Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
translating
2387 replies to this topic
#1651 higgsy
higgsy
    Northern Yam Yam
  • 835 posts
  • Name: James
  • Ford Model: Focus Zetec S 1.6 TI-VCT
Posted 22 October 2013 - 12:39 PM
it don't work on mine no matter how long I set it  I think you cant set it
Nice one dezwez, if others are having the issue it must be a feature only available to some models.
Have something to contribute?
#1652 mayak
mayak
  • Budding Enthusiast
  • 72 posts
  • Name: Marcin
  • Ford Model: Focus mk 2
  • Year: 2007
Posted 22 October 2013 - 12:44 PM
according to author, it doesn't work at all
#1653 minimadgriff
minimadgriff
  • 48 posts
  • Name: Ben
  • Ford Model: Focus RS (The original) & Ford Kuga
  • Year: Non
Posted 29 October 2013 - 02:29 PM
Is it possible to enable DDS on a S-Max or do they need sensors in the tyres unlike the Focus/Kuga?
Also to enable auto locking for a Mondeo/S-max is the procedure as follows :-
- Read from IPC
- Read from BCM
- Select Central Configuration
- Automatic Locking by speed - Select with automatic locking
- Write to IPC
- Write to BMC
Is that correct?
Or should it be done the following way?
- Read from BCM
- Write to BCM
Then
- Read from IPC
- Write to IPC
Ben
#1654 fyl
fyl
  • Members via Twitter
  • 40 posts
  • Name: fyl
  • Ford Model: Focus 2.0 TDCi
  • Year: 2011
Posted 30 October 2013 - 02:30 AM
- Read from IPC
- Read from BCM
- Write to IPC
- Write to BMC
Is that correct?
- Read from BCM
- Write to BCM
Then
- Read from IPC
- Write to IPC
Ben
Not sure about the S-Max but I enabled DDS on my focus mk2.5 without any sensors in the wheel as DDS uses the ABS sensors (guessing Yaw/Pitch/wheel speed) to work. I had a recent flat and DDS issues a warning on the information cluster to check tyre pressure.
#1655 minimadgriff
minimadgriff
  • 48 posts
  • Name: Ben
  • Year: Non
Posted 30 October 2013 - 10:09 PM
On my Kuga I have too, but I am not sure about the S-max :( On the internet I can find listings for tyre pressure sensors.
#1656 747777
747777
  • 56 posts
  • Name: Chris
  • Ford Model: S-Max
  • Year: 2012
Posted 31 October 2013 - 12:01 AM
Is it possible to enable DDS on a S-Max or do they need sensors in the tyres unlike the Focus/Kuga?Also to enable auto locking for a Mondeo/S-max is the procedure as follows :-- Read from IPC- Read from BCM- Select Central Configuration- Automatic Locking by speed - Select with automatic locking- Write to IPC- Write to BMCIs that correct?Or should it be done the following way?- Read from BCM- Select Central Configuration- Automatic Locking by speed - Select with automatic locking- Write to BCMThen- Read from IPC- Select Central Configuration- Automatic Locking by speed - Select with automatic locking- Write to IPCThanksBen
Either way is fine.
DDS? - highly unlikely.
#1657 giwrgos_ath
giwrgos_ath
  • 152 posts
  • Name: George
  • Ford Model: Focus MK2.5
Posted 02 November 2013 - 05:55 PM
Guys,
Is any of those software compatible with a MK7 Fiesta? Can you activate stuff like auto lock, dds etc?
Can those be used to view diagnostics for a KA?
#1658 JW1982
JW1982
  • True Ford Enthusiast
  • 685 posts
  • Name: Wilco
  • Ford Model: Focus MK3 Champions Edition
  • Year: 2013
Posted 02 November 2013 - 07:02 PM
The Fiesta MK7 is not supported by this software. As far as I know there is no software available for the Fiesta MK7 which has the same functionality as the ELMconfig software.
This software should be able to read/erase DTC codes on a Ford Ka but in my opinion there is better software for diagnostics of a Ford Ka. One of the more advanced Ford specific software for diagnostics of most Ford models which works with the (modified) ELM327 interface is Forscan.
#1659 mayak
mayak
  • 72 posts
  • Name: Marcin
  • Year: 2007
Posted 02 November 2013 - 08:18 PM
Fiesta mk7 is supported by ADS (paid program and adapter)
#1660 JW1982
JW1982
  • 685 posts
  • Name: Wilco
  • Year: 2013
Posted 03 November 2013 - 06:37 AM
Is the ADS software currently translated to English?  In the past I contacted the people who make ADS but at that time it was only available in Russian.
#1661 jpinhas
jpinhas
    Member
  • PipPip
  • 11 posts
  • Ford Model: Focus 1.6 TDCI
Posted 07 November 2013 - 12:00 PM
Anyone know if it is already possible to reverse the delay instant consumption, caused by the upgrade Trip Computer for ROM 0509.
#1662 mayak
mayak
  • 72 posts
  • Name: Marcin
  • Year: 2007
Posted 07 November 2013 - 12:18 PM
no
#1663 liam-20
liam-20
  • 149 posts
  • Name: liam
  • Ford Model: focus st3
Posted 09 November 2013 - 04:50 PM
hey guys had the elm for a while now and my mates has asked me to activate his cruise control is there a how to any where as I don't wanna just click stuff as it aint my car cheers. liam
#1664 Preee
Preee
    Ford Fruitcake
  • 4,099 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3 | Fiesta Zetec Mk7
  • Year: 2012
Posted 09 November 2013 - 05:58 PM
has anyone got the link for ADS i have lost it and can't find it on google!
#1665 mayak
mayak
  • 72 posts
  • Name: Marcin
  • Year: 2007
Posted 09 November 2013 - 09:26 PM
http://ads-ford.ru/ - site
http://ads.ipb.su/ - forum
are you going to buy it?
Not what you're looking for?
4 user(s) are reading this topic
0 members, 4 guests, 0 anonymous users
