Simo Soop Posted January 30, 2012 Share Posted January 30, 2012 HI! I want my cars doors locking automaticly, when i start driving. What i must do? BR, Anti Hijack Feature 1. Turn on ignition until the dash lights come on but don't start engine! 2. Lock the door using the lever on the door handle and then unlock 3 Times 3. Turn off ignition 4. Repeat 2 but with ignition OFF 5. Turn on ignition - should hear a beep 6. Lock door again as in 2 BUT ONLY ONCE - final beep should be heard 7. Done! Doors should now lock at around 5mph. including reverse!!! Trying - not working!!! Quote Link to comment Share on other sites More sharing options...
focus11 Posted January 30, 2012 Share Posted January 30, 2012 Hi, I also tried this on my 2011 MK3 Focus, but again it didnt work, and I tried it numerous times but eventually gave up! Any ideas as I would ideally like this feature. Regards Quote Link to comment Share on other sites More sharing options...
Simo Soop Posted January 30, 2012 Author Share Posted January 30, 2012 Hi, I also tried this on my 2011 MK3 Focus, but again it didnt work, and I tried it numerous times but eventually gave up! Any ideas as I would ideally like this feature. Regards I wrote the question to my dealer, waiting a reply Quote Link to comment Share on other sites More sharing options...
btmaldon Posted January 30, 2012 Share Posted January 30, 2012 On the older Fords, you had to do the whole proceedure within 30 seconds. I will try it on mine tonight as I used to have this on my Mondeo, and quite liked it. Quote Link to comment Share on other sites More sharing options...
Simo Soop Posted January 30, 2012 Author Share Posted January 30, 2012 On the older Fords, you had to do the whole proceedure within 30 seconds. I will try it on mine tonight as I used to have this on my Mondeo, and quite liked it. Yes, but 2012 focus had only one button,( 2. Lock the door using the lever on the door handle and then unlock 3 Times) - when i want door locks then i must push the button? If you understand me? Quote Link to comment Share on other sites More sharing options...
Preee Posted January 30, 2012 Share Posted January 30, 2012 On the older Fords, you had to do the whole proceedure within 30 seconds. I will try it on mine tonight as I used to have this on my Mondeo, and quite liked it. If you manage it , let me know i would like that feature , i will also try it myself see if it works on a 2010 Focus Titanium Quote Link to comment Share on other sites More sharing options...
jimrex Posted January 31, 2012 Share Posted January 31, 2012 I tried it on my Mk3 and it didn't do anything. Would like to know if it's possible too as hitting the lock button has become a habit when I set off now! Quote Link to comment Share on other sites More sharing options...
tomo2001 Posted January 31, 2012 Share Posted January 31, 2012 I tried it on my Mk3 and it didn't do anything. Would like to know if it's possible too as hitting the lock button has become a habit when I set off now! How did you try this on the Mk3 as it doesn't have a lock button on the door handle ?? Quote Link to comment Share on other sites More sharing options...
NorthSussex Posted January 31, 2012 Share Posted January 31, 2012 Do you live in such a dangerous area to need this level of security? Or is there some other reason you want to keep all the car doors locked when you are driving? Having all the doors locked if or when you have an accident is not a good idea! Maybe we just live a sheltered life in the country. Quote Link to comment Share on other sites More sharing options...
Preee Posted January 31, 2012 Share Posted January 31, 2012 Tried this on my Mk2.5 , 5 times and it does not work. found another post saying that it should be done Ign On Lock/unlock 3 times Ign Off lock/unlock 3 times Ign On ----- Beep should be heard Lock/unlock once ---- beep should be heard ! Neither of them work for me. If it did work it's not really an anti jack feature , because if your stopped at lights etc the doors would open and only locked after 5mph Quote Link to comment Share on other sites More sharing options...
jimrex Posted January 31, 2012 Share Posted January 31, 2012 How did you try this on the Mk3 as it doesn't have a lock button on the door handle ?? I used the lock button under the stereo controls - I figured it was worth a try (but deep down I knew it was unlikely to work!!) Quote Link to comment Share on other sites More sharing options...
btmaldon Posted January 31, 2012 Share Posted January 31, 2012 Nope. Cant get it to work on mine either. Quote Link to comment Share on other sites More sharing options...
Simo Soop Posted January 31, 2012 Author Share Posted January 31, 2012 Tried this on my Mk2.5 , 5 times and it does not work. found another post saying that it should be done Ign On Lock/unlock 3 times Ign Off lock/unlock 3 times Ign On ----- Beep should be heard Lock/unlock once ---- beep should be heard ! Neither of them work for me. If it did work it's not really an anti jack feature , because if your stopped at lights etc the doors would open and only locked after 5mph I must press 3 times the button (lock-unlock-lock) ing on then press 3 times (unlock-lock-unlock) ign off and then ign on - and then i must hear a beep? when i want to door locked then i must press the button. 2012 focus dont have door handle locking, only the button. Is that right? Quote Link to comment Share on other sites More sharing options...
TDCiST Posted January 31, 2012 Share Posted January 31, 2012 Having all the doors locked if or when you have an accident is not a good idea! The anti hijack system is linked into the Airbag system... so in a serious accident the doors will unlock... Plus if your in a really serious accident, the fire brigade wont hesitate to use their big air powered "Jaws of Life" to get you out.... Quote Link to comment Share on other sites More sharing options...
Wickwick10_1 Posted January 31, 2012 Share Posted January 31, 2012 Do you live in such a dangerous area to need this level of security? Or is there some other reason you want to keep all the car doors locked when you are driving? Having all the doors locked if or when you have an accident is not a good idea! Maybe we just live a sheltered life in the country. I think it's a great feature ! During a bad accident put the window through and open door ....... Simples Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 1, 2012 Share Posted February 1, 2012 Very true comments above, I would also suggest that maybe this feature is one that has to be activated by the dealer. I had it on my Cee'd and got it activated, plug into the ecu, press a button - Done! some things just cant always be done. For Example, It could be that the method above *should* work, in that, if its set on the ECU to listen then it should work, but what if the ECU isnt listening? I would write to Ford, maybe you found a bug with their ECU software... Quote Link to comment Share on other sites More sharing options...
focus11 Posted February 9, 2012 Share Posted February 9, 2012 I wrote the question to my dealer, waiting a reply Hi, any update on whether you got a reply? Quote Link to comment Share on other sites More sharing options...
Simo Soop Posted February 13, 2012 Author Share Posted February 13, 2012 Hi, any update on whether you got a reply? Yes, They said it is not practicable. If i want to doors lockd then press the button every time. i think it is possible, but i dont now how. Any ideas? Quote Link to comment Share on other sites More sharing options...
