Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
translating
2459 replies to this topic
#1801 Zurrieq
Zurrieq
  • Budding Enthusiast
  • 118 posts
  • Name: Stephen
  • Ford Model: Fiesta
  • Year: 2006
Posted 07 January 2014 - 06:00 AM
Hi Bjoras. What programs did you use for PATS? Any links. Thanks
Have something to contribute?
#1802 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 21,264 posts
  • Name: James
  • Year: 2007
Posted 07 January 2014 - 12:15 PM
I think you should be fine, as long as you are using a modern PC and have a recommended part (most of the guys here who modded their own have linked to which they used).
As long as you dont use an old and cacky laptop, you should be alright!
#1803 bjoras
bjoras
    Member
  • PipPip
  • 20 posts
  • Name: Bjørn
  • Ford Model: Focus 1.6 tdci titanium
Posted 07 January 2014 - 06:38 PM
You get an old version of FoCom (1.0.7575) delivered with an OBD device, which I don't think is based on the elm-chip.
http://www.aliexpres.../520147838.html
The software works quite well for my car, which is a 2010 model. It detects the most important ECU's, but not as many as ELMConfig. There are some actuator tests which I've tried, but I have only tested the PATS functions of the advanced part of the software. So far the unit works as claimed by the seller.
You'll need in-codes to get access to the PATS-system. These you can buy at http://www.patscode.com/en/index. I think you can get 10 keys for a reasonable price, but If you make to many errors and you need more codes, you'll have to pay a lot of money to log into the car you actually own. In the long run, if you need to log in again, it will be cheaper to buy a so called password calculator. I bought this one: http://www.aliexpres.../512017798.html. Seems to work quite well. You'll get an usb dongle which contains 2000 tokens (in-codes). The calculator software doesn't work without it. Every time you use an in-code, the number of tokens in the dongle will decrease by one.
You'll find manuals at http://www.obdtester.com/downloads, but keep in mind that those are for the current versions of FoCom.
Don't expect this cheap chinese copy of the real FoCom product to be bug-free. Also, there's no support. You're on your own if something bad happens!
The flip-key I bought from http://stores.ebay.com/pandkeys/. A local auto locksmith didn't have this key, but he had the equipment to copy my old key to the fresh blade of the new one. He also had the equipment to clone the transponder in the key, but then I think you'll need an empty transponder. The blade was a little bit too thick, but the locksmith managed to fix it. You can get the job done for a small amount of money, if you find the right guy. Follow your cars manual to program the remote keyless entry functions! Use FoCom to register the (not empty) transponder chip into PATS!
You pay for the key, FoCom device, the locksmith and the in-code calculator. You get some fun tools :P and a working key for a price much lower then an original key at a Ford dealer.
Hope this helps you out :) Stephen!
#1804 bjoras
bjoras
    Member
  • PipPip
  • 20 posts
  • Name: Bjørn
Posted 07 January 2014 - 06:56 PM
I guess you're right :huh: It's too exciting to do things like that on your own :P, but I know I will be sweating :unsure: I'll look after one of those links.
Thanks James!
#1805 ovideatza
ovideatza
    Member
  • PipPip
  • 13 posts
  • Name: Ovidiu
  • Ford Model: Focus
Posted 07 January 2014 - 07:22 PM
Hello again guys!
I'm having a problem with my ELM327 and I cannot manage to find out why.
I posted on the russian forum, but no answer yet:
http://ffclub.ru/top..._post/15014740/
Can you help me?
Could I need a hard reset of the ELM? All other programs are working fine, only ELMConfig is not working.
Thank you.
Also, few months ago, when I tried to enable the alarm, it said on the screen "open hood" or something like that. The car it's a Titanium. I checked the wiring, I have wires to the front hood lock, is it possible to have the wires going to the lock but the lock not to have pins inside? Can I check this without taking out from the car de lock?
PS: on civil's ftp there is a incode-outcode calculator, in the folder called "New Folder", maybe it is a free program for this. Anyone knows something about this? Too bad that he didn't made possible to program key's with ELMConfig.
#1806 mayak
mayak
  • 72 posts
  • Name: Marcin
  • Ford Model: Focus mk 2
  • Year: 2007
Posted 08 January 2014 - 08:50 AM
look here: http://forum.fordclu...417&postcount=6 there are pictures how to add additional wire to hood lock
(pictures are taken from tutorial from http://www.ford-focu...92f6f52670869e8
#1807 james_60
james_60
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,022 posts
  • Name: Jamie
  • Ford Model: 2013 Focus Titanium X 1.6TDCI 115BHP
  • Year: 2013
Posted 08 January 2014 - 12:28 PM
Thats a no then :-( foci mk3 been out since 2011 :-(
Jamie
#1808 Danwel
Danwel
  • 147 posts
  • Name: Daniel
  • Ford Model: Focus TDCI
  • Year: 2007
Posted 08 January 2014 - 04:05 PM
Just ordered my cable off dezwez to arrive all done and soldered ready for use as i don't have the equipent to solder it myself so don't mind paying an extra few quid for someones time and effort.
Currently on page 25 of this thread but am i right in saying once i have checked the AS BUILT program it will tell me what my car has and doesn't have?? After this i am able to download the software and begin to tweak things?
#1809 ovideatza
ovideatza
    Member
  • PipPip
  • 13 posts
  • Name: Ovidiu
  • Ford Model: Focus
Posted 08 January 2014 - 04:23 PM
so, there is this possibility to have wires but no pin inside.
thank you for the link, I will use it when I get my ELMConfig working again...I keep getting "Error reading COM device". ForScan or other software works with my ELM327, even ELMConfig worked before..
in ELMConfig you just read module and you will have thicked all your default car configuration. After that you can make modification as you like, depending on what your car support. AS BUILT is needed when you have problems and you want to go back to default configuration and you don't know it. As an advice, be sure to save each page from ELMConfig read from the car on your laptop prior doing any modification.
#1810 Danwel
Danwel
  • 147 posts
  • Name: Daniel
  • Year: 2007
Posted 08 January 2014 - 05:35 PM
Thanks for that looking forward to getting started
#1811 bjoras
bjoras
    Member
  • PipPip
  • 20 posts
  • Name: Bjørn
Posted 08 January 2014 - 06:42 PM
I cannot find that folder at his site. Anyway, if the program is named "FordIncodeCalculator.exe", I guess it's just a copy of the calculator I mentioned above. It's easy to find this program on Internet, but it wouldn't work without the dongle. I suggest you buy the calculator and a FoCom device.
It wouldn't help that much, if Civil included the PATS module. Still you need the in-code to log in to the module.
#1812 bjoras
bjoras
    Member
  • PipPip
  • 20 posts
  • Name: Bjørn
Posted 08 January 2014 - 06:59 PM
Then I would guess the hardware is ok. What about your COM-port settings in ELMConfig? What about the RuntimePack? Have you changed any settings recently? You could eventually test it on another computer.
#1813 dezwez
dezwez
    Dezwez
  • PipPipPipPipPip
  • 5,392 posts
  • Name: Derek
  • Ford Model: ford focus 1.8 zetec mk 2.5
Posted 08 January 2014 - 07:16 PM
you can down load the software now from that link I sent you
you can view it in off line mode
#1814 Danwel
Danwel
  • 147 posts
  • Name: Daniel
  • Year: 2007
Posted 08 January 2014 - 07:21 PM
you can down load the software now from that link I sent youyou can view it in off line mode
Can't seem to find the link mate, is it my email to sent it to or via pm?
#1815 dezwez
dezwez
    Dezwez
  • PipPipPipPipPip
  • 5,392 posts
  • Name: Derek
Posted 08 January 2014 - 07:34 PM
hers the link
http://civil.iffc.ru/ELMConfig/
go to this site and download elmconfig zip to you desktop
when there unzip it to a new folder on your desktop
copy both files in the download to this folder you need both to make it work
when it starts you can view in off line mode
Not what you're looking for?
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
