Preee Posted December 11, 2012 Author Share Posted December 11, 2012 Looks like preee beat me to it again :) On nightshift Willy so i'm up early lol :) Quote Link to comment Share on other sites More sharing options...
danry88 Posted December 11, 2012 Share Posted December 11, 2012 i am completely lost with this, do i need to downlead elmconfig or just the link to the russian 1 on the 1st page? i downloaded the russian 1 then uploaded the drivers when the lead plugged into laptop, then plugged lead into car and input VIN, COM1 and bit rate then when i click online it comes up with an error box. any help? Quote Link to comment Share on other sites More sharing options...
Preee Posted December 11, 2012 Author Share Posted December 11, 2012 The link on the first page will download the latest version which has English Translation , you also need to download the Runpack.exe and run this on your PC to install required missing DLL fiiles this may be where your Error is coming from. take a screen shot of the error your getting and post it so we can see whats happening. Quote Link to comment Share on other sites More sharing options...
danry88 Posted December 11, 2012 Share Posted December 11, 2012 i downloaded the runtime do i need the elmCONFIG download? Quote Link to comment Share on other sites More sharing options...
Richiemac Posted December 11, 2012 Share Posted December 11, 2012 Download links to latest version (0.2.3 / 01-12-12) + Runtimepack......... http://rapidshare.com/files/4223502841/Elmconfig%200.2.3.zip http://rapidshare.com/files/177230387/RuntimePack.exe Quote Link to comment Share on other sites More sharing options...
StanH Posted December 12, 2012 Share Posted December 12, 2012 Apparently I do not have permission to download the English version of FF2 I am signed in - what do I need to do? Quote Link to comment Share on other sites More sharing options...
haralabosg Posted December 12, 2012 Share Posted December 12, 2012 Apparently I do not have permission to download the English version of FF2 I am signed in - what do I need to do? Same for me . Even i am signed in, i have no permission for download..... Quote Link to comment Share on other sites More sharing options...
cragger89 Posted December 12, 2012 Share Posted December 12, 2012 I have made a few cables for people , downside is now i don't have a Mk2.5 to test it on anymore , i know Lennys Cable works :). i'm keeping hold of my cable incase civil-zz manages to figure out the Mk3 Focus. you say your cable is goosed ? , when you plug into laptop do the LED's light up at all? Yes it does indeed light up and if I go on to Putty, the two LEDs flash properly. If you were up for it Preee, I could post it to you as I would imagine what I've done (whilst angry) is soldered the white wires to the wrong pins on the connector which goes to the car. If you had one which works perfectly, you'd probably be able to repair it. The holes are already made in the case for the wires to escape or for the switch to be installed. I do still have the cable as I calmed down after an hour and pulled it out of the recycle bin - at the point of throwing it away I enjoyed the thought of it being melted down! Quote Link to comment Share on other sites More sharing options...
Daz-ST Posted December 12, 2012 Share Posted December 12, 2012 anyone know what you select to enable the auto locking I went into GEM and put 10 in the autolock if vehicle speed greater than this value but it's not working Quote Link to comment Share on other sites More sharing options...
Willy Posted December 12, 2012 Share Posted December 12, 2012 anyone know what you select to enable the auto locking I went into GEM and put 10 in the autolock if vehicle speed greater than this value but it's not working Here you go daz, tick these boxes first Quote Link to comment Share on other sites More sharing options...
Daz-ST Posted December 12, 2012 Share Posted December 12, 2012 Here you go daz, tick these boxes first nice one Willy will pop back out got it working fine enable dds so far Quote Link to comment Share on other sites More sharing options...
Daz-ST Posted December 12, 2012 Share Posted December 12, 2012 great got the autolocking working now did select eco mode in HEC level 2/3 but that doesn't seem to have worked Quote Link to comment Share on other sites More sharing options...
Willy Posted December 12, 2012 Share Posted December 12, 2012 great got the autolocking working now did select eco mode in HEC level 2/3 but that doesn't seem to have worked OK here's where you want to go Daz. Make sure you have a fully charged battery as the update takes about 40 minutes. Turn off everything like anti virus, screen saver, wifi, power options as the laptop must stay on without any interruptions. Quote Link to comment Share on other sites More sharing options...
Daz-ST Posted December 12, 2012 Share Posted December 12, 2012 OK here's where you want to go Daz. Make sure you have a fully charged battery as the update takes about 40 minutes. Turn off everything like anti virus, screen saver, wifi, power options as the laptop must stay on without any interruptions. what does that do Willyonly other thing I have noticed it says I am doing 11 mpg on the trip do you just reset it Quote Link to comment Share on other sites More sharing options...
Willy Posted December 12, 2012 Share Posted December 12, 2012 It updates you speedo cluster to the latest version with enabled eco mode and shift light. I'm guessing you have a facelift as It's only compatible with the facelift. Your mpg figures will be a bit off for a few weeks as the car has to relearn your driving style. Quote Link to comment Share on other sites More sharing options...
Daz-ST Posted December 12, 2012 Share Posted December 12, 2012 It updates you speedo cluster to the latest version with enabled eco mode and shift light. I'm guessing you have a facelift as It's only compatible with the facelift. Your mpg figures will be a bit off for a few weeks as the car has to relearn your driving style. yeah I have a 59 plate facelift all sorted and updated. did crap myself tho because it failed the 1st time and my complete cluster wasn't working but did it again and it completed in 19 min did turn the laptop screen off half way through for 5 min or so. is there any info on the eco mode coz it says see manual Quote Link to comment Share on other sites More sharing options...
Kd372a Posted December 12, 2012 Share Posted December 12, 2012 Hi, I have a modified ELM327 device that I've successfully modified my 2011 Focus ST, auto lock, seat belt reminder alarm, etc. So I decided to try it on my C-Max (58 plate). Well, it will read the GEM info and that’s about it. Can't get the VIN or anything else to work, read configuration. Just get errors. Any ideas welcome, tried a couple of times, Focus ST is fine, same laptop & software ELMConfig 0.2.3, same configuration. Thanks Quote Link to comment Share on other sites More sharing options...
Preee Posted December 12, 2012 Author Share Posted December 12, 2012 Apparently I do not have permission to download the English version of FF2 I am signed in - what do I need to do? I asked Steve to take a look at the files , so can you test them now to see if they download / Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted December 12, 2012 Share Posted December 12, 2012 I asked Steve to take a look at the files , so can you test them now to see if they download / still the same Quote Link to comment Share on other sites More sharing options...
Daz-ST Posted December 12, 2012 Share Posted December 12, 2012 Is there a setting for the autolocking if you stop and open say passenger door for it to relock again when you driving off without switching off and on again Quote Link to comment Share on other sites More sharing options...
nuno8210 Posted December 13, 2012 Share Posted December 13, 2012 Is there a setting for the autolocking if you stop and open say passenger door for it to relock again when you driving off without switching off and on again It will auto relock when you drive faster then the selected speed if you check the "auto relocking" box. Quote Link to comment Share on other sites More sharing options...
Daz-ST Posted December 13, 2012 Share Posted December 13, 2012 It will auto relock when you drive faster then the selected speed if you check the "auto relocking" box. Pretty sure i have that ticked already will check tomorrow Quote Link to comment Share on other sites More sharing options...
cragger89 Posted December 13, 2012 Share Posted December 13, 2012 As my car has Eco mode (since programming the first time round at the weekend) does this mean I don't need to run the update? Only asking as I do not have the green arrow, but not necessarily going to do anything as a full software update if it isn't going to actually benefit me at all. Quote Link to comment Share on other sites More sharing options...
Richiemac Posted December 13, 2012 Share Posted December 13, 2012 Have you marked the ' shift up indicator ' option..... Configuration / page 1 / ELM Config ? Quote Link to comment Share on other sites More sharing options...
cragger89 Posted December 13, 2012 Share Posted December 13, 2012 In all honesty, I've probably neglected to do that. When the cable arrives on loan from Lenny I shall take a closer look. I don't even use the Eco mode, I just like lights coming on. I like to feel like I'm a pilot when I drive.... Quote Link to comment Share on other sites More sharing options...
