Overheating Problem
18 replies to this topic
#1 anthzm
anthzm
    Member
  • New Member
  • PipPip
  • 29 posts
  • Name: Anthea
  • Ford Model: focus estate
  • Year: 1999
Posted 26 February 2012 - 01:42 PM
Hi please can someone help me. My car was over heating so we replaced the thermostat, but it still kept over heating so we bled it to remove air. Now the pipes furthest away from the water bottle are getting hot, but the pipes closest to the bottle and the radiator are staying cold. There is still high pressure building up in the water bottle and it is bubbling. The fan comes on randomly even when the radiator is still cold.
Do you think I still have air in the system? or what else could it be! :(
Have something to contribute?
#2 Darren T
Darren T
  • New Member
  • 76 posts
  • Name: Darren
  • Ford Model: Ka
  • Year: 2004
Posted 26 February 2012 - 01:45 PM
Hi, Your problem does sound like a massive air lock
#3 anthzm
anthzm
    Member
  • New Member
  • PipPip
  • 29 posts
  • Name: Anthea
  • Year: 1999
Posted 26 February 2012 - 02:04 PM
thats what I thought too, thank you. Any advice on how I can solve this problem please and tell where the air lock is? I have had the car running for 20 minutes with the bottles cap off, but it still does it when I drive it.
#4 Darren T
Darren T
  • New Member
  • 76 posts
  • Name: Darren
  • Ford Model: Ka
  • Year: 2004
Posted 26 February 2012 - 02:25 PM
Try putting the heater to hot and the blower to max, Keep squeezing the cold hoses to try and shift the air lock. Without seeing the car i can't tell you where the air lock is.
#5 anthzm
anthzm
    Member
  • New Member
  • PipPip
  • 29 posts
  • Name: Anthea
  • Year: 1999
Posted 26 February 2012 - 02:28 PM
Thanks I will give that a go :) shall I do that with the cap off again?
#6 Darren T
Darren T
  • New Member
  • 76 posts
  • Name: Darren
  • Ford Model: Ka
  • Year: 2004
Posted 26 February 2012 - 02:34 PM
In theory it shouldn't make much difference as most cars should be self bleeding. But it won't hurt to try it with the cap off. Good luck with it.
#7 anthzm
anthzm
    Member
  • New Member
  • PipPip
  • 29 posts
  • Name: Anthea
  • Year: 1999
Posted 26 February 2012 - 02:39 PM
Thank you :)
#8 Darren T
Darren T
  • New Member
  • 76 posts
  • Name: Darren
  • Ford Model: Ka
  • Year: 2004
Posted 26 February 2012 - 02:40 PM
That's ok
#9 Darren T
Darren T
  • New Member
  • 76 posts
  • Name: Darren
  • Ford Model: Ka
  • Year: 2004
Posted 26 February 2012 - 02:42 PM
That's ok :D
#10 Z3 MON
Z3 MON
  • New Member
  • 328 posts
  • Name: David
  • Ford Model: Ford Mondeo 2.0 TDCI 115 Mistral 2004
  • Year: 2004
Posted 26 February 2012 - 02:47 PM
Most modern cars do not need bleeding as they self bleed, if the water is acctually bubling i would suggest that your have hed gasket failure. have you checked the oil level? does the water level keep dropping? what colour is the water, also is there any white stuff on the cap of the radiator?
#11 anthzm
anthzm
    Member
  • New Member
  • PipPip
  • 29 posts
  • Name: Anthea
  • Year: 1999
Posted 26 February 2012 - 03:02 PM
I was hoping no one would mention the head :( The oil level is fine and the water is clear. I haven't noticed the water level drop, but the car should be cold now so I will go and check. The radiator is a sealed unit, so do you mean the water header bottle cap?
#12 anthzm
anthzm
    Member
  • New Member
  • PipPip
  • 29 posts
  • Name: Anthea
  • Year: 1999
Posted 26 February 2012 - 03:43 PM
The water level has dropped, but I think I can safely say the head has gone, as when I rev it there is water coming out of the exhaust :( :(
#13 btmaldon
btmaldon
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,581 posts
  • Name: Bruce
  • Ford Model: BMW 320i Coupe M Sport, KA Luxury
Posted 27 February 2012 - 04:44 PM
You will get water out of the exhaust anyway as that is what the cat converts the gases to. Try changing the expansion tank cap. It sounds like its not holding the pressure, which makes the coolant boil at a lower temperature and stops it circulating properly which gives you hot and cold spots like an air lock.
Good luck.
#14 anthzm
anthzm
    Member
  • New Member
  • PipPip
  • 29 posts
  • Name: Anthea
  • Year: 1999
Posted 27 February 2012 - 05:47 PM
Thank you, I have ordered one and will collect it tomorrow, lets hope that is all it is. All this advice is great, I am ruling everything out and trying to sort the problem before having to go to a garage. :(
#15 btmaldon
btmaldon
  • PipPipPipPipPip
  • 2,581 posts
  • Name: Bruce
Posted 27 February 2012 - 07:21 PM
Let us know how you get on.
Not what you're looking for?
