Problems with heated front windscreen
#1
Posted 20 January 2009 - 06:26 PM
When I switch it on to clear the screen before I drive I hear a knocking noise coming from the drivers side of the engine compartment. This does not seem to happen when the engine is warmer however I don't often have the need to use it then!
Does anyone know how I can fix this as it is particulary irritating.
Thanks in advance
#2
Posted 20 January 2009 - 11:27 PM
#3
Posted 21 January 2009 - 08:07 PM
Thanks for this.The only difference that the heated screen will make is the huge draw of power when its switched on. Cant really account for the knocking, could be alternator. You dont have the blowers on full demist too do you??? If you do that will be using the air conditioning too, could be air conditioning pump if you do.
I bang the whole lot on when i get in, didn't know that i wasn't supposed to!
I will try it without the blowers and see if it still happens.
I don't fancy getting a new alternator/air con pump though, i was hoping that it would be an easy, cheap and well known fix.
#4
Posted 23 January 2009 - 01:57 PM
You can do whatever you want to its your car lol. I'm just giving you possibilities for the cause of the noise you get.
#5
Posted 24 January 2009 - 09:51 AM
