Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
translating
2437 replies to this topic
#1621 dezwez
dezwez
    Dezwez
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 5,058 posts
  • Name: Derek
  • Ford Model: ford focus 1.8 zetec mk 2.5
Posted 05 October 2013 - 07:56 PM
Ok from your download , make a folder and extract al files from the original download into it , ELMConfig is searching for the data folder , so place both the data folder and the Elmconfig.exe in it's own folder together.
Ok done that and it come up with  a load of  vbf files  8 of them
Have something to contribute?
#1622 Preee
Preee
    Ford Fruitcake
  • 4,337 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3.5 | Fiesta Zetec Mk7
  • Year: 2015
Posted 05 October 2013 - 08:12 PM
Ok so you made a new folder , and inside that folder should be
elmconfig.exe
Data folder containing the .vbf files ,  frw.dat and code.dtc files
so when you open your new folder , it should have elmconfig.exe and data folder.
#1623 dezwez
dezwez
    Dezwez
  • PipPipPipPipPip
  • 5,058 posts
  • Name: Derek
Posted 05 October 2013 - 08:14 PM
elmconfig.exe
yes it does
#1624 Preee
Preee
    Ford Fruitcake
  • 4,337 posts
  • Name: Paul
  • Year: 2015
Posted 05 October 2013 - 08:15 PM
yes it does
Ok give that a try see if it solves the problem.
#1625 dezwez
dezwez
    Dezwez
  • PipPipPipPipPip
  • 5,058 posts
  • Name: Derek
Posted 05 October 2013 - 08:45 PM
ok will do thanks a lot :)
#1626 dezwez
dezwez
    Dezwez
  • PipPipPipPipPip
  • 5,058 posts
  • Name: Derek
Posted 05 October 2013 - 09:15 PM
ok now looks like this thanks very much preee
#1627 Preee
Preee
    Ford Fruitcake
  • 4,337 posts
  • Name: Paul
  • Year: 2015
Posted 05 October 2013 - 11:20 PM
No Problem Dezwez , glad it worked.
#1628 simmaren_1
simmaren_1
    Newbie
  • Budding Enthusiast
  • Pip
  • 7 posts
  • Name: Fredrik
  • Ford Model: Focus
  • Year: 2006
Posted 09 October 2013 - 07:59 AM
Hello,
When I finaly got the right elm327 (elm327 dongle #3...) with 500k speed, I read VID & firmware and tried to write it back to the PCM but then it said that my PCM is not supported!
I have the 5M51AG PCM number and the ECU-131.
Soon I will sell the car :(
/Fredrik
#1629 KevG
KevG
    Member
  • PipPip
  • 21 posts
  • Name: Kevin
  • Ford Model: Focus ST2
  • Year: 2007
Posted 12 October 2013 - 05:05 PM
Hi, Been reading about this on the FocusSToc.com, and bought the ELM and done the mod to it, downloaded the latest version of software V2.10c, I cannot seem to read/get information from the MS-CAN modules, they all come back with N/A and NO DATA, also tried the switch thinking it was that and I get a CAN ERROR, but I can read and access information etc from the HS-CAN modules, any ideas?
I want to program in a new(used) Bluetooth module with USB.
My ST2 is 2007 Pre-facelift with voice control
Any help would be grateful.
Kev
#1630 JW1982
JW1982
  • 788 posts
  • Name: Wilco
  • Ford Model: Focus MK3 Champions Edition
  • Year: 2013
Posted 12 October 2013 - 05:41 PM
The USB functionality does only work in combination with Focus MK2.5 Sony (produced after 08-2008) and Travelpilot (FX and NX) radio's. The Focus MK2 radio's uses the old Bluetooth/Voicecontrol system which has different wiring/modules and do not support the USB functionality.
If your car is equipped with the original radio and Bluetooth/Voicecontrol system your new module with USB functionality will not work.
Did you perform the "Setup adapter for MS-CAN bus" procedure of the ELMconfig program? This function can be found under "Adapter Setup" on the start screen of ELMconfig. If this does not solve your problem the problem is most likely caused by a bad switch or incorrect wiring.
#1631 KevG
KevG
    Member
  • PipPip
  • 21 posts
  • Name: Kevin
  • Year: 2007
Posted 12 October 2013 - 05:53 PM
Even though I have the Sony Gen2 "Oval Style" stereo as from the factory this will still not work?
#1632 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 17,769 posts
  • Name: Clive
  • Year: 2015
Posted 12 October 2013 - 06:30 PM
If it's the mock oval Gen2 then no, if it's the Gen3 then yes.
#1633 JW1982
JW1982
  • 788 posts
  • Name: Wilco
  • Year: 2013
Posted 12 October 2013 - 06:42 PM
No, most likely the USB functionality will not work. the oval shaped Sony radio's with red illumination which are fitted into the late Focus MK2 and early MK2.5 models are technically different than the later MK2.5 versions of this radio.
The older versions of the oval shaped Sony radio's uses the old Bluetooth/Voicecontrol system. This system has a Bluetooth/Voicecontrol module with part number 4M5T-19G488-AX or 7M5T-19G488-AX (the X can be any letter). This is a mono module which communicates the audio to a special Phone input of the radio.
  Old module versions do not have a USB connection at all and can not be updated.
After 04-2008 The Bluetooth/Voicecontrol system was changed. Another Bluetooth/Voicecontrol module was fitted with part number 8M5T-19G488-AX. This is a Stereo module which communicates the audio to the AUX input of the radio (this is not noticeable). The wiring of the AUX connection in the glove box is routed to the Bluetooth/Voicecontrol module before going to the radio.This type of module has an USB connection for firmware update purposes. When Ford released the USB functionality (about 08-2008) another type of Bluetooth/Voicecontrol module was introduced. The module with part number 8M5T-19C112-AX is based on the new Bluetooth/Voicecontrol system but has USB playback functionality, Ipod control and some later versions also suport Bluetooth/Audio.
I retrofitted the new MK2.5 Bluetooth/Voicecontrol system to my car after I fitted a 2011 6000CD Premium MP3 (from a S-max) to my Focus MK2. The system was fully functional but the 6000CD does not support USB so I bought an oval shaped Sony. Unfortunately the Sony was produced in 2007 and did not work with my MK2.5 Bluetooth/Voicecontrol system at all. For this reason I sold this radio and bought myself a 2009 Sony 6-CD DAB radio. The Sony DAB radio works great with the Bluetooth/Voicecontrol system and now I have the USB, A2DP and Bluetooth Audio functionality which is really great.
There is a simple check to determine if the radio will support USB or not. press and hold the1 & 6 button together. Now a serie of different hardware and software numbers will appear. Look for a number which looks like 05-03-03. For USB support the number has to start with a 5. If the number starts with a 4 the radio definitely  does not support USB.
#1634 KevG
KevG
    Member
  • PipPip
  • 21 posts
  • Name: Kevin
  • Year: 2007
Posted 12 October 2013 - 07:09 PM
Well, just checked and I done the check and low and behold, the 1st thing that came up was 04-04-14, so thats that then, look like a new stereo for Christmas, one that will do USB etc etc.
Thanks for the replies, where is the rep on this forum (...goes and for a look...)
#1635 SkinnyB
SkinnyB
  • 55 posts
  • Name: Simba
  • Ford Model: Zetec 1.6 Mk 2.5
Posted 12 October 2013 - 10:44 PM
Alright folks, some troubling news has just come to my attention :o , after months and months of searching for a bluetooth module with USB i finally managed to buy one yesterday (still waiting for it to be delivered)  for an acceptable amount but now after reading this
 i am a bit worried that my stereo does not support the USB function. I have done the check as mentioned above and when its cycling though all the numbers there are three which look like the firmware, 10-00-02 is the 1st then there is a date 25/07/2007 another number FB 07-02-08 then BL 02-04-05
can anyone confirm which number i need to be looking at or weather my stereo will support USB function or not
and if my stereo does not support USB which for me is becoming more and more likely is there not a way to update the software or firmware whatever it maybe?
btw i have the facelift focus on an 08 plate believe its the early version of the mk2.5's
Not what you're looking for?
4 user(s) are reading this topic
0 members, 4 guests, 0 anonymous users
