Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
translating
2292 replies to this topic
#2041 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,260 posts
  • Name: James
  • Year: 2007
Posted 17 June 2014 - 09:18 PM
nope, as long as there is HS and MS thats all that matters, no point in having an off switch.
Have something to contribute?
#2042 troy45
troy45
  • 961 posts
  • Name: Troy
  • Ford Model: Focus ST
Posted 17 June 2014 - 09:52 PM
That's great, cheers :)
Have now fired up the soldering iron and dived in without quite reading the info properly first time :rolleyes:
#2043 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,260 posts
  • Name: James
  • Year: 2007
Posted 17 June 2014 - 10:04 PM
haha, good luck then, you might find you need to do a bit of solder - desolder if you jump too quick but good luck with it and hopefully you can get all the benefits from it! :)
#2044 troy45
troy45
  • 961 posts
  • Name: Troy
Posted 17 June 2014 - 11:25 PM
Got there ok eventually, just a bit of juggling act having enough length in the switch wires to work with but then also get the box back together.
Maybe get it onto the car tomorrow depending on time :)
#2045 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,260 posts
  • Name: James
  • Year: 2007
Posted 18 June 2014 - 12:24 PM
good result! was it an electric or butane iron you used?
#2046 troy45
troy45
  • 961 posts
  • Name: Troy
Posted 18 June 2014 - 06:39 PM
Plain old electric soldering iron, nothing fancy but it does the job, has served me well for years :)
Did have a butane one but just couldn't get it to work.
#2047 troy45
troy45
  • 961 posts
  • Name: Troy
Posted 19 June 2014 - 05:23 PM
Had a crack at using my modified ELM327 on the car today.
Didn't go completely smooth, seemed to get some No Data issues and MS-can not working - double checked all the connections were wired right and with a bit more digging I found I had to take baud rate off auto detect before it would let me set the unit for MS-can but got there eventually.
Will take me a bit of time to find out what is useful to alter. So far I've got ESP option activated on the cluster menu, Driveaway locking, enabled approach/puddle lights to see if I can get power from this at the mirror connection. Found in the ACM menu that my car was set up for fabric interior so updated that and I set Radio info enabled on the cluster which doesn't seem to do anything?
Also somehow now the car beeps like crazy when it's in reverse, will be turning that one off pronto :rolleyes:
Anyone know how the puddle lights usually operate so I can do some voltage checks?
Cheers
#2048 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,260 posts
  • Name: James
  • Year: 2007
Posted 19 June 2014 - 05:54 PM
Puddle lights are active after unlock and until auto relock I believe, radio info requires the right firmware on the mk2.5 cluster.
Sent from my MY SAGA C2 using Ford OC mobile app
#2049 troy45
troy45
  • 961 posts
  • Name: Troy
Posted 19 June 2014 - 06:10 PM
Thanks for the info there - I'll pull some trim off tonight then and check some voltages for the mirrors, plus see what firmware the software says I have on my cluster.
Just reading up now on the firmware update :)
#2050 troy45
troy45
  • 961 posts
  • Name: Troy
Posted 20 June 2014 - 08:44 PM
Being lazy I've not looked up what the Focus RS setting on the HEC? does.
I assume it doesn't turn my car green and take some horsepower off it?
:P
#2051 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,260 posts
  • Name: James
  • Year: 2007
Posted 20 June 2014 - 08:52 PM
nah it just disables the innappropriate options for the RS...
#2052 Sarge
Sarge
    Newbie
  • Budding Enthusiast
  • Pip
  • 3 posts
  • Name: Gary
  • Ford Model: Focus C-Max Ghia 1.8tdci
  • Year: 2006
Posted 22 June 2014 - 08:10 PM
I have started to remove the hated EPB from my 2006 C-Max Ghia, starting with the interior console and working to the outside later, and a few days ago I "took the plunge" and having bought a ready-modified Elm cable I went into the car menus, followed the advice on here and unticked the EPB boxes. All went well and thankfully I no longer have the persistent messages on the dash display advising of total EPB failure but have I removed everything I should have? I still have the electric switch connected and if I remove the key from the ignition without remembering to hold the switch down the EPB starts to operate automatically. Can this "auto application" be removed using the Elm, or will it need different software?
Have to say, all the advice on here has been brilliant and a great help. I would never have thought of attempting anything like this in the past, so much respect to all involved!! :)
#2053 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,260 posts
  • Name: James
  • Year: 2007
Posted 22 June 2014 - 08:51 PM
not sure that you can disable it altogether with elm, you need to remove it from the HEC, GEM and probably the ECU.
#2054 Sarge
Sarge
    Newbie
  • Pip
  • 3 posts
  • Name: Gary
  • Year: 2006
Posted 24 June 2014 - 11:57 PM
Ok, thanks for that jeebowhite, appreciate it.
#2055 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,260 posts
  • Name: James
  • Year: 2007
Posted 25 June 2014 - 10:35 AM
no problem, good luck and do let us know if it works!
Not what you're looking for?
6 user(s) are reading this topic
1 members, 5 guests, 0 anonymous users
