Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
translating
2410 replies to this topic
#1411 clubber
clubber
  • Budding Enthusiast
  • 109 posts
  • Ford Model: ST3
Posted 21 July 2013 - 02:11 PM
Has anyone worked out how to use FDS?
Have something to contribute?
#1412 mrmetallica
mrmetallica
  • 348 posts
  • Name: john
  • Ford Model: focus titanium 1.6
  • Year: 2009
Posted 21 July 2013 - 04:43 PM
whats fds
#1413 minimadgriff
minimadgriff
  • 48 posts
  • Name: Ben
  • Ford Model: Focus RS (The original) & Ford Kuga
  • Year: Non
Posted 21 July 2013 - 08:40 PM
Pree,
I tried the odd ELM327 today (unmodified), It would bring up the HEC info but not configuration information as it said it needed to be set at a speed of 50000 but it wouldn't let me set it to this?
It read the following info
plus it read the VIN.
When I selected MS-CAN it would just do the following,
#1414 Preee
Preee
    Ford Fruitcake
  • 4,161 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3 | Fiesta Zetec Mk7
  • Year: 2012
Posted 22 July 2013 - 01:41 AM
Seems like it probably would not work even if you did modifiy it. One for the car boot sqle me thonks :)
#1415 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 22 July 2013 - 09:11 AM
whats fds
It's another configuration program, similar to ELMconfig, it's in the 1st post
#1416 mrmetallica
mrmetallica
  • 348 posts
  • Name: john
  • Year: 2009
Posted 22 July 2013 - 09:45 AM
ah forgot about that.it just the same as elm ,but i think it had problems.
#1417 minimadgriff
minimadgriff
  • 48 posts
  • Name: Ben
  • Year: Non
Posted 22 July 2013 - 10:09 AM
I will just keep this one for diagnostics and mod the other one I have.
#1418 Preee
Preee
    Ford Fruitcake
  • 4,161 posts
  • Name: Paul
  • Year: 2012
Posted 22 July 2013 - 03:12 PM
Good idea , at least you know you have a "Real Fake" ELM :)
#1419 LordSnick
LordSnick
    Newbie
  • Members via FB
  • Pip
  • 4 posts
  • Name: Svein
  • Ford Model: Mondeo Titanium X Sport
Posted 23 July 2013 - 10:23 PM
Finnaly i got my usb elm today, modified it. And now i got autolocking doors. Since i have a Mondeo, I had to write the CCD to both modules, the ipc and bcm. :D
Last time i could only write to the bcm module with the bluetooht adapter i had. Can't get the other things to work tough. One funny thing is that the original config for CCD in my car states that i don't have "home lights". I have 30 sec as standard on my car, but it wont let me config it so i can turn i off or change it to 60 sec. :huh:
#1420 Hodge725
Hodge725
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Name: Andrew
  • Ford Model: Focus
  • Year: 2005
Posted 24 July 2013 - 06:01 PM
I am wondering if there is anywhere I can purchase, an already modified elm327 USB device.
#1421 minimadgriff
minimadgriff
  • 48 posts
  • Name: Ben
  • Year: Non
Posted 24 July 2013 - 07:32 PM
With my other ELM I purchased I now have it all working and enabled things that my expensive IDS/VCM will not!
#1422 mrmetallica
mrmetallica
  • 348 posts
  • Name: john
  • Year: 2009
Posted 24 July 2013 - 07:40 PM
any one know why this happens and why the elm cant run at that speed ?
#1423 giwrgos_ath
giwrgos_ath
  • 152 posts
  • Name: George
  • Ford Model: Focus MK2.5
Posted 24 July 2013 - 08:42 PM
guys, i recently finished modifing the elm, however i run into trouble. When i connect the cable to the car, none of the programs work. I've followed my checklist, however i receive a "CAN ERROR".
* I've installed the drivers on the computer including the RuntimePack.
* I've set the port to COM1 (Speed 38400)
* I've been using this port and speed in all programs (ELMConfig, ELM-FF2_EN, FDS)
* I've connected the cable to different usb ports
* I've tried all three available states on the switch.
Any suggestions or instructions would be much helpful.
Also, i am still a bit confused overall. My questions are as following:
1. Why do we need the switch? What is the use of each state?
2. Which program should i use in order to read the configuration of the car and make alterations? (ELMConfig, ELM-FF2_EN, FDS)
3. Do i need to follow the instructions for Putty before the programs in order to establish a connection with the car?
Thank you in advance.
#1424 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,328 posts
  • Name: James
  • Year: 2007
Posted 25 July 2013 - 08:01 AM
CAN error is a communication error on the car I believe... Sounds like it doesnt want to talk!
Is there not an OBDII port in the engine bay that you can try and communicate with? eliminate the possibility that its the drivers one being duff?
#1425 giwrgos_ath
giwrgos_ath
  • 152 posts
  • Name: George
Posted 25 July 2013 - 12:19 PM
Where would that OBDII port be located? I'm trying to connect to the port below the steering wheel.
Would those programs work fine without running putty first?
Not what you're looking for?
7 user(s) are reading this topic
1 members, 6 guests, 0 anonymous users
