Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
#1126
Posted 01 February 2013 - 01:09 AM
#1127
Posted 01 February 2013 - 01:13 AM
#1128
Posted 01 February 2013 - 11:33 AM
Best regards,
Brian
#1129
Posted 01 February 2013 - 08:47 PM
#1130
Posted 01 February 2013 - 09:06 PM
Does this software/cable work with a Mondeo 2012 model (Mk4?)?
Best regards,
Brian
Brian it does show this as mk 4 , but at the moment it's not fully translated into English , so you will have some translating to do
Good work at least you solved the problem quicklyJust modified my cable went to send the request to set it up with elmconfig but got response - "correct response from ELM timed. Received response to request "AT WS"". Took it apart and I had a bad solder so resoldered it and all working ok.
#1131
Posted 04 February 2013 - 07:52 PM
#1132
Posted 11 February 2013 - 12:12 PM
Great
I'll check my tyres tonight and see how many PSI's I've lost in order to generate the warning.
Update of update: So on checking they were down around 10 PSI - admittedly I haven't checked them for a while in the hope the sensor would pick up the air loss and the error message would be displayed. Just goes to prove it does work by enabling using this guide.
My wheels are 18's which I run at 33 PSI
Stu
#1133
Posted 13 February 2013 - 09:04 AM
I own a ff mk2 2.0 TDCI 05'. I have been using this software and it's great but i have a little problem. When I want to change delays (for autolock, courtesy light, etc...) i keep getting an error.
Any ideas?
Tnx, Menzy
#1134
Posted 15 February 2013 - 05:52 AM
#1135
Posted 15 February 2013 - 10:12 AM
#1136
Posted 15 February 2013 - 06:07 PM
Thanks for all the help this thread has been awesome.
#1137
Posted 17 February 2013 - 09:50 AM
I have a mk2.5 focus titanium. Do I have the hardware to use this software to enable:
1) auto door lock
2) auto heated screen on low temp
3) tyre pressure monitoring
Also, on doing a gauge test, I can see I have a up arrow but no down arrow. Is this Eco mode/gear advice? If so, does it work on the 2008 onwards titanium a?
Apologies if it sheen asked - I'm only on page 10 of 76 and got overexcited!
#1138
Posted 17 February 2013 - 10:52 AM
Well this is all clearly bonkers, but something I'd love to try.
1) auto door lock
Yes this should work fine on your car
1) Yes
2) Yes
3) some times this works , but some reports that it has not worked
There is only an "up" arrow for gear shift Eco , but your Firmware for the clocks must also be updated to version 509
#1139
Posted 22 February 2013 - 03:22 PM
In my country we have a FordClub, with upgrades and tehnical stuff, but this topic is really interesting. I want to thank you all for your effort.
After reading all this pages, i bought an elm327, cheap one. After half a day work, I managed to install on Win7 64bit. It now connect to my car when using some programs included in the box. But when i try to connect using ELMConfig, latest version from Civill, I get this error:
Any ideea? have allready changed port speed, between 9.600 and 38.400, no chance. Also, i used comm 3, comm 2, comm 31...the same error. When I use ELM-FF2, when i press the button translated to "Read car info", I get a popp-up (i only understandt HCAN there) after that nothing...in the black screen something that I don't underdstand, and no chance to thick something on/off, everything remains faded..
#1140
Posted 22 February 2013 - 05:02 PM
Hy guys. I'm not from Uk, so please forgive my english.
After reading all this pages, i bought an elm327, cheap one. After half a day word, I managed to install on Win7 64bit. It now connect to my car when using some programs included in the box. But when i try to connect using ELMConfig, latest version from Civill, I get this error:
This does look like a Comm port problem , Comm port has to be below 10 , maybe comm 3 and 2 are causing conflicts , an un-modified cable will only read from HEC
3 user(s) are reading this topic
0 members, 3 guests, 0 anonymous users
