Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
translating
2319 replies to this topic
#1276 Jarda
Jarda
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Name: Jarda
  • Ford Model: Focus
Posted 19 April 2013 - 01:00 PM
Have nothing to do with the ROM, has to do with going to page 3 of the HEC.
When i  load  the configuration on page 3 of the HEC appears a warning that can cause delayed on instant consumption, and I ignored. I think it is not only the immediate consumption, I also think that confuses autonomy and reserve warning light.
To: jpinhas
Hi.
Have you solved your problem with instant consumption? I have similar problem, so I would welcome assistance with it.
Have something to contribute?
#1277 mayak
mayak
  • Budding Enthusiast
  • 72 posts
  • Name: Marcin
  • Ford Model: Focus mk 2
  • Year: 2007
Posted 19 April 2013 - 01:06 PM
Busy using it already.....arrived yesterday. So far so good !
Literally, what more can configure this program in Focus2 comparing to ELMConfig? I know it can adjust millage and flash PCM so it means that UCDS can enable cruise control in FF2. Anything more?
In S-Max - are there more options in car central configuration in BCM in comparision to ELMConfig? Are there any configuration options in IPC (instrument cluster)? Have you tried to enable displaying instant fuel consumption in your (old) analogue cluster?
Thanks Richard! :)
#1278 vince_13
vince_13
    Vince
  • True Ford Enthusiast
  • 542 posts
  • Name: Andrew
  • Ford Model: Focus Zetec
  • Year: 2009
Posted 19 April 2013 - 04:24 PM
hi pree
just plugged in my elm cable and worked as it should, i tested a few things like washer fluid level etc and it writes and reads :)
however i couldnt acess any other tabs but as your guide says the cable needs modding which will be next
cheers again
#1279 Preee
Preee
    Ford Fruitcake
  • 4,099 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3 | Fiesta Zetec Mk7
  • Year: 2012
Posted 19 April 2013 - 05:57 PM
hi pree
cheers again
Good News Andrew , does the washer level work? , it never did on my old car as the sensor was not present even though it was a Titanium.
Modding the cable will open up the rest of the options , just remember to Do the BACKUPS , it's a must :)
#1280 jpinhas
jpinhas
    Member
  • PipPip
  • 11 posts
  • Ford Model: Focus 1.6 TDCI
Posted 19 April 2013 - 08:17 PM
To: jpinhas
Hi.
No, still the same. I do not know how to solve the problem.
#1281 vince_13
vince_13
    Vince
  • 542 posts
  • Name: Andrew
  • Year: 2009
Posted 20 April 2013 - 08:20 AM
the warning came up on the dash yes but wouldnt go away (as i dont have the sensor fitted)
when you say backups is that the AS-Built do i generate an as-built?
if i wanted to re-install the backup i presume i would click input as-built?
some options like the phone details and RDS i dont think will show up because i dont have the bigger LCD screen that correct?
wont be modding the cable today as bought the wrong switch, bought dpst not dpdt :angry:
#1282 laurashgeo
laurashgeo
    Member
  • PipPip
  • 10 posts
  • Name: George
  • Ford Model: Focus 2.5
  • Year: 2011
Posted 20 April 2013 - 11:06 AM
I received the second diagnosis and it is working :D
I manage to add the switchers and I now I have Eco Mode, DDS, Radio and Auto-locking.
I will put some photos to see that the interior is completely different to the the one from the tutorial: the leds are smd and the pins are in another order.
I activated also the double locking, but is not working!
#1283 Preee
Preee
    Ford Fruitcake
  • 4,099 posts
  • Name: Paul
  • Year: 2012
Posted 20 April 2013 - 11:13 AM
Bottom of each page gives you the option to load each page settings. Also you will see a save option this is to save your default settings do it for every page and keep safe in case you nwed to restore your settings to default.
The phone and radio might show the larger screen is only for the satnav
#1284 mrmetallica
mrmetallica
  • 302 posts
  • Name: john
  • Ford Model: focus titanium 1.6
  • Year: 2009
Posted 20 April 2013 - 11:28 AM
mines small screen and shows radio and phone .
 laurashgeo why two switches on yours ?
#1285 laurashgeo
laurashgeo
    Member
  • PipPip
  • 10 posts
  • Name: George
  • Year: 2011
Posted 20 April 2013 - 11:54 AM
I fallowed the tutorial from the first page. Than I saw that there are double switcher on the market.
#1286 vince_13
vince_13
    Vince
  • 542 posts
  • Name: Andrew
  • Year: 2009
Posted 20 April 2013 - 12:28 PM
wow cheers guys will activate it then and see what appears,
as ive changed my headunit will it still display radio and phone? if so what info does it display?
those 2 switches looks like spst
#1287 Preee
Preee
    Ford Fruitcake
  • 4,099 posts
  • Name: Paul
  • Year: 2012
Posted 20 April 2013 - 12:36 PM
It does not display that much information , TBH , it displays cd track number , radio station name and phone displays incoming call but not caller name but it's still good :)
#1288 Jarda
Jarda
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Name: Jarda
  • Ford Model: Focus
Posted 20 April 2013 - 04:28 PM
Hi, jpinhas.
I have bad news. :-(
Yesterday I wrote question to civil-zz, who is author of ELMConfig and he answered me, that no way how to repair our problem at current moment. He doesn´t know, if it will be posible in some future release of ElmConfig, because he doesn´t know why such effect appears.
Did you upgrade FW to 0509 after first access to 3th page of Configuration/HEC or before it?
I still have FW 0508 now, so I don´t know, if I should try upgrade to FW 0509.
Do you think, that it would help me?
Thanks.
#1289 jpinhas
jpinhas
    Member
  • PipPip
  • 11 posts
Posted 20 April 2013 - 05:28 PM
Hi, jpinhas.
Thanks.
I accessed the page to backup before upgrading to the ROM 509, do not know if it was then or after that caused the error.
I think the problem is only caused by the access to page, the problem is not in having the ROM 508, 509 or otherwise.
#1290 JW1982
JW1982
  • 613 posts
  • Name: Wilco
  • Ford Model: Focus MK3 Champions Edition
  • Year: 2013
Posted 21 April 2013 - 07:04 AM
Radio and Phone info will only be shown if you have fitted an original Ford Radio which supports these options. For the Focus only the MK2.5 oval shape radio's do support Radio and Phone info. The square shape radio's from the MK2 do not support Radio and Phone info.
Not what you're looking for?
7 user(s) are reading this topic
1 members, 6 guests, 0 anonymous users
