Focus 05 Mk1 Speedo Probelm
10 replies to this topic
#1 Paul Rogers
Paul Rogers
    Newbie
  • New Member
  • Pip
  • 5 posts
  • Name: Paul
  • Ford Model: Focus
  • Year: 2005
Posted 05 March 2012 - 10:38 AM
I have recently brought a 05 plate mk1 1.6 petrol focus zetec manual and all has been fine until recently, when i have been driving along the speedo drops to 0 and stays there for awhile or goes to 0 and straight back up to the speed i am going, none of the other dials are affected the miles are still displayed, there is no loss of power or performance everything else is fine it is just the speedo and there doesn't appear to be any pattern as to when it occurs its just random, does anyone have any idea what it could be?
Have something to contribute?
#2 tomo2001
tomo2001
    Serial Poster
  • Budding Enthusiast
  • 485 posts
  • Name: Paul
  • Ford Model: Ford Focus 1.6 TDCi Titanium X
  • Year: 2011
Posted 05 March 2012 - 11:31 AM
Doesn't the Focus around that year suffer from instrument cluster electrical gremlins ? I'm sure other members will advise or a quick search may help.
#3 tomo2001
tomo2001
    Serial Poster
  • 485 posts
  • Name: Paul
  • Year: 2011
Posted 05 March 2012 - 11:34 AM
http://www.fordowner...__1#entry153918
#4 Paul Rogers
Paul Rogers
    Newbie
  • New Member
  • Pip
  • 5 posts
  • Name: Paul
  • Ford Model: Focus
  • Year: 2005
Posted 05 March 2012 - 01:07 PM
I have done the dashboard trick and have got the following errors
D041 ..........U1041.......... Invalid data for vehicle speed
D123 ..........U1123.......... Invalid data for odometer
all the gauges swept correctley, could this be a problem with the VSS?
#5 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 17,820 posts
  • Name: Clive
  • Year: 2015
Posted 05 March 2012 - 03:30 PM
Check the speedo cluster and try WD40 on the back.
If that's no good then i'd recommend changing the VSS.
#6 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,892 posts
  • Name: arthur
  • Year: 2006
Posted 05 March 2012 - 04:33 PM
vehicle speed sensor on the gearbox is the culprit not the cluster though ide advise having ford change it as the pins corrode and can be a sod to get out if its the cluster you would also notice the temp gauge drop at the same time then pick back up
#7 Stoney871
Stoney871
  • Super Mod
  • 17,820 posts
  • Name: Clive
  • Year: 2015
Posted 05 March 2012 - 08:57 PM
It is possible to do the job yourself but can take ages to get the old one out and a risk of snapping the pin off.
I'd recommend getting the bits needed from eBay and approaching a local garage.
It would be far cheaper than at a dealer as they would probably insist in swapping other things at the same time as they usually do plus they love pushing for diagnostics you don't need.
#8 Paul Rogers
Paul Rogers
    Newbie
  • New Member
  • Pip
  • 5 posts
  • Name: Paul
  • Ford Model: Focus
  • Year: 2005
Posted 05 March 2012 - 10:08 PM
thanks guys i will get the parts and ask my uncle to do it for me as he is a mechanic
#9 Stoney871
Stoney871
  • Super Mod
  • 17,820 posts
  • Name: Clive
  • Year: 2015
Posted 05 March 2012 - 11:37 PM
Best option i reckon, make sure you get a VSS and a pin as i guarantee the pin will get mangled removing it.
For some reason most of the original fit pins are hollow and are none too sturdy wheras the new ones are solid and more robust.
Definitely recommend you grease or graphite the new pin though in case you need to remove it again.
#10 Paul Rogers
Paul Rogers
    Newbie
  • New Member
  • Pip
  • 5 posts
  • Name: Paul
  • Ford Model: Focus
  • Year: 2005
Posted 07 March 2012 - 10:58 AM
New VSS and pin order my uncle will fit it for me when it arrives lets hope this sorts the problem out and its not the cluster
#11 artscot79
artscot79
  • PipPipPipPipPip
  • 7,892 posts
  • Name: arthur
  • Year: 2006
Posted 07 March 2012 - 11:59 AM
it rarely is the cluster some garages will say it is when its not the vss is the cheapest and simplest option to go for and in 99 percent of cases solves the problem
Not what you're looking for?
