Radio Fascia
#1
Posted 14 February 2012 - 09:54 PM
Also, i'm struggling to find a curved fascia. Anybody know where i could obtain one.
Many thanks.
#2
Posted 14 February 2012 - 10:28 PM
The MK2 comes out with keys and the fascia has two torx to remove it.
The 2.5 has a fascia that unclips and the radio is held in with 4 torx.
This is a MK2.5 fascia and just clips in.
http://www.ebay.co.u...=item27c36011e7
This is a MK2 fascia and is held in place behind the radio face by 2 torx screws.
http://www.ebay.co.u...=item2c624b55c6
This is a MK2 style radio with the 4 key slots for removal as marked.
This is a MK2.5 radio which has screws to secure it into the dash.
http://www.ebay.co.u...=item4cfe68fd47
I'm pretty sure you get the gist of it.
To fit the MK2 dash you'd need a radio with the key removal method rather than the screw in chassis.
May i suggest one like this?
http://www.ebay.co.u...=item1c23a73815
Just be sure that it is listed for a Focus as Mondeo radios are slightly different sizes as in they are too long for the dash, slightly angled on the face and the face size is slightly bigger too.
Hopefully you find this info useful and it saves you from buying a radio which you can't fit properly.
#3
Posted 14 February 2012 - 11:49 PM
So i'm now looking at this stereo : http://www.ebay.co.u...c#ht_500wt_1287
Do you reckon i'll have any problems with this one? Looking at it the stereo is square so I won't have to change the fascia and there are keys on each of the corners of the stereo.
#4
Posted 15 February 2012 - 12:15 AM
Far better than the standard Visteon radio.
#5
Posted 15 February 2012 - 07:22 AM
#6
Posted 15 February 2012 - 09:19 AM
#7
Posted 15 February 2012 - 09:57 AM
If the radio you are after has the same mounting method as the focus you have i.e as per my earlier post you'll be ok.
#8
Posted 15 February 2012 - 10:01 AM
As long as you have the right security code then there will be no problems.Hi, FocusTDCI110, just a quick reminder regarding the ford 6000 radios, they all have the vin number and reg of the car they was fitted to, I don’t know what involved in having it changed.
You can change those details yourself as it's more of a way to identify the radio if stolen and recovered.
The radios are not locked to any particular vehicle.
#9
Posted 15 February 2012 - 08:37 PM
the conversion from Mk2 to Mk2.5 Ford audio unit is pretty simple. I did it in around 45mins. You need the Oval fascia, and brackets for the new unit, as the new unit screws in. I found the screws were the pain to sort, as ford dont stock them (or say they dont). I finally went to B+Q and bought a small packet of the fattest, and shortest self tappers, and used them.
This website has step by step pictures of the process with Ford part numbers if the stuff you need, so you dont need to confuse the Fords storeman.
hope that helps..., BTW, I am sure that the unit you have seen on E-bay will also need a curved fascia as well.
http://www.jamessimp...to-preface-lift
#10
Posted 15 February 2012 - 09:43 PM
The radio Jack linked to is a standard MK2 fit, it's just the inner part of the radio face that has the curved look to it.
I can understand your point about the fascia shape but if you look carefully at the picture the radio face is rectangular with the 4 key slots so will fit a MK2 without having to change the fascia but will look like a MK2.5 radio to the casual observer.
#12
Posted 15 February 2012 - 10:34 PM
Probably also needs an aerial upgrade too but that's straightforward.
#13
Posted 15 February 2012 - 10:58 PM
#14
Posted 16 February 2012 - 12:55 AM
Hi
I can't see the complete tutorial for the conversion. Am i missing something? I'm gonna give it a go this weekend, little bit worried about the brackets situation. Can anyone expand on this for me?
#15
Posted 16 February 2012 - 12:58 AM
I have some experience with this kind of equipment. Navigation software is stored on SD Card. You can use any navigation software for Windows CE Net, so UK maps or any others are not a problem. You do not have to change the aerial, there is additional GPS aerial and it is working fine even when mounted under dash. For me the problem is radio interface, poor graphic, bad quality HF system, no RDS (despite it is stated in specification) and many others. This kind of radios do a lot of things but I was sick every time I had to use it. They are all the same china product with different front panel. If I was to install such radio I would go for Kenwood, Pioneer, JVC etc. They are much more expensive, but using them is pleasure not pain.
Unfortunately that's the problem with buying kit meant for another country.
The RDS coding is probably totally different where the radio is meant for and it is very true that you get what you pay for.
I'd love a top end double din radio unit with everything integrated but it's justifying the cost to myself and more importantly the wife.
Also tagged with one or more of these keywords: radio, fascia, heater controls, curved fascia, facelift stereo
United Kingdom - General Ford Discussions by Model →
Ford Fiesta Club →
New Fiesta - Radio Not Turning On Automatically?Started by Boggsy, 11 May 2013 |
Ford Modifications and Projects →
Ford Modification Discussions →
Ford Smax 2007 - Replacing Standard Radio (6006Cdc) With Sony Cd DabStarted by KevW, 23 Apr 2013 |
Ford Fiesta Club →
Fiesta 4500 Rds Cannot Refit! Help!Started by douglasj93, 07 Mar 2013 |
General Forums →
Audio & Electronics →
Transit 2005Started by bezerk, 25 Feb 2013 |
Ford Fiesta Club →
2009 Fiesta Zetec Electrical Problem?Started by Samster12, 25 Jan 2013 |
Latest Comments
More
