Focus Knocking On Offside Front Wheel
kingliam
 Share
hi i have a knock on a offside front wheel i think it could be a ball joint but not sure can any one help thanks
Link to comment
It could be the lower ball joint, track rod ball joint, worn lower arm bushes, arb bushes and possibly a few other things
Without inspection its impossible to say
Link to comment
You'd need to get it on a lift and give the wheel a good push and pull, turn the steering to full right lock and inspect the joints for play and wear.
A badly worn ball joint will be quite evident if there.
Link to comment
thanks all can it be the track rod
Link to comment
It could be the track rod end? I had a knocking on my old focus but the steering was also a bit iffy at times. replaced the track rod ends and it certainly transformed the car. quite easy to check these though, get the wheel off and see if they move or knock
Link to comment
hi i have fited all new parts ball joints suppenon leg spring bushes and it keeps on knocking any help please
Link to comment
do you have a "notch" in the steering at a certain point? ie it "notchs" at the same point of turn?
if not then my brothers one had a top mount go and his knocked.
also jack the car up and see if there is any play in the wheel, could be wheel bearing? although thats normally a humm
Link to comment
hi thank i have looked and cant see any think wrong with it .the only thing i can think of now is the tie rod cant be any think else
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
