Support the club!
Mk4 Fiesta Engine, Starter Motor, Battery? Not Sure Whats Wrong!
Fiesta Engine
9 replies to this topic
#1 roberts_ian1988
roberts_ian1988
    Newbie
  • Pip
  • 1 posts
  • Name: Ian
  • Ford Model: Fiesta
  • Year: 2000
Posted 06 February 2012 - 04:50 PM
Any advice or ideas are welcome, please help!
I own a W reg MK4 Fiesta 1.4 zetec. I have NEVER hasd any engine, clutch, gearbox, battery problems or anything under the bonnet basically in the 4 years i have owned it. Has always driven smooth and perfectly.
Yesterday i drove out of a parking space, stalled (embarrassing i know) and the engine would not start again. Was still turning over, battery fine etc. Towed it home, go a sort of mechanic mate who discovered that was just the fuse for the fuel pump, replaced, started fine and went to bed (it was late).
The next morning had to jump start the car because the battery was drained from the numerous attempts to start the car the day before. Took the car for a drive and it now feels HORRIBLE! Every time i put my foot on the clutch it feels like its going to stall, the car feels like its shaking when this happens. When in neutral its shaking, the car just doesn't sound good at all, almost feels like exhaust is blowing but its in mint condition! I simply cannot figure it out! Any advice or questions feel free.
Thanks, Ian.
#2 akakray
akakray
  • 76 posts
  • Name: Jamie
  • Ford Model: Fiesta Zetec S
  • Year: 2011
Posted 06 February 2012 - 07:09 PM
I'll just throw a few ideas out there...
Idle control valve
Faulty or malfunctioning injector
Air flow sensor
Clogged fuel filter
Has it had a service recently? I ran a diesel for a couple of years without servicing it and it used to shake after I booted it, thought it was probably a clogged filter somewhere down the line but got rid before I looked into it.
Sorry it's no real help but just a few things I can think of
#3 stef123
stef123
  • Management
  • 3,609 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 06 February 2012 - 08:28 PM
sounds like it could be an ignition problem, possibly the ignition coil?
#4 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,834 posts
  • Name: Clive
  • Year: 2007
Posted 06 February 2012 - 08:37 PM
Maybe because the fuel pump went out the engine spinning over drew the fuel out of the pipes and left an air pocket. Possibly that has now moved up to the filter?
#5 btmaldon
btmaldon
  • PipPipPipPipPip
  • 1,589 posts
  • Name: Bruce
  • Ford Model: Focus Sport
  • Year: 2011
Posted 06 February 2012 - 09:42 PM
Id stick a good fuel cleaner in it and take it for a blast along a duel carriageway or motorway.
As mentioned above, check out the normal serviceable bits, especially if they havent been changed for a while.
#6 dah
dah
  • 89 posts
  • Name: dave
  • Ford Model: mk 7 Fiesta Titainum 1.6 TDCI
  • Year: 2011
Posted 07 February 2012 - 01:31 PM
Hi just have a look at the plugs to see if any are black make sure ht leads are on all plugs in order.This may be 1,3,4,2.
not sure ?.
Ps Some times plugs can get broken putting them back look at tops white bit check for cracks.
Dave
PPs If the plug leads have been moved they can break inside if old? this can give a missfire.
#7 orcomma
orcomma
  • 404 posts
  • Name: Jimmy
  • Ford Model: Fiesta Titanium 1.6 [95] TDCi
Posted 07 February 2012 - 01:56 PM
either coilpack or maf sensor i reckons
#8 William Crossey
William Crossey
    Member
  • Members via FB
  • PipPip
  • 29 posts
Posted 11 February 2012 - 10:19 PM
mk 4 fiestas and the first focus and facelift focus is very prone to ignition missfire and the only way to cure it is to replace the coilpack ignition leads and plugs. the simple pulling of the plugs and poping a single plug in to check car had a spark is enough to fracture a lead and cause the coil to go faulty.. its not a fault of the mechanic that looked the car over as they would have to have been on theyre way out and it just helped it along. a coil out of a motor factors is just as good as an origonal same with leads just ensure its good brand of plugs. the 02-05 fiesta is the same but the facelift of that version onwards had a new style coil pack fitted along with the 07 on focus onwards and that seams to have cured the missfire problem but afraid it will not fit the earlier cars without re wiring the car.
#9 andyuk7
andyuk7
  • 50 posts
  • Ford Model: encore
Posted 12 February 2012 - 08:22 AM
hi get your cat checked out as mines doing the same as mine loosing power when im driving and ive been reading on the net that my cats clogged
#10 William Crossey
William Crossey
    Member
  • Members via FB
  • PipPip
  • 29 posts
Posted 12 February 2012 - 08:48 PM
cats dont commonly clog on a petrol ford unless they suck water in and it swells the insides but if that happens it will have caused engine damage.. ive been a ford tech for many years and it is more common for an after market back box to clog but if the exhaust clogs either way then it will choke the engine and be down on power the fault above is splutering and missfireing and is unrelated.
