Willy Posted October 15, 2012 Share Posted October 15, 2012 I'm driving a 2010 Focus ST and have noticed since updating the ROM that I'm getting inaccurate miles to empty readings. I've pulled the KAM fuse but no luck. I usually get 290 when the tanks full but now get 400 which is way off. Any ideas? Quote Link to comment Share on other sites More sharing options...
StanH Posted October 15, 2012 Share Posted October 15, 2012 Is it reading KMs ? Quote Link to comment Share on other sites More sharing options...
roger7313 Posted October 15, 2012 Share Posted October 15, 2012 Hi all, I would like to migrate the BLIS (Blind Spot Information System) from Mondeo to Focus. My car is MK2.5. Does it possible porting to Focus? Quote Link to comment Share on other sites More sharing options...
clubber Posted October 15, 2012 Share Posted October 15, 2012 I'm driving a 2010 Focus ST and have noticed since updating the ROM that I'm getting inaccurate miles to empty readings. I've pulled the KAM fuse but no luck. I usually get 290 when the tanks full but now get 400 which is way off. Any ideas? It will settle down. The ECU takes time to relearn everything. Mine was the same. How do you get 290? I get around 250 but I do do a lot of town driving. Going to Manchester and back on Saturday so will try and see if I can get 400 out of a tank. Quote Link to comment Share on other sites More sharing options...
Willy Posted October 15, 2012 Share Posted October 15, 2012 It will settle down. The ECU takes time to relearn everything. Mine was the same. How do you get 290? I get around 250 but I do do a lot of town driving. Going to Manchester and back on Saturday so will try and see if I can get 400 out of a tank. I drive like captin slow ;) I'll keep an eye on it and see if it comes down. Quote Link to comment Share on other sites More sharing options...
Preee Posted October 16, 2012 Author Share Posted October 16, 2012 Anyone got any idea why I can't connect a modded Bluetooth device to elmconfig. I always get a 8020 connection error :( Try adjusting the speed settings of the bluetooth port. Quote Link to comment Share on other sites More sharing options...
clubber Posted October 16, 2012 Share Posted October 16, 2012 Can the mod be done on the bluetooth ELM's like the one below? http://www.ebay.co.uk/itm/ELM327-V1-4-CAN-BUS-OBDII-OBD2-Car-Diagnostic-Interface-Scanner-Code-Bluetooth-/251044586667?pt=UK_Diagnostic_Tools_Equipment&hash=item3a736c64ab&_uhb=1 Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted October 16, 2012 Share Posted October 16, 2012 Can the mod be done on the bluetooth ELM's like the one below? http://www.ebay.co.u...736c64ab&_uhb=1 cant see why not Quote Link to comment Share on other sites More sharing options...
Willy Posted October 16, 2012 Share Posted October 16, 2012 I've tried to do a bluetooth version and to start with it wouldn't work because it wouldn't connect to the PC for long enough but found this was because of the bluetooth software I was using (Bluesoleil) and the fact that it was allocating hight COM port number which I think ELMconfig doesn't like. However after changing to a Toshiba bluetooth software and selecting a low COM port it work super. Quote Link to comment Share on other sites More sharing options...
Tiggie Posted October 17, 2012 Share Posted October 17, 2012 Hi need help trying to set cruse control Ford focus 2008 I have a working lead and wire and software When I go to the PCM It shows blank is that normal? Quote Link to comment Share on other sites More sharing options...
Richiemac Posted October 17, 2012 Share Posted October 17, 2012 Yip, you need to check the cc boxes in the HEC and Gem. Quote Link to comment Share on other sites More sharing options...
Tiggie Posted October 17, 2012 Share Posted October 17, 2012 Both enabled Not Working as yet Quote Link to comment Share on other sites More sharing options...
Tiggie Posted October 17, 2012 Share Posted October 17, 2012 When you click PCM dose it show anything for you? Quote Link to comment Share on other sites More sharing options...
Richiemac Posted October 17, 2012 Share Posted October 17, 2012 No, you can only read and clear fault codes in PCM........have you taken the car out for a spin and hit the ON button and then Set + button .......above 20mph i think ?? Quote Link to comment Share on other sites More sharing options...
Tiggie Posted October 17, 2012 Share Posted October 17, 2012 Yes rich nothing happening what so ever is it case it's an auto? Quote Link to comment Share on other sites More sharing options...
Richiemac Posted October 17, 2012 Share Posted October 17, 2012 Unfortunately, some PCMs are not CC supported.......looks like you have one of them :( I was lucky, two clicks and it worked . Some others on here have had your problem........being auto would make no difference. Quote Link to comment Share on other sites More sharing options...
Tiggie Posted October 17, 2012 Share Posted October 17, 2012 So would a different gem modual work if it was the right one? Quote Link to comment Share on other sites More sharing options...
Juanito88 Posted October 17, 2012 Share Posted October 17, 2012 Does no longer work on an update of ELMconfig to configure pcm does not? With regard to updating 509 can I activate the notice of change of oil? Does anyone know something? Quote Link to comment Share on other sites More sharing options...
FocusRS Posted October 18, 2012 Share Posted October 18, 2012 Just bought a ELM327 obd2 v1.5 so I can play with setting 's once I've modified it but would like to test it in unmodded form first.. It came with a mini disc but no instructions. Can anyone point me in the right direction, had a look but can't find anything. Quote Link to comment Share on other sites More sharing options...
Preee Posted October 18, 2012 Author Share Posted October 18, 2012 Download the latest version of ELMconfig , a link is on page 47 or 48 of this thread , you can then try your lead out , and adjust settings in the HEC. Plug your lead in , open ELMConfig , select your port number from the program and go online , Top right of ELMConfig under modules tab there is a button to set the required commands for when you modify the cable , but you can still put those commands in before you modify it. Quote Link to comment Share on other sites More sharing options...
FocusRS Posted October 18, 2012 Share Posted October 18, 2012 Download the latest version of ELMconfig , a link is on page 47 or 48 of this thread , you can then try your lead out , and adjust settings in the HEC. Plug your lead in , open ELMConfig , select your port number from the program and go online , Top right of ELMConfig under modules tab there is a button to set the required commands for when you modify the cable , but you can still put those commands in before you modify it. Thank's very much Paul, dark now will have a go tomorrow. Quote Link to comment Share on other sites More sharing options...
Willy Posted October 20, 2012 Share Posted October 20, 2012 I have found a suppler that will do the modded ELMs and send them out for £25 including postage to the UK only if anyones interested ;) Also Does anyone know how to change the speed at which the auto lock activates as I cant change mine and get this error message Quote Link to comment Share on other sites More sharing options...
StanH Posted October 20, 2012 Share Posted October 20, 2012 Can't really help, but I have just done mine and the only differences I can see are that I entered my VIN and ReadfromGEM was available Stan Quote Link to comment Share on other sites More sharing options...
Felicia24 Posted October 21, 2012 Share Posted October 21, 2012 G'day, i have a bluetooth OBD device that i've connected to my laptop via bluetooth and used ELM-FF2 to change a few things like eco mode and shift light ect, however I can't get ELMConfig to work, every time i try read it says CAN error. Is it merely because I don't have the cable version? any help would be appreciated. Cheers Quote Link to comment Share on other sites More sharing options...
Willy Posted October 21, 2012 Share Posted October 21, 2012 Elmconfig needs a low com port number (below 10) I think. I had the same problem. Also look into using different bluetooth software like Toshiba. Quote Link to comment Share on other sites More sharing options...
