Darren Cook Posted January 26, 2012 Share Posted January 26, 2012 Hey, noticed whilst repairing a leak in the boot that someone's messed with the loom extended wires and one is lose with seemingly no place to connect.. its a orange and green wire. any ideas? Pictures below.... Click for bigger image Quote Link to comment Share on other sites More sharing options...
Darren Cook Posted January 26, 2012 Author Share Posted January 26, 2012 Searched around and this might be yellow/green and be rear fog light?... any input on if im right. my multimeter doesn't fit into this connector to test for +12v on fogs on. Quote Link to comment Share on other sites More sharing options...
Preee Posted January 26, 2012 Share Posted January 26, 2012 I think the only way to check for sure is to cut into it and test the voltage , being in the boot it may also have been a power feed if some one had used a sub in there Quote Link to comment Share on other sites More sharing options...
Darren Cook Posted January 26, 2012 Author Share Posted January 26, 2012 I think the only way to check for sure is to cut into it and test the voltage , being in the boot it may also have been a power feed if some one had used a sub in there Only thing sub wise it could be is a signal line (ignition on/off) as its far too thin for power. (would be 10 gauge (400watt) or thicker) I will just cut the connector off. doesn't connect to anything that i can see anyway.. cheers. Quote Link to comment Share on other sites More sharing options...
dezwez Posted January 26, 2012 Share Posted January 26, 2012 has it had a tow bar taken off Quote Link to comment Share on other sites More sharing options...
