Remap Or Superchip?
#1
Posted 16 February 2012 - 02:35 PM
What advantages do they have over one another? I presume the superchip is easily removable and you can fit and remove yourself.
Cost wise there fairly simular, remap being around £300 and superchip at £400.
Dose the superchip just come with 'pre loaded' map on it that is a general basis for the car it is purchased for? If so it seems fairly simular to having the car remapped at a tuning garage who will only have a general basis map for your car/engine.
Iv also been warned about clutch/gear box issues, I beleive the gear box should be able to take the extra power no problem, but what about the clutch? My cars done just over 80k, is clutch failer prown to be an issue?
One last thing is insurance, do insurance companies tend to penalise one more over the other? Iv read many people saying with superchips etc you can remove them quickly in the event of an accident, but personally I would never take that chance and will be letting my insurance company know whichever I choose. What is the rough increase on your premium when adding either of the two? Or dose it simply vary on the driver/car/person who deals with the call?
Any help would be much appreciated.
#2
Posted 16 February 2012 - 08:46 PM
never use a tuning box
Bluefin = an OBD device that remaps your ECU, same as any remap. The good part is that you can choose how much you want to tune your car, and you can always change it back to default
Tuning box = a device that "fouls" the ECU. It is something that you would have to keep pluged in all the time, and actually sends wrong info about the diesel/air mix in order to give more power. This is bad because it will run you turbo charger in a way that will break it.
Also never tune your car to the max, do a safe tune first. After DPF delete, new exhaust, better air intake system (i don't mean just a filter change)', you can increase the power gradually (bluefin has 3 stages of remap that you can upload to your car). Keep in mind that some so called "tuners" don;t take into account, the maximum pressure your turbo charger can take. Also they don't take you account that your turbo, because of all the "save the planet" stuff put on your car (EGR, DPF, CAT), works overtime, so if you take all that off, your car will breathe better, have more fresh air (no EGR means no gas recirculation), and it will work better, even without tuning
#3
Posted 16 February 2012 - 10:09 PM
#4
Posted 17 February 2012 - 10:13 AM
Every other solution is kind of universal. I have used tuning box for abt 3 years. I did it only because I bought used one much cheaper than I would have to pay for remap. I was very pleased with it and I loved additional power. Nothing happened to the engine or clutch, there was no black smoke when accelerating. One thing about tuning boxes is they give to a lot of torque from low revs and if you do not operate properly this can kill the clutch pretty fast. New tuning box costs more than remap. Forget cheap tuning boxes from ebay for few quid - they just cheat air temperature sensor, this has nothing to do with real tuning box. For me the biggest advantage of the box is the fact, that you can take it out at any time, fit it in other car (as long as it is compatible) or simply sell it and get part of the money back.
#5
Posted 17 February 2012 - 10:53 AM
Anyone got the blufin remap on there focus diesel?
cheers
#6
Posted 17 February 2012 - 11:13 AM
Better panel filter but no modifications to the exhaust and I still get 150hp.
When I got the car it had been apparently tuned before but not very well as it was flat in second.
Now it has good power through the full range and only a very brief lag.
It goes like a goosed whippet.
#7
Posted 17 February 2012 - 11:33 AM
It is true that a remap, using real time dyno, plus a few other tweaks, getting new tubo times, new gear times, new pressures and so on is the best you could have, but bluefin is a good alternative nevertheless.
PS: 200.000 miles is kind of late for a remap, but if your car is ok, engine wise, turbo wise, EGR is clean and so on, you should be fine ... unless you are willing to do an engine rebuild. My personal advice would be to do a safe tune, for a 2.0tdci 136 bhp, you could go for about 170bhp i think.
#8
Posted 17 February 2012 - 11:46 AM
Pidu you are right, but also keep in mind bluefin is not generic, when you get it, you have to get your own ECU software, send it to them, they would, in theory create a tune map for your car, and then you can upload it in your ECU. At least this is how i got it done on my old mondeo.
Bluefin you are talking about is new to me, so I was not talking about it at all. From what you say I would place it between tuning box and proper remap, because tune map you get will never be as good as remap done with dyno, but will be way better than box.
#9
Posted 17 February 2012 - 01:50 PM
Hey,
never use a tuning box, you can buy a bluefin device. That is actually writing the software on you ECU. So it is like you have the remap in your own hands. It is more expensive than just go and remap it somewhere, but on the other hand, when you go to have your car checked, you just plugin the bluefin, change to default software job done.
Thanks very much for the info, much appreciated!
My car is non DPF, I beleive it was introduced to the focus' in 2006? But anyway, with that in mind there is no need to remove dpf etc.
When you say the bluefin kit has 3 tune stages I presume that is just a generic map that increases power and torque each time? (3 being the most)
You also mentioned in another post about you send your current ecu data to them and they can create a map for you? Dose this mean when you buy a bluefin that is is 'blank' and you have to upload a set of map data to it? I may have misunderstood what you meant there though.
Also when you say 'you can plug in and set back to standard settings when you have your car checked' I presume this is in reference to warrenty? My car has no worrie so therefore isnt an issue to me.
Also once you have the bluefin device, say for example I sold my focus and bought I dont know.. For arguements sake vw golf turbo diesel, can I download new 'map software' to the device so that it can be used in other cars?
Sorry for all the questions, the bluefin device is completley new to me!
#10
Posted 17 February 2012 - 02:36 PM
Bluefin came with a generic map for it but they give you the option to upload your current map to them and quite quickly- one hour for me - they mail back a custom map based on your cars data.
I did mine and then a buddy of mine who works for VOSA did a dyno test for me.
Lower setting gave me 135bhp top one runs at near as makes no difference 150bhp.
Standard tune was 115bhp.
I recommend a full service beforehand to get the best tune results.
#11
Posted 17 February 2012 - 02:41 PM
Read the second part ... it will answer some of your questions.
This is a more general info :
http://www.mybluefin...=2&variant=1735
http://www.superchips.co.uk/
If you change car, you will have to buy a new one i think. Not 100% sure.
Bluefin may be let's say "out of date" not blank.
In theory there should be 3 stages of tuning stored on the bluefin :
Stage 1: the so called "eco tuning". Increases your bhp/torque by about 5-10% maybe
Stage 2: The most used without any other modifications (safe tuning) to the car (no air kit, no exhaust and so on) that will take you car to around 30% increase
Stage 3: This will take you car further, over 30%
Keep in mind these numbers are for a new focus. With 200k miles, this may be different.
Yes, you can make a backup of your original/default ECU software with this, and you can store it on a computer/laptop/stick whatever you want, and put it back if you ever need it.
Also, take into consideration what "Pidu" said, this bluefin is a generic tuning more or less.
As a general knowledge, most manufacturers of normal cars, "under tune" their cars. Why? Because those cars have to perform the same in all kind of conditions (Hot/cold, humid/dry and so on) for a lot of time. This is why most turbo charged cars, it is said they have an upper limit of about 25-30% more then you get when you buy the car, in which you can increase you performance, without any real effect to the cars "health". After you pass this limit, you will shorten your cars life. By this i don't mean the engine itself, this may include, turbos, hoses, superchargers, transmission, clutch, egr and so on. The diesel engine is very sturdy by design because it has to withstand a lot of explosions after all. and a lot more pressure then a petrol one. But the components all around it ... that is another story.
Also tuning means more then a remap. Tuning means getting your car in a better condition. If you were for example to get involved in racing, you will find that the first "tune" you car will suffer is suspension and/or braking system. Engine remap it's probably the last thing you should do
SO, tuning means more then just a simple remap, i am just saying
Hope this answers your questions.
#12
Posted 18 February 2012 - 03:07 AM
I'm not a particularly fast driver, but occasionally i do DRIVE the car if you know what i mean?
I reckon a re-map would suit my motor rather than a box or a bluefin...As i do have a custom twin exhaust, but no filter upgrade at this stage (opinions on filter upgrades appreciated, good? bad?)
Does it matter if one was to run on regular diesel or BP Ultimate post mapping? My car doesn't seem too fond of BP ultimate (almost cut out twice) But seemed happier on a half and half mix of regular fuel and ultimate.
#13
Posted 18 February 2012 - 09:03 AM
I've always been a strong believer that too much power used wisely is more economical than a stressed smaller engine driven on the limit... Re-mapping will (to put it crudely) "make my engine bigger" (excuse my overly simplistic terminology)
Thats my exact way of thinking!
Iv just had the car serviced less than 20 miles ago (not getting to drive the car as im working abroard a lot at the moment) And I also plan to have the cambelt done within the next 5k, proberbly after my next stint abroard after march. I will proberbly save having either a remap or buying a bluefin till then, At the moment im more swaying towards the bluefin, simply because you can varey the 'tune' on the car to what you prefer, you can reset back to standard any time you like, and it also acts as a fault code reader, for what you pay you get a fair bit of kit.
Dose anyone have any information/experience regarding using the bluefin as a fault diagnostic tool?
Again, thanks for all the helpful information.
#14
Posted 18 February 2012 - 02:34 PM
#15
Posted 24 February 2013 - 01:08 PM
Besides that also noticed power delivery still start at the same points and not as their dyno graph which quicker delivery (@ lower RPM)
I just emailed them about this and hopefully they will give me a revised map. Before I purchased, I asked them how many maps they would provide and they said only 1. Hopefully they would be willing to help me fine tune it for me.
What are your experiences with Superchips if you have encountered before ?
