Handbake Woe
6 replies to this topic
#1 coreyams1
coreyams1
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Name: lee
  • Ford Model: focus
  • Year: 2005
Posted 02 March 2012 - 08:25 PM
My handbarke lever has just decided to fall apart (it's the plastic push in button) not only does it now look naff but !Removed! annoying to use aswell giving you a sore thumb! is this an easy fix or do I have to rip half my centre consol apart? if so how do I go about it.it's an 05 climate model.
Have something to contribute?
#2 irl-06lx
irl-06lx
  • New Member
  • 124 posts
  • Name: Alex
  • Ford Model: LX
  • Year: 2006
Posted 03 March 2012 - 08:58 AM
taking the centre console out is simple, it all pulls apart and four 10mm bolts gets the main bit off.
but you shouldn't need to take it out
the handbrake gaitor (the plastic surrounding the fabric that covers it) just lifts off. A flat screw driver in the top of it and pry gently up and it'll pop off.the fabric has an elasticy closure over the handbrake so just pull that off. Nothing else needs to come off to get the handbrake cover off.
#3 JamieFOB
JamieFOB
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Name: Jamie
  • Ford Model: Ford Focus 2.0 Ghia
  • Year: 1999
Posted 09 March 2012 - 02:41 PM
You don't need to take the console off. I've just replaced the parking brake handle on the wife's '99 2.0 litre Ghia, took 40 mins.
Be careful prising off the gaiter, it's only held in place by a flexible pastic trim. Gently insert a flat bladed screwdriver at the rear end (closet to the rear seats) of the gaiter and softly push down & towards the rear seats. It's only a small plastic lip to clip out, then squeeze both sides and the two at the front/sides will pop out as well. Pull the gaiter off over the handle.
Handle assembly is simple, just two bolts in the base and one on the cable. All 10mm. Then remove the sensor clip and it comes out. Fitting is obviously the reverse.
I'm no mechanic but it really is easy.
JamieFOB ;)
#4 irl-06lx
irl-06lx
  • New Member
  • 124 posts
  • Name: Alex
  • Ford Model: LX
  • Year: 2006
Posted 09 March 2012 - 05:54 PM
Jamie did you take the hand grip of your handbrake?
I'm looking at getting the cover linked below, which is a replacement for the one thats on the car. Its a standard black one. I'd love to take my one off and replace it but no clue how.
any chance you could run through how to get it off if you did this? I can see no way to remove the actual handle at all.
pretty well versed in getting gaitor and centre console off.
part is below
http://www.fordparts...34522_c_106.htm
cheers
#5 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,570 posts
  • Name: Clive
  • Year: 2015
Posted 09 March 2012 - 05:58 PM
From what I read jamie replaced the whole handbrake assembly.
As far as I'm aware the part you're planning requires removal of the old plastic grip and requires cutting to do so.
#6 irl-06lx
irl-06lx
  • New Member
  • 124 posts
  • Name: Alex
  • Ford Model: LX
  • Year: 2006
Posted 09 March 2012 - 06:03 PM
ah cheers stoney. don't want to hijack the thread as I know i have my own!
#7 JamieFOB
JamieFOB
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Name: Jamie
  • Year: 1999
Posted 10 March 2012 - 09:46 AM
Spot on Stoney. The handle grip on my old one just slid off with a twist but I think this was only possible because the release/rachet system was broken anyway. I looked at the new one but couldn't see any way of getting it off without breaking /cutting it.
JamieFOB B)
Not what you're looking for?
