Leefordfocus Posted February 12, 2012 Share Posted February 12, 2012 I've got 1.8 tdci 57 plate focus. The car won't start if parked on a hill facing up as if the fuel is draining back into the tank. I've had injectors checked, I've had a new return valve fitted not sorted it, I'm resorted to parking the car downhill at home and work. Help appreciated!! Quote Link to comment Share on other sites More sharing options...
Preee Posted February 12, 2012 Share Posted February 12, 2012 Sounds like an Split pipe allowing air in the fuel rail pipes allowing it drain back , can you smell diesel under the bonnet or under the car. Check al the diesel return pipes. Quote Link to comment Share on other sites More sharing options...
Leefordfocus Posted February 12, 2012 Author Share Posted February 12, 2012 Yeah I thought split pipes, I've had a new return valve fitted thought that would cure it but no luck, you can smell diesel under car/bonnet. Quote Link to comment Share on other sites More sharing options...
