Guide Fitting Cruise Control Focus Mk2 & Mk2.5 And Ford C-Max
533 replies to this topic
#451 clubber
clubber
  • Budding Enthusiast
  • 109 posts
  • Ford Model: ST3
Posted 15 November 2013 - 08:01 AM
Ford buttons or self made? I noticed that the GEM beebs on the rear window heater trick, even if the buttons were set up all wrong.
Ford buttons mate, I have a 4 spoke steering wheel.
Have something to contribute?
#452 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,264 posts
  • Name: James
  • Year: 2007
Posted 03 December 2013 - 12:26 PM
How important is it for these resistors to be the right value?
I bought a pack of resistors of all the varying amounts, and most of them are all less than the value specified. Most come in 5 - 17 ohms less than they are packaged as?
120 = 115
180 = 177
300 = 295
510 = 495
1000 = 983
Should I be getting in touch with the seller, and should these numbers be a minimum, or is it a ballpark game?
#453 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,264 posts
  • Name: James
  • Year: 2007
Posted 04 December 2013 - 02:32 PM
Having a rather blonde moment...
Attached is how I think it should work. Given that I have the microswitches with 4 legs (1 pair the switch closes, 1 pair remains closed permenantly).
So the plan is this, the top of the boxes in my diagram are the perma closed, so after I press the button, the current will then run through all of these circuits, and will output the resistance of all of these resistors to the car.
So at any point, the ECU should always receive a resistance of 1210 ohms. I then turn cruise off and the ECU receives no resistance, and switches it off, but as soon as I release the button it then gets all 1210 Ohms back again.
So can someone just clarify for me that this is correct? The switch bridges going down, and remains perma closed going across? I am confident that this is right, but something just doesnt feel right lol
#454 Focus66
Focus66
    Member
  • PipPip
  • 23 posts
  • Name: Ian
  • Ford Model: Focus
  • Year: 2006
Posted 10 December 2013 - 10:41 AM
Be very quick, an absolute bargain.......
http://www.ebay.co.u...=item3a8889fccf
#455 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,264 posts
  • Name: James
  • Year: 2007
Posted 10 December 2013 - 01:02 PM
Bargain and a half!
Out of curiosity, would anyone who has succsesfully activated cruise control with their modified OBDII adapter, be willing to lend it to me? It appears mine cannot talk at 500000 so I cannot get onto the PCM and do the download.
#456 simmaren_1
simmaren_1
    Newbie
  • Pip
  • 7 posts
  • Name: Fredrik
  • Ford Model: Focus
  • Year: 2006
Posted 17 December 2013 - 08:27 AM
Hello,
When I finaly got the right elm327 (elm327 dongle #3...) with 500k speed, I saved the VID & firmware, loaded it back and activaded the CC-option (in PCM).
When I then tried to write it back to the PCM it said that my PCM is not supported!
I have the ECU-131 and PCM 5M51AG.
Does someone know why only the "5M51JD / JE" are supported by the ELMConfig?
What is the difference between JD/JE and my AG?
Will the xxxAG be supported in the future or am I just in bad luck regarding the activation of the CC?
Can I download another calibration file to my PCM?
I do not want to give up :(
/Fredrik
Focus 1.8 FlexiFuel 2006
My cruise control is now working!
Thanks to ELMconfig and the Quizzer functionality I managed to activate the cc. It was scary when you read that the PCM is beeing erased...
My tool is a modified china version with the FTDI... All of the warning messages about doing it on your own risk was flashing for my eyes...
It worked so I am glad :)
Thank you ELMconfig!!!
Cheers
Fredrik
#457 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,264 posts
  • Name: James
  • Year: 2007
Posted 17 December 2013 - 08:46 PM
no matter which PCM I use, none are supported :( This is under all of the PCM types as well, so its the same error on the others :(
I have connected the switches temporarily and tried it and unfortunately no cruise :( seems that I wont be able to do this with Elm Config perhaps.
I basically ticked the box and tried to write, and that was the result, I hope its just a user error! :P any thoughts?
#458 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,264 posts
  • Name: James
  • Year: 2007
Posted 20 December 2013 - 10:08 PM
Does anyone have any reason to believe that the mondeo cruise buttons would use different resistances?
#459 giwrgos_ath
giwrgos_ath
  • 152 posts
  • Name: George
  • Ford Model: Focus MK2.5
Posted 21 December 2013 - 12:45 PM
Guys, today i had the time to work on this mod. After ensuring that i have all the required switches and cables, in installed the wheel and it seemed fine.
I activated the CC using ELMconfig on two places of the config without any issues, and went for a ride, but for some reason the CC didn't come on.
Also, i noticed that the one-click closing of all windows is no longer working. The opening is fine.
Any ideas what that might be?
#460 Tezza
Tezza
  • 158 posts
  • Name: Terry
  • Ford Model: Focus ST3
  • Year: 2009
Posted 21 December 2013 - 04:08 PM
Try this
Step 1:
Press the power window control switch close button until the door window is fully closed and hold the button in the close position for a further second.
Step 2:
Release the power window control switch close button and press again two or three more times, for one second each time.
Step 3:
Press the power window control switch open button until the door window is fully open.
Step 4:
Briefly press the power window control switch close button to the second detent and release the button.
If the door window does not close automatically, repeat the complete procedure.
Repeat the door window motor initialization for each door window motor.
#461 giwrgos_ath
giwrgos_ath
  • 152 posts
  • Name: George
Posted 21 December 2013 - 05:33 PM
Thanks Terry, that solved my problem! Any idea why it happened in the first place? was it because i removed the battery?
The CC is still not working however... Any suggestions on that? I doubt it can be a faulty wheel...
#462 jarp
jarp
  • 63 posts
  • Name: Jari
  • Ford Model: Focus
  • Year: 2005
Posted 21 December 2013 - 07:03 PM
CC usually needs to be enabled from three places - that and how to do it is what we have been discussing for last 20 pages. From what modules did you enable CC?
#463 giwrgos_ath
giwrgos_ath
  • 152 posts
  • Name: George
Posted 21 December 2013 - 11:04 PM
Jari, i used ELM-FF2 and activated on IPC and BCM. I couldn't find the third option. Is this the PCM that you are talking about?
#464 jarp
jarp
  • 63 posts
  • Name: Jari
  • Ford Model: Focus
  • Year: 2005
Posted 22 December 2013 - 09:38 AM
Yes, PCM is the problem child as you cannot activate CC that easily from it. If you are lucky enough your PCM may already have CC ativated, but apparently not as it's not working. You need to enable CC from PCM... Please see last 10 pages about it.
And you can verify that your steering wheel and buttons works by using test mode:
- While holding rear window heater button down, turn ignition on
- Keep pushing heater button until you hear beeb -> test mode is on
When in test mode, all input buttons from steering wheel etc. should induce audible beeb and flash indicators should flash also. So you can test that GEM will recognize all your buttons.
#465 giwrgos_ath
giwrgos_ath
  • 152 posts
  • Name: George
Posted 22 December 2013 - 10:01 AM
Jari,
Thanks for your answer. I've done the test and the buttons work fine.
I followed this topic in the past, but for some reason, i thought that my problem was not related to the ones discussed earlier, since i had the wired version of the cable. I will have to revisit all the posts and come back with more questions (if any)
Update: I was using ELMConfig v0.1.0.2 without any luck, but updating to v0.2.11b seem to have solved my issues. I read the VID-block (took 9 mins) and wrote it back (around 3 mins) to fix the 'block in use' error and then updated the configuration. Tested and it works!
I was scared at one point because the laptop battery died, but fortunately that didn't brick my car and i was able to restart the process.
Not what you're looking for?
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
