Mk4 Gearbox
10 replies to this topic
#1 Lee churchyard
Lee churchyard
    Member
  • New Member
  • PipPip
  • 25 posts
  • Name: Lee
  • Ford Model: Mondeo mk4 2.0 6 speed diesel
Posted 01 March 2012 - 09:33 PM
Hi my mk4 mondeo started to give me problems ie gearbox it was hard to get it in first gear in the morning and second once it warmed up it was a bit better had a new clutch dmf and bearing so it's all new in there it was good for a few days but although better still seams a bit clunkie in the morning any ideas plz
Have something to contribute?
#2 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,133 posts
  • Name: Clive
  • Year: 2015
Posted 02 March 2012 - 01:21 AM
Was the clutch fork checked?
They can bend a little.
#3 Lee churchyard
Lee churchyard
    Member
  • New Member
  • PipPip
  • 25 posts
  • Name: Lee
Posted 02 March 2012 - 08:58 AM
What's that ?
#4 Stoney871
Stoney871
  • Super Mod
  • 18,133 posts
  • Name: Clive
  • Year: 2015
Posted 02 March 2012 - 12:48 PM
The clutch fork is the bit that disengages the clutch by pulling the plates apart.
If it's out of shape the clutch will not disengage correctly.
Not from a Mondeo but It will look something like this-
http://www.ebay.co.u...=item3f1434d380
#5 Lee churchyard
Lee churchyard
    Member
  • New Member
  • PipPip
  • 25 posts
  • Name: Lee
Posted 02 March 2012 - 01:43 PM
Mk4 mondeos don't have that it's all dun by hydrolics if I've spelt that right
#6 Stoney871
Stoney871
  • Super Mod
  • 18,133 posts
  • Name: Clive
  • Year: 2015
Posted 02 March 2012 - 01:47 PM
I stand corrected.
#7 mondeo161
mondeo161
    Member
  • Budding Enthusiast
  • PipPip
  • 28 posts
  • Name: John
  • Ford Model: Mondeo MK4 Titanium X 163
  • Year: 2011
Posted 01 June 2015 - 08:44 AM
I have the same problem.
I personally suspect something to do with the gearbox as when driving the gearchange was fairly smooth and the bite was sharp. But like you selecting first or reverse when the car is static was mostly very difficult.
Anyway I took it to the local ford dealership (Macklin Motors) who had their "Master Technician" asses it and he diagnosed the clutch was at fault. ( I was still skeptical) but let them change the clutch complete including the DMF. (My wallet is now very light)
I put the car in on the morning and it was ready at 4.30 (I was impressed) but hey presto the fault is still there.
I ran it for a day to give the clutch time to bed but no change so I asked to go for a run with the technician so I could explain exactly the fault. The car was making an out to be a liar as it was selecting 1st with just slight difficulty but he could not select reverse without selecting one of the forward gears and eventually accepted there was a problem.
The car goes back in next Tuesday and when they have said they will have to take the box back out.
Update to follow.....
#8 pragmatix
pragmatix
  • 554 posts
  • Name: Pete
  • Ford Model: Mondea 2Ltr Tdci Titianium Estate
Posted 02 June 2015 - 07:49 AM
The cables may need adjusting, prone to going out of adjustment
#9 flying clutchman
flying clutchman
  • 179 posts
  • Ford Model: transit2.5D
Posted 04 June 2015 - 10:33 AM
If the car is having difficulty selecting gears while stationary then it's likely to bhe clutch related. The reason is this: provided the car is completely stationary when you push the clutch down, every thing in the gearbox should stop moving. Try selecting first or reverse before you switch on. If it selects easily, but won't when you start the engine, it suggests the clutch is not quite disengaging 100%
 One thing you can try which might help is to press the clutch in and hold for 2 or 3 seconds before you try to select the offending gear. This gives the clutch disc time to stop spinning, it helps sometimes.
#10 mondeo161
mondeo161
    Member
  • PipPip
  • 28 posts
  • Name: John
  • Year: 2011
Posted 04 June 2015 - 08:11 PM
Thanks Clutchman I will give the 2 second rule a try.
What I have noticed is that when I park the car on my drive which is sloped. It seems to go into reverse no probem, especially first thing in the morning.
At other times and when on flat ground is when the difficulty selecting occurs.
#11 mondeo161
mondeo161
    Member
  • PipPip
  • 28 posts
  • Name: John
  • Year: 2011
Posted 09 June 2015 - 09:40 PM
UPDATE:
The car went in to Macklin Motors this morning. I got a phone call from the service desk in the afternoon to advise that the Synchro on the lower gears was the problem so the box has to be opened and a few parts replaced.
I questioned why the clutch was replaced in the first instance and was told that it also needed replaced but the synchro could have been done at the same time, "So I would not be charged for the work involved removing the gearbox on this occasion"
I would be charged for opening the gearbox and replacing the worn parts. Cost not far off of £800 on this occasion.
I am not a qualified mechanic but I have driven and worked on cars for many years so I questioned the initial diagnosis when I was told that the clutch was the problem.
Today I have been proven right but cannot prove that the clutch did not need replaced as they have not got the clutch they removed two weeks ago.
With a total bill of around £1800 "after much haggling" I think any further mechanical work will be going to a not so expensive trusted mechanic.
Be wary of wrong diagnosis at ford dealers!!!!
Not what you're looking for?
