Cutting Out At 3800 Revs
6 replies to this topic
#1 pat2l
pat2l
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: mondeo 2.0 tdci
Posted 04 February 2012 - 12:05 PM
hiya all hope someone can help, just had dmf and clutch done (£550) car starts and runs ok but if i take it up to just under 4000 revs the engine dies,starts up again ok and runs ok but the problem remains, no codes showing mechanic also scratching hiis head, hope someone can help.
Thanks in advance
Have something to contribute?
#2 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,543 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 04 February 2012 - 07:03 PM
first thing to check is that non of the rubber pipes have been trapped when the work was done and reassembled restricting air flow.
#3 pat2l
pat2l
    Newbie
  • New Member
  • Pip
  • 2 posts
Posted 05 February 2012 - 10:29 AM
hi mintalkin checked around but cant see any trapped,poked around on the forum and it seems it could also be a sensor on the blink more money i suppose,still tryin to solve it though thanks alot.
#4 Podzak
Podzak
  • Budding Enthusiast
  • 100 posts
  • Name: Peter
  • Ford Model: Mondeo 2.2 Diesel Estate Ghia
  • Year: 2006
Posted 13 February 2012 - 06:13 PM
4000rpm?
Which drag racing track do you use? :)
#5 Z3 MON
Z3 MON
  • New Member
  • 328 posts
  • Name: David
  • Ford Model: Ford Mondeo 2.0 TDCI 115 Mistral 2004
  • Year: 2004
Posted 15 February 2012 - 01:11 PM
4000 rpm is a bit high for a diesel mondeo, why are you reving it so much?
#6 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,543 posts
  • Name: mintalkin
  • Year: 2006
Posted 15 February 2012 - 03:30 PM
was this fault there before the work was done?
#7 clueless chancer
clueless chancer
    Member
  • New Member
  • PipPip
  • 23 posts
  • Name: chris
  • Year: 2005
Posted 19 February 2012 - 07:17 PM
I recently had my dual mass flywheel, clutch and starter motor replaced. As soon as I drove out of the garage the engine management light came on. Went back to garage, he plugged it in, fault code was fuel ail pressure low, and he said injector 3 needed replacing. I took it home, turned out a hose from the EGR valve had been torn in half. Replaced it for 70 pence, light went out.
Well worth having a close look under bonnet after having work done, you never know.
Not what you're looking for?
