higgsy Posted October 22, 2013 Share Posted October 22, 2013 it don't work on mine no matter how long I set it I think you cant set it Nice one dezwez, if others are having the issue it must be a feature only available to some models. Quote Link to comment Share on other sites More sharing options...
mayak Posted October 22, 2013 Share Posted October 22, 2013 according to author, it doesn't work at all 1 Quote Link to comment Share on other sites More sharing options...
minimadgriff Posted October 29, 2013 Share Posted October 29, 2013 Is it possible to enable DDS on a S-Max or do they need sensors in the tyres unlike the Focus/Kuga? Also to enable auto locking for a Mondeo/S-max is the procedure as follows :- - Read from IPC - Read from BCM - Select Central Configuration - Automatic Locking by speed - Select with automatic locking - Write to IPC - Write to BMC Is that correct? Or should it be done the following way? - Read from BCM - Select Central Configuration - Automatic Locking by speed - Select with automatic locking - Write to BCM Then - Read from IPC - Select Central Configuration - Automatic Locking by speed - Select with automatic locking - Write to IPC Thanks Ben Quote Link to comment Share on other sites More sharing options...
fyl Posted October 30, 2013 Share Posted October 30, 2013 Is it possible to enable DDS on a S-Max or do they need sensors in the tyres unlike the Focus/Kuga? Also to enable auto locking for a Mondeo/S-max is the procedure as follows :- - Read from IPC - Read from BCM - Select Central Configuration - Automatic Locking by speed - Select with automatic locking - Write to IPC - Write to BMC Is that correct? Or should it be done the following way? - Read from BCM - Select Central Configuration - Automatic Locking by speed - Select with automatic locking - Write to BCM Then - Read from IPC - Select Central Configuration - Automatic Locking by speed - Select with automatic locking - Write to IPC Thanks Ben Not sure about the S-Max but I enabled DDS on my focus mk2.5 without any sensors in the wheel as DDS uses the ABS sensors (guessing Yaw/Pitch/wheel speed) to work. I had a recent flat and DDS issues a warning on the information cluster to check tyre pressure. 1 Quote Link to comment Share on other sites More sharing options...
minimadgriff Posted October 30, 2013 Share Posted October 30, 2013 On my Kuga I have too, but I am not sure about the S-max :( On the internet I can find listings for tyre pressure sensors. Quote Link to comment Share on other sites More sharing options...
747777 Posted October 30, 2013 Share Posted October 30, 2013 Is it possible to enable DDS on a S-Max or do they need sensors in the tyres unlike the Focus/Kuga?Also to enable auto locking for a Mondeo/S-max is the procedure as follows :-- Read from IPC- Read from BCM- Select Central Configuration- Automatic Locking by speed - Select with automatic locking- Write to IPC- Write to BMCIs that correct?Or should it be done the following way?- Read from BCM- Select Central Configuration- Automatic Locking by speed - Select with automatic locking- Write to BCMThen- Read from IPC- Select Central Configuration- Automatic Locking by speed - Select with automatic locking- Write to IPCThanksBenEither way is fine.DDS? - highly unlikely. 1 Quote Link to comment Share on other sites More sharing options...
giwrgos_ath Posted November 2, 2013 Share Posted November 2, 2013 Guys, Is any of those software compatible with a MK7 Fiesta? Can you activate stuff like auto lock, dds etc? Can those be used to view diagnostics for a KA? Thanks 1 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted November 2, 2013 Share Posted November 2, 2013 The Fiesta MK7 is not supported by this software. As far as I know there is no software available for the Fiesta MK7 which has the same functionality as the ELMconfig software. This software should be able to read/erase DTC codes on a Ford Ka but in my opinion there is better software for diagnostics of a Ford Ka. One of the more advanced Ford specific software for diagnostics of most Ford models which works with the (modified) ELM327 interface is Forscan. Quote Link to comment Share on other sites More sharing options...
mayak Posted November 2, 2013 Share Posted November 2, 2013 Fiesta mk7 is supported by ADS (paid program and adapter) Quote Link to comment Share on other sites More sharing options...
JW1982 Posted November 3, 2013 Share Posted November 3, 2013 Is the ADS software currently translated to English? In the past I contacted the people who make ADS but at that time it was only available in Russian. Quote Link to comment Share on other sites More sharing options...
jpinhas Posted November 7, 2013 Share Posted November 7, 2013 Anyone know if it is already possible to reverse the delay instant consumption, caused by the upgrade Trip Computer for ROM 0509. Quote Link to comment Share on other sites More sharing options...
mayak Posted November 7, 2013 Share Posted November 7, 2013 no Quote Link to comment Share on other sites More sharing options...
liam-20 Posted November 9, 2013 Share Posted November 9, 2013 hey guys had the elm for a while now and my mates has asked me to activate his cruise control is there a how to any where as I don't wanna just click stuff as it aint my car cheers. liam Quote Link to comment Share on other sites More sharing options...
Preee Posted November 9, 2013 Author Share Posted November 9, 2013 has anyone got the link for ADS i have lost it and can't find it on google! Quote Link to comment Share on other sites More sharing options...
mayak Posted November 9, 2013 Share Posted November 9, 2013 http://ads-ford.ru/ - site http://ads.ipb.su/ - forum are you going to buy it? Quote Link to comment Share on other sites More sharing options...
Preee Posted November 9, 2013 Author Share Posted November 9, 2013 http://ads-ford.ru/ - site http://ads.ipb.su/ - forum are you going to buy it? I'm lookings at both programs , as i have been speaking to a Russian guy that has enabled the center screen on his Mk3 Focus to accept a standard PAL input for a reverse camera with out Ford's £600 worth of modues , and he said he flashed the screen via software , so i was checking if either UCDS or ADS was the program , but neither mention it. So i guess i will have to wait for him to respond with what he flashed the screen with. Thanks for the Links Mayak:) Quote Link to comment Share on other sites More sharing options...
liam-20 Posted November 10, 2013 Share Posted November 10, 2013 hey guys need sum quick help I can get accress to everything except the 3rd menu on the hec it just keep coming up with warning say frw.dat file missing had look in file and it is there am I doing anything wrong? Quote Link to comment Share on other sites More sharing options...
Preee Posted November 10, 2013 Author Share Posted November 10, 2013 Liam its the folder structure you must have it can't find the firmware file. if you go back a few pages on this guide i told Dezwez how to do it. Quote Link to comment Share on other sites More sharing options...
saklak Posted November 10, 2013 Share Posted November 10, 2013 Not sure if this is the right place but since is connected with Elm327 I'll go ahead :). Using Forscan and having all that live data ( dashboard ) how do you know which numbers are correct and which not ? are you watching for spikes or something ? Totally noob here ... Quote Link to comment Share on other sites More sharing options...
dezwez Posted November 10, 2013 Share Posted November 10, 2013 Liam its the folder structure you must have it can't find the firmware file. if you go back a few pages on this guide i told Dezwez how to do it.post is on page 108 at the botom Quote Link to comment Share on other sites More sharing options...
mayak Posted November 13, 2013 Share Posted November 13, 2013 latest version of ELMConfig (11c) supports Bosch PCMs in FF2, so 1.6 tdci and ST but it has beta status - has anyone tried to enable cruise control in 1.6 tdci ? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 13, 2013 Share Posted November 13, 2013 might need to give it a go! I havent tried it yet, I am still on v11a maybe b though... Same download location as the original post by Preee? Quote Link to comment Share on other sites More sharing options...
mayak Posted November 13, 2013 Share Posted November 13, 2013 there is no 11a - there was 11, 11b and 11c all 'elevens' are almost the same link as always: http://civil.iffc.ru/ELMConfig/ELMConfig.zip Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 13, 2013 Share Posted November 13, 2013 I guess its b I am using lol Quote Link to comment Share on other sites More sharing options...
clubber Posted November 13, 2013 Share Posted November 13, 2013 latest version of ELMConfig (11c) supports Bosch PCMs in FF2, so 1.6 tdci and ST but it has beta status - has anyone tried to enable cruise control in 1.6 tdci ? I've tried it on an ST but there is no READ/WRITE VID block in the Procedures>Page 2 so you can't write the modified PCMDump to the car See this post http://www.fordownersclub.com/forums/topic/30008-guide-fitting-cruise-control-focus-mk2-mk25-and-ford-c-max/?p=304791 Quote Link to comment Share on other sites More sharing options...
