What is it?
6 replies to this topic
#1 Luke123
Luke123
    Newbie
  • Pip
  • 3 posts
  • Ford Model: mk3
Posted 20 January 2009 - 07:29 PM
Hi
Ive just registered so.... :huh:
I own a mk4 fiesta, its on an S plate, 1300 engine. I think its the zetec S enigine, Sounds like a sewing machine tbh lol
I was driving home and the car seamt a bit stiff and didnt seem to be as poweerful as normal so i checked the oil levels and topped up. :unsure:
I was then sat on my drive with the car ticking over and the car seamt to get quiter as tho it was dying and then stutttered a few times. :unsure:
I turned the car off and the back on about 4 or 5 times and the same kept happening!
As i walked off a noticed water on the floor behind the exhaust!
Could it be the head gasket or a valve problem??
Can anyone tell me what they may think the cause of the problem may be please.
#2 Pimp My Ride
Pimp My Ride
  • 37 posts
  • Ford Model: Mk3 Fiesta
Posted 20 January 2009 - 08:31 PM
To see if its the head gasket what u need to do is take the cover off that is over where to add oil, Its connected on my mk3 to the air filter, anyway when removed inside there should be like a foam or that sitting around the top, thats one way to see if the head gasket is leaking water.
#3 Luke123
Luke123
    Newbie
  • Pip
  • 3 posts
  • Ford Model: mk3
Posted 20 January 2009 - 10:05 PM
Hi
Ive had the bonnet up while the engines running and theres no steam or anything and theres no water around the top of the head where it would be if the seal was bust. the engine sounds normal aswell, no loud noise different to normal etc
The water from the exhaust has bits of black in it, almost like soot.
~Thanks
#4 vamp2k05
vamp2k05
  • 61 posts
  • Ford Model: fiesta mrk 3 lx saphire
Posted 20 January 2009 - 10:09 PM
check the connection between centre and downpipe see if its come loose or if its blowing
#5 Rookwise
Rookwise
    Member
  • PipPip
  • 19 posts
  • Ford Model: 2001 Fiesta Freestyle in Moondust Silver
Posted 20 January 2009 - 11:48 PM
The 'water' might be unburnt petrol. It possibly could be running too rich.Have the car checked out with some diognostic equipment to see if the engine is running/set up properly.If you have a local mobile engine tuner in your area.Give them a ring and see how much it will be for them to plug into your car.I know of one in my area (my dad, family business) that charges £45 an hour to check the car over and set it up properly so expect to pay near that.
#6 Luke123
Luke123
    Newbie
  • Pip
  • 3 posts
  • Ford Model: mk3
Posted 21 January 2009 - 09:43 AM
Thanks alot guys, ill check all this.
I think it needs a good service tbh
Can i still drive around, short distances?
#7 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 21 January 2009 - 03:48 PM
a bit of water from the exhaust is normal thats why exhausts rust from the inside out
