not sure get as many pics as you can and upload
Mine doesn't have the wires :( Any chance just pulling the 2 wires straight from the steering to the plug will work ?
You would need to check the fuse box to see if it has the connections available. Then you will need to get brake and clutch switches. Followed by wiring for all three - steering wheel, both switches.
Would be possible i bet but alot of work
Excellent news John! sneaky Ford but you managed to hack it ;)
