Guide Fitting Cruise Control Focus Mk2 & Mk2.5 And Ford C-Max
606 replies to this topic
#601 dyy
dyy
    Newbie
  • Budding Enthusiast
  • Pip
  • 2 posts
  • Name: Adam
  • Ford Model: Focus
  • Year: 2007
Posted 29 April 2015 - 11:29 AM
Activating CC in PCM order:
1. Reading firmware (to the file on your laptop)
2. Loading that firmware (from that file you've just created)
3. Checking appropriate option in PCM
4. Writing the firmware
Have something to contribute?
#602 igorsinkovec
igorsinkovec
    Member
  • PipPip
  • 19 posts
  • Name: Igor
  • Ford Model: Focus MkII Estate 2.0 TDCi 136
  • Year: 2006
Posted 29 April 2015 - 04:10 PM
Thanks Igor, I'll check the ohm values using a multimeter. I have the Focus schematics file. I find it hard to believe that my PCM or its firmware doesn't support CC. Btw, the firmware inside my PCM is the newest version available for that type, dated late 2008. Cheers
Still, it could be 1.6 TDCi cars were never available with Cruise control. Can anyone confirm this?
#603 Milosh
Milosh
    Member
  • PipPip
  • 21 posts
  • Name: Milos
  • Ford Model: Focus
  • Year: 2007
Posted 29 April 2015 - 06:22 PM
Are you saying that these exact steps are necessary in order to activate Cruise Control in PCM?
Simple "tick the checkbox and write to PCM" isn't enough?
Igor, I doubt that, but I will try to get some information from people who own this engine.
I have checked the resistance and everything is correct, except that the SET+ and SET- buttons are wired (or placed) the wrong way around, but I don't mind that. The ON, OFF and RESUME buttons have correct resistance values, which should turn CC on and off...
#604 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 17,088 posts
  • Name: Clive
  • Year: 2015
Posted 29 April 2015 - 06:25 PM
I believe that the cc requires specific resistance parameters to function properly so having set+ & set- swapped may cause problems.
#605 igorsinkovec
igorsinkovec
    Member
  • PipPip
  • 19 posts
  • Name: Igor
  • Year: 2006
Posted 29 April 2015 - 06:44 PM
I agree. The only way to absolutely eliminate the radio stalk as the possible cause is to make sure it's wired properly. Do you have any spare resistors lying around to make a temporary buttons assembly and test with that?
The procedure that @dyy outlined is what we all have done. The fact that you skipped a few steps is also a possible cause for your problem in my opinion, even if all logic defies it. I too ignored that before and I was probably wrong to. There could be something important that happens in the PCM during that procedure, for example it could force the PCM to accept a changed config whereas otherwise the PCM could ignore it. There is still a lot we don't know.
#606 Milosh
Milosh
    Member
  • PipPip
  • 21 posts
  • Name: Milos
  • Ford Model: Focus
  • Year: 2007
Posted 29 April 2015 - 07:30 PM
I totally agree about that last sentence of yours. I think that those two buttons being swapped can't make a difference, since the GEM does certain steps when it detects certain resistance values, and it certainly does get correct input values when ON, OFF and RESUME buttons are pressed, but it still does nothing.
If this is what all of you have done then I will try it tomorrow as well and we'll see. Thanks everyone for your help so far!
#607 dyy
dyy
    Newbie
  • Pip
  • 2 posts
  • Name: Adam
  • Ford Model: Focus
  • Year: 2007
Posted 30 April 2015 - 10:12 AM
Yes. It's not enough to just tick the option and write
Not what you're looking for?
