St On Top Gear
slappyhaze
 Share
Did anyone else see this at the start of the latest Top Gear (montage in first episode of the new series showing whats coming up)?
Focus or Fiesta?
Have they announced an ST in the new shape Focus?
Link to comment
According to ford Ecat the focus in the images above is actually the reg of a Mk3 Ford Focus 1.6 Eco Boost model?
Primary Features
Build Date: 04.07.2011
Vehicle Line: Focus 2011-
Body Style: 5 Door Saloon
Version: Series 40
Engine: 1.6L EcoBoost SCTi (150PS) - Sigma
Transmission:6 Speed Manual Trans - B6
Drive: RHD FWD
Axle Ratio: 3.82
Emission:Stage V Emissions
Air Conditioning: Dual Zone Auto Temp Control
Territory: (+)"GB"
Paint: Panther Black (Metallic)
Interior Fabric: Pur/Torino / Charcoal Black
Minor Features
Less Roof Reinforcement
Less Roof Line Conversion
Less Rear Mudflaps
Front Door Scuff Plates - Ford Oval
Accessory Media Hub 1XUSB
Less Interior Pack
Less Front Mudflaps
With Hill Launch Assist
Rear Passenger Door
With Manual Liftgate
Saarlouis Plant Built
Less Security Lock Group
Less Special Equipment Package
Ford Corporate badge
Less Marketing Flex Prep Pack
Less Sales badge
Less Special Order Paint
Less SVO Application/Label
Less Dress Up RSO
Less SIP
Exterior Paint - Solid
For Normal Temperature Zones
Less VP Application Label
Less Mass Customization Package
Less Fire Extinguisher Fixings
Less Tyre Repair service Kit
With Auto Closing Windows
Power Front Windows One Touch Up/Do
Power Rear Window One Shot Up/Down
With Tinted Glass All Round
Grille - Upper Blk Msh/Chrome Surnd
Less Windshield Heat Shielding
With Heated Windscreen
Less Console Ashtray
Less Temp Controlled Glove Box
With Padded Dash
Mini Overhead Cnsl W/Sunglass Bin
Console - With Closed Bin
Less Rear Floor Console
Int Environment Clr-Charcoal Black
Int Feat Colour - Charcoal Black
Front Floor Carpet mats
Rear Floor Carpet mats
With General Stowage Box
Less Sun Blinds
Deluxe Headliner
With Illuminated Sunvisor - Drivers
With Illuminated Sunvisor-Passenger
With Aluminum Interior Door Handles
With LH Front Door Armrest
With RH Front Door Armrest
Less Stowage Bins
Rear Coat Hook
Less Luggage Compartment Net Kit
With Load Area Cover
Less Load Compartment Loops
Less Load Retention Net
Less Decklid Liner
With Load Floor Carpet
Less First Aid Retain Straps
Less W.Triangle Retaining Straps
Less Driver Roof Storage
Less Front Grille
Grille-Lower Surround Hgh Gls Chrm
Less roof rack
Less Exterior Body Mouldings
Rocker Panel Moulding -Cladding C/K
With Bright Door Frame Moulding
Less Door Edge Guards
Less Auxiliary roof rack Crossbars
With Rear Spoiler
With Electrochromic R/View Mirror
Dual Pwr/Heat/Fold/Pud Lamp/Signal
With Body Coloured Exterior Mirror
With Driver Seat Back Map Pocket
Passenger Seat Back Map Pocket
With Front 2 Way Headrest
With Electric Driver Seat Recliner
With Passenger Seat Recliner-Rotary
Less Special Seat Covers
Less Special Front Seat Covers
Less Special Rear Seat Covers
With Two Piece Rear Seat Cushion
With 60:40 Split - Folding Rr Seat
With Integrated Rear Headrest
Rear Centre Armrest With Stowage
With Rear Center Head Restraint
With Drivers Manual Lumbar Support
With Passengers Man Lumbar Support
With Drivers Heated Seat
With Heated Passenger Seat
With Drvr/Passngr Seat Belt Minder
With Driver 4 Way Pwr.Seat Adjuster
With Pass 4 Way Manual Seat Adjust
Less Trailer Coupling
With Front Towing Hook
With Rear Towing Hooks
Less Trailer Sway Control (TSC)
Engine Cover - Under Hood
Body Coloured Exterior Door Handle
Body Coloured Tailgate Handle
Ignition Key Combination Pack 1
With Leather Gear Shift Knob
Steel Sec Door Lock Shield
With Child Proof Safety Lock
With Remote Controlled Tailgate Release
Less Second Remote Ignition Key
Less Door Auto Relocking
With Door Dead Locks
Less Door Unlock System
With Door Entry Remote Control Unit
With Keyless Start
Capless Fuel Filler Without Lock
With Int. Rear Window Wiper/Washer
With Automatic Windscreen wiper
With Heated Washer Jet
With Headlamp Washer
Less Sun Roof
Less Tonneau Cover
Front Bumper - Painted Body Colour
Less Front Bumper Extension
Rear Bumper Body Coloured Plastic
Less Rear Bumper Skirt
Less Thermoplastic Kneebolster Sys
Air Crtn Rstrnt LH
Less Rear Side Air Bag Restraint
3 Part Seat Belt- European Regultn
With 2 Static Rear Seat Belts
With Driver Air Bag
With Passenger Air Bag
With Side Air Bag - Drivers Side
With Side Air Bag - Passenger Side
Less Passenger Air Bag Deactivation
With Isofix Hard Point Attachment
With Manual Adjust Frt.S.Belt Mount
Style 1 Tether Anchorage Restraint
With Mini Steel Spare Wheel
Tyre Pressure Moniter Sys-DDS
With Standard Rear Shock Absorbers
7J X 17" Style 5 Alloy Wheel
215/50 17" W Rated BSW Tyre
Limited service Mini Spare Tyre
With Standard Tyre Tread - Front
With Standard Tyre Tread - Rear
Less Wheel Covers
Locking Wheel Nuts
With Kysor Radiator Shutter
Less Engine Block Heater
Less Frame Mounted Fuel Filter
Cold Start -15 Deg C
Less Immersion Heater
Starter - Stop/Start System
With Standard Suspension
Front Spring Load Class-K
Rear Spring Load Class-Q
Strt Sngl Vsbl Pipe One Sd Sngl Muf
Less Exhaust Pipe Extension
Less Handbrake Grip
Mechanical Hand Operated Park Brake
Standard Duty Fr/Rr Calp And Pads
With Rear Disc Brakes
Less Low Speed Safety System
Brakes-HLA/ESP/TC/ABS
Less Rear Bumper Protector
With High Back Front Seats
Less Rear Comp Duct
Less Air Purifier Sensor
With Recirculating Heater
Non Locking Capless Fuel Fill
With Lead/Unleaded Fuel
With Fixed Foot Pedals
Standard Foot Pedal Pad Design
With Electric Power Steering
With Manual Tilt/Slide Stg Column
4 Spoke Leather Steering Wheel
Speed Control And ASLD
Less Auxiliary Heater
Less Park Heating
Conventional Instruments - Level 3With Instrument Cluster - Rheostat
With MPH/KMH Speedomeer
With Trip Compute
Less Instruent Gauges
Dua Note Electric Horn
Less Tyre Inflation Monitor
Less Compass Display
MFD High TFT Screen
Less Navigation System
With Message Centre
Less Navigation Disk
Less Navigation Data
Less Emergency Call Button
Less Blind Spot Information System
Less Lane Keeping Aid
Thatcham Catergory 1 Alarm System
With Safeguard Anti-Theft Sys(Pats)
With Rear Parking Aid
With Front Parking Aid
Less Side Parking Aid
With Automated Parking System
Standard Duty battery
Less A/V Jack
BT/VC Phone Interface + USB Connect
ICE-Mid Audio Branded + DAB
Ice Feature Pack 8
Branded ICP
Less Upgraded Sound System
With 9 Radio Speakers
Less Radio Subwoofer
Less Telephone Preparation Pack
Less Mobile Office Pack
Less Family Entertainment System
Less Sync
Voice Activated Module - British
With Steering Wheel Radio Controls
Less Column Stalk Radio Controls
Less Electrical Outlet
Less Smokers Package
Less Power Point Plug
With Power Point Plug - Rear
Less Camera
Less Cool Box
Less Style Pack
Less Comfort Pack
With Auto Headlamps
With Chrome Fog Lamp Bezel
High Intensity Discharge Headlamp
DTRL Lamp Lit In Pos 0 And Pos
With Front Fog Lamps
With Aluminium Headlamp Bezels
Multi Colour Ambient LED Lighting
With Footwell Lights
Fr Individual and Rr Map Lights
Front And Rear Lamp LED
Less Rear Overhead Reading Lamps
With Glove Box Illumination
With Load Compartment Lamp
Less Aux Interior Lights
Tail lamps - LED Rear
With High Mounted Stop Lamp
With Single Rear Fog Lamp
With Automatic Headlamp Levelling
With Automatic Headlamp Control
Less Accessory - Packages
Outside Air Temperature Present
Link to comment
Yeah I noticed the focus in their vid too.
I was waiting throughout the last season for them to review it. Glad they're finally featuring it.
Maybe its a zetec s and the owner has put an ST badge on? lol though surely the car experts would have noticed that
Link to comment
anyone cared to think they may have just any plates on them? doubt ford would have sent out a 'fake' st to the biggest car show in the world
Edit: an un-released car wouldn't be registered anyway would it
Link to comment
I did think that but then thought surely we would have seen something online about it, even if just spy shots etc.
Link to comment
Yeah, def ST, due out later this year in 5 door and estate versions (No 3dr!!!), some shots of the estate can be seen http://www.ford.co.uk/Cars/FutureVehicles/focus-st-wagon was also on the autoexpress website http://www.autoexpress.co.uk/motorshows/paris-motor-show/256987/ford_focus_st_official_pictures.html
Link to comment
Its from the film The Sweeney which is in post-production - Ford have supplied the cars and the one in the picture is the new FOCUS ST (although that particular car may not be as they wont want to wreck an ST). Here is a couple of links :)
http://www.imdb.com/title/tt0857190/
The film on IMDB
http://www.autoexpress.co.uk/news/autoexpressnews/275554/focus_st_set_for_the_sweeney.html
The article in Auto Express
Hope that helps guys :)
Link to comment
Yeah, most probably they got Ford to mock up the standard Focus as a ST for filming as they would most likely go through a few in getting the action right and using a real ST would cost a lot more.
Still, seeing that makes you want to sob.
Nice to see they have Ben Drew in the film, he was good in Harry Brown and love Plan B.
Link to comment
It certainly looks like an ST but as others have mentioned probably a mock up as the clip shows crashing (I cringed when I saw it) Hopefully they'll be reviewing the actual ST too, it's about the right time to, by next series it would have already been released, we know Top Gear like their hot hatches, and this ones got a fair amount of hype, so I'll be looking forward to the upcoming episodes!
Link to comment
do you think they are worried about writing off a st when they wrote off a jag xf if you read the top gear mag they said they had a budget off 3.5 million for the chase sequence
Link to comment
Capital letters, commas, full stops, correct spelling..
Why write off an actual ST, when you can write off something worth less that looks the same? It could be a similar situation with the XF - it might look like a top of the range model but actually could be a tarted up bottom of the range car.
Link to comment
Even so, always seems such a waste when they go and write off a perfectly good new car. Like the little red thing they had a while back (what was it again?) which they drove upside down through a sewer (even though it was fake), destroyed, then jumped it into the sea. As amusing as some of these things are to watch I hate seeing it!
Link to comment
It's quite possible that the ST is actually worth a lot more than the standard car will be - I doubt that it's in the standard state that it left the factory in.
Look at Casino Royale - the DBS didn't have enough grunt or the right sound for what they wanted, so one of the cars was stripped out and fitted with an even bigger lump and ridiculous exhausts. Then of course the one in the crash was a mere Shell. This scene is probably no different - they will have had several cars, some with roll cages - hell sometimes they even use LHD cars but leave the RHD interior in, that way they can have their star at the wheel but someone else controlling the car.
At the end of the day - it looks like an ST, the important thing is that we will be seeing this car in the UK before long.
And akaray - while I'm with you on the need for correct punctuation etc - we don't make an issue of it here, it tends to drive some people off.
Link to comment
Renault Twingo with Ross Kemp in the boot. :)
Link to comment
That's the one.
A lot of cars Top Gear use are demo models from the manufacturers and have been thrashed by every journo in the country.
Remember when they played football with aygo's?
The companies don't expect them to come back in one piece.
Still a waste though.
Link to comment
What difference does it make can you read it yes ? thought so .I wrote it quickly whats the problem .
Link to comment
Don't apologise - you're not alone and it wasn't a telling off.
What I will say is that the majority of posters on FOC do use punctuation (which does make posts much easier to read) and those who do tend to get more replies and become part of the community more easily.
Link to comment
I agree it's a waste of a good car, even if it isn't a real ST!
Ford spend millions on advertising and marketing their models though, so for the cost of one car, they are getting some pretty decent advertising to millions of people on Top Gear.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
