Noisey Door
3 replies to this topic
#1 Greg Sugrue
Greg Sugrue
  • Members via FB
  • Pip
  • 4 posts
  • Name: Greg
  • Ford Model: Focus Zetec
  • Year: 2011
Posted 10 February 2012 - 02:31 AM
My brand new 2011 Focus Zetec 2.0 Petrol has an annoying squeak / rattle in the drivers side rear door when you go over any rough road surface.
My dealer is 160kms away, and I asked them to look for the reason during the 2000km after sale check, but noise remains.
They put some silicon on the seals, but it is no better.
This is my first brand new car, and this is disappointing, my 13 year old Peugeot 206GTi is quieter, and that is saysing something!
Has anybody had noisey doors and found an answer ?
I don't really want to have to drive 160km to the dealer if there is something I can try myself B)
Have something to contribute?
#2 artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 8,094 posts
  • Name: arthur
  • Year: 2006
Posted 10 February 2012 - 06:14 AM
My courtesy car was the same i aplied sum grease to the door catch which sorted it if it doesnt im afraid youll have to take it back and insist on a courtesy car till its fixed.
#3 tyler s
tyler s
  • New Member
  • 36 posts
  • Name: david
  • Ford Model: focus
Posted 11 February 2012 - 06:55 PM
I had this problem and the fault was door hinge not adjusted correctly.To prove this get someone in back seat, drive over rough road slowly to make sure noise happens.Then retest with door open.If it stops adjust the door striker slightly inwards[open door and its the catch on body of car]only slightly loosen bolts and tap inwards tighten retest. make sure you only move it a small amount to keep you doors aligned.Also does this happen when you pull away quickly?
#4 the jbib
the jbib
  • New Member
  • PipPip
  • 13 posts
  • Name: Pete
  • Ford Model: Mk2 TDCI
  • Year: 2011
Posted 18 May 2012 - 08:57 PM
I have the same problem. I couldn't work out if it was the centre column or the rear door itself. I will try the fix. When you say loosen the catch, is that on the front side or the rear?
Not what you're looking for?
