Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
translating
2437 replies to this topic
#601 liam-20
liam-20
  • Budding Enthusiast
  • 149 posts
  • Name: liam
  • Ford Model: focus st3
Posted 15 September 2012 - 09:39 PM
ive just done the update cant really see any changes whats this pats?
Have something to contribute?
#602 Preee
Preee
    Ford Fruitcake
  • 4,341 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3.5 | Fiesta Zetec Mk7
  • Year: 2015
Posted 15 September 2012 - 09:48 PM
Passive anti theft system. i'm sure updating would not have touched it as it would just be updating the Rom data and not the config , and as you have already updated .
With Rom 509 if you turn Eco mode on and shift light then , the Shift light should show green at 2000rpm to tell you to change gear Economically
#603 JW1982
JW1982
  • True Ford Enthusiast
  • 789 posts
  • Name: Wilco
  • Ford Model: Focus MK3 Champions Edition
  • Year: 2013
Posted 16 September 2012 - 06:22 AM
The firmware update only erases and writes the data on the flash memory of the instrument cluster. The PATS data is stored in the EEPROM of the instrument cluster. the EEPROM remains untouched during the update. So after the update the PATS doesn't need reprogramming.
#604 Nitemare
Nitemare
    Member
  • New Member
  • PipPip
  • 18 posts
  • Ford Model: Focus RS
Posted 16 September 2012 - 11:42 AM
Updated ROM using updated software. Thanks.
Nitemare. ;)
#605 .Ryan
.Ryan
  • 750 posts
  • Name: Rhino
  • Ford Model: Focus Zetec S
  • Year: 2009
Posted 16 September 2012 - 12:08 PM
Kindly Liam was going to do this upgrade for me today but work got in the way of me going to the Blackpool Ford Show, interesting to see what this upgrade does, pretty clever stuff!
#606 mrmetallica
mrmetallica
  • 372 posts
  • Name: john
  • Ford Model: focus titanium 1.6
  • Year: 2009
Posted 16 September 2012 - 12:34 PM
You can download new version of ELMconfig from HERE.
For connecting a instrument cluster on the kitchen table like i do you have to connect the 12 volt positive and negative wires from a 12 volt DC source to the correct pins of both the ELM327 and the instrument cluster. You must also connect the HS-CAN wires between the ELM327 and the correct pins of the instrument cluster. I have made a set of adapter cables from scrap car connectors. With thes cables i can connect several modules (instrument cluster, radio, etcetera).
For connecting the instrument cluster you have to connect the following pins.
Pin 4 = 12 volt positive
Pin 6 = 12 volt negative
Pin 17 = HS-CAN negative
Pin 18 = HS-CAN positive
do you connect to the wires inside the box or the diagnostic end ?
#607 boylin
boylin
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Ford Model: Ford KA
Posted 16 September 2012 - 03:23 PM
how do you update the ROM to get the eco light?
found it, HEC > Procedures > Page 2
#608 Teabags
Teabags
  • New Member
  • 50 posts
  • Name: DB
  • Ford Model: Focus ST
  • Year: 2009
Posted 16 September 2012 - 05:48 PM
Does ELMconfig update do any other new stuff?
#609 JW1982
JW1982
  • 789 posts
  • Name: Wilco
  • Year: 2013
Posted 16 September 2012 - 06:14 PM
I am using a OBD2 connector and a instrument cluster connector from a scrap Focus MK2. I have connected the right pins (positive, negative and HS-CAN) of these connectors with each other and connected a external 12 volt power source to the positive and negative wires.
This way i can connect the instrument cluster connector to the instrument cluster and the ELM327 to the OBD2 connector. When i put 12 volt power on the positive and negative wires the instrument cluster display lights up and the instrument cluster can be fully diagnosed with ELMconfig.
#610 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 17,811 posts
  • Name: Clive
  • Year: 2015
Posted 16 September 2012 - 06:34 PM
Very handy indeed.
#611 Richiemac
Richiemac
  • 194 posts
  • Name: Richard
  • Ford Model: Focus 2014 1.6 tdci + S max 2011
  • Year: 2014
Posted 16 September 2012 - 09:30 PM
OK, so did the update earlier and now have ECOmode in my menu....shift,anticipation and speed are there but doesn't seem to do very much ? No shift light either ? Missing something or maybe need PCM update too ?........
#612 Preee
Preee
    Ford Fruitcake
  • 4,341 posts
  • Name: Paul
  • Year: 2015
Posted 16 September 2012 - 09:42 PM
When you switch ignoring on do you see the green arrow ?
#613 Richiemac
Richiemac
  • 194 posts
  • Name: Richard
  • Year: 2014
Posted 16 September 2012 - 10:09 PM
Just checked and no green arrow at ignition on.......?
#614 nuno8210
nuno8210
  • 49 posts
  • Ford Model: Focus
Posted 17 September 2012 - 09:35 AM
I have a 2008 Focus 2.0 TDci so I have no Eco-mode nor eco shift light. When I turn the ignition on the up arrow only lights in red and 2010 Focus lights both in red and green.
Does this update to the HEC works in my car? Will the Eco-mode work also on 2.0TDci? As far as I remebed, here in Portugal, there where only 1.6 TDci Econetic that had the Eco-mode. I already activated the Eco-mode on 2010 1.6 TDci that were no Econetic but will it work on 2.0 TDci?
I would love to have the eco-mode and the shift up light on my car but I only will update when I am 100% that the upgrade will not brick my car as I need it to work!
Regards.
#615 Richiemac
Richiemac
  • 194 posts
  • Name: Richard
  • Year: 2014
Posted 17 September 2012 - 10:08 AM
Ok, did the self test and i don't have the green arrow in my display....so that explains that i guess ? Eco mode is working though, as my flower petals are starting increase :)
Not what you're looking for?
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
