NLPNick Posted February 22, 2012 Share Posted February 22, 2012 Hi My alternator belt snapped on my focus 1.8 TDDI, (not the biggest of problems), upon inspection the belt tensioner wheel looks quite worn, so I have ordered a belt tensioner. After reading further about the job online it has been suggested that the original cause of the belt snapping could be that the water pump has jammed, thus causing the belt to heat/ cause wear to belt tensioner. Prior to the belt snapping the car was making an interminent noise which i assume was wear to belt tensioner but the car was running great. My challenge is if I replace the belt and tensioner, and the real cause of all this was the water pump it could be money i really cant afford wasted. Clearly i dont want to change a non faulty water pump at the price they are. How would I know if the water pump has gone or not? Any help would be appreciated, thanks in advance :) Quote Link to comment Share on other sites More sharing options...
tyler s Posted February 22, 2012 Share Posted February 22, 2012 spin the water pump pulley.if it spins and has no up and down movement it should be ok Quote Link to comment Share on other sites More sharing options...
alz Posted February 22, 2012 Share Posted February 22, 2012 Hi, if the belt is still off, test the water pump for play, to see if there is any side to side movement in the pully, also look for water leaking. Quote Link to comment Share on other sites More sharing options...
NLPNick Posted February 22, 2012 Author Share Posted February 22, 2012 Thanks alz and tyler - will do both of those in morning as dark here and am restricted to working in street, but really appreciate your posts :) Quote Link to comment Share on other sites More sharing options...
NLPNick Posted February 22, 2012 Author Share Posted February 22, 2012 it seems to be seized solid, so I guess that means a new water pump. at least by learning on the forum i didnt waste my cash on having to purchase another belt and poss tensioner. thanks Quote Link to comment Share on other sites More sharing options...
