Fieta 51 plate butler
Ford Fiesta 1.3 Flight Car
35 posts in this topic
Dear all
Over the last 6 to 8 mths , i have notice a whining noise , in gears 2nd and 3rd, I have no idea what this is and how to fix this, here some points on it
1, when in 2nd gear its at it worst , you can hear it whin up and down from speeds of 20-10mph, its been like this for a while now and doesnt seen to get any higher pitch then it is already is..but can be annoying not know what it is!!
2.In 3rd gear its only slight and can only just hear it
Is this somthing bad?? Can it be fixed?? will it cause damage in the long run??
Hope you take you time to reply to my topic because i have no idea with not much machanic knowledge!!
Thanks Carl
Hi Carl
Although not an easy job get the gearbox oil changed its 10 years old and will be full of metal and nasties.
The Whining etc could very well be a symptom of low gearbox oil. or wear due to age etc etc.
Dont Give up on the gearbox until the oil has been changed
Although its a for life lubricant it can be drained out by removing the reverse detent cover and or a driveshaft.
Castrol Manual SMX-S Gear Oil is a fully synthetic SAE 75W/85 manual gear oil
Hope This Helps
Jamie
Hi Carl
Did this help ??
Only use the oil i have specified as these are known trouble box's that only favour the expensive stuff.
Jamie :-)
As Jamie above me said change your gearbox oil before changing the gearbox or whatever, as it might be the cause of the issue you're having.
My Fiesta (Zetec unit not OHV unit like your Flight model) there's a noticable whine in 1st and 2nd, and just like you when slowing down from 10-20mph to a stop (clutch depressed or not, makes no difference) it sounds almost like a milkfloat. I did loads of research loads of older Fiesta owners like us are having the same noise from their cars. So essentially it might just be a certain 'quirk' of these gearboxes. I replaced the oil in mine and it's made the noise quieter, but it's still there.
When you put the car in neutral, and then lift your foot off the clutch (engine on obviously) can you hear a grinding/spinning type of noise? Mine does that too, sounds like either the input shaft or layshaft, but again lots of Fiesta owners notice a similar sound.
Thanks for the help!! I will change the gearbox some how, the whining does only happen in gears 1 2 and 3 , the car as only done 40000 miles , in no gear it sounds ok, I have been told its a bearing wearing in the gearbox, the only problem I will have now is putting oil in the gearbox because i have no how to do this
Hi Carl
Oil not gearbox :-(
Buy a haynes manual.
Some useful bits of kit you may need and want to keep for other jobs in the future are.
Socket Set
a length of clear plastic pipe http://www.ebay.co.uk/itm/10mm-3-8-1-METRE-CLEAR-PVC-FLEXIBLE-WATER-HOSE-TUBING-PLASTIC-PIPE-POND-TUBE-/380401392387?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5891b09b03
a Oil removing pump http://www.ebay.co.uk/itm/2-LITRE-OIL-and-FLUID-EXTRACTOR-PUMP-NEW-SILVERLINE-/220801328558?pt=LH_DefaultDomain_3&hash=item3368c8e5ae
Lots of Old Rags
Trolley Jack
Axle Stands
Metric spanners
Posi screwdriver
blade screwdriver
the oil there are two types CASTROL SYNTRANS FE 75W/CASTROL SYNTRANS MULTIVEHICLE 75W-90
(previously known as SMX-S)
You must make sure you check either with halfords or a motor factor or if you get a haynes manual it will state one of the above.
Thick gloves (Rubbery sort) (Protects your hands from oil/dirt and scrapes etc etc)
An easy way of removing as much of the old oil as possible is to use the oil extraction pump by inserting the hose into the gearbox.
To Do this you need to use a spanner to remove the reverse gear switch which if you stand over the bonnet of the car and look at the front of the gearbox you will see a plug exiting the gearbox horizontly with two wires coming out of it. (sorry about my explanations)
a little oil might seep this is normal.
Before you do all this take the car on a run that means you can do 60mph for a few miles this will heat up the old oil in the gearbox and the crap will suspend in the oil making it easier to get as much out as possible,
You will need two bottles of the oil above and you will have a little left over.
Before doing any of this please please get a haynes manual for the car you have.
The local library is the easiest option you can borrow it for up to 3 weeks in most librarys but dont get it dirty lol.
And be warned cars are heavy and if you dont take proper safety precautions it could seriously injur you or kill you if the car falls on you when you are working on it.
Sorry if this puts you off but once you get a sense of knowing what you are doing it can actually be fun because then you will learn how to maintain a car inside and out without spending 000's or 0000's at a garage.
Jamie
Hi Carl
Hope This Helps
Jamie
Changing the gearbox oil is a terrible idea, it will cause more problems than good.
Edit: Stupid suggestion, are you sure it isn't coming from the speakers?
That is a valid point.
If it's a whirring noise that increases with the revs it could well be the aux connector has come loose - that's if you have one fitted.
Try running the car with stereo off to eliminate a possibly easy fix.
If it's the radio picking up interference from the alternator etc. try fitting ferrous cores on the aerial cable.
thankyou d lockers i now feel this small .
@Jamie: lol I suppose each will always be to their own, dLockers, why would you not recommened changing the gearbox oil?
Gearbox oil for the most part is not meant to be changed. It ages with the box.
It's like throwing redex or some other magic engine cleaner in an old engine block - it's not recommended. It will dislodge crap and block the engine.
If you swap the oil you risk it seeping out of the oil seals that are now aged with the oil that's in there.
Better answer:
http://answers.yahoo.com/question/index?qid=20080317110443AAmotae
Oxidized oil + metal shavings + sludge
Definitely pursue the radio option.
If changing the oil in the gearbox is so bad why do we change the oil in our engines ?
Wow , changing gearbox sounds a tough job for a novice knowledge Person like me, to put things into what I have notice with the car is follows,
I got the car at 37300 from a lad who had a custom made exhaust on it, very noisy and well looked after, when I was driving the car at first, I didn't notice the whining because it's my first car and would of thought it was normal, after a few weeks of driving it, I did start listening to the engine whining noise, deceleration to turn couners, with the stupid exhaust I had on . I proberly couldn't hear it in acceleration though and past 2nd gear , I monited the noise going though 2700ish with no changes to it, then I had my car MOT about 3 weeks ago , got the exhaust removed for a standed one put on, that's when I notice the whining up as well as down, proberly hear more then now, but I think I will leave it how it is for the next 300-500 miles and if the noise increases will get something done, my question is????
1.will this cause damage to the car if it doesn't change in any way???
I would like to get under the bonnet and fix this myself but I can't from a book, I can only do things when I have watched someone do it or show things!!!
So I will leave it how it is and carry on as normal,
Also done the radio test and the noise is still their,
Because this sludges up exponentially faster and is a service item.
If you change the oil regularly from day one, you probably won't have a problem, and can do it to your hearts content.
Changing oil in a gearbox that has original oil in it 10 years later is not advisable because of the reasons I said.
Hi Carl
Leave the gearbox oil change job for a while.
your right it is a tough job for a novice.
One easy thing could be that you ask that the oil level in the box is just below the reverse switch plug just to be sure that its not infact empty
One other thing i have thought is could it be a wheel bearing. now obviously is this noise coming from the passenger side front
Jamie
Its defo the gearbox, because , when am in N , it makes no noise at all, where do I look to check the level as I have no idea where that is ???
..how does that make it the gearbox?
When in neutral lots of components aren't moving, and when in gear lots of components are
Do not check the level, it's a silly idea. These gearboxes are sealed for the life of the car, they don't have a way to check the level other than to see if oil is 'there' - which won't end well.
Gearbox oil also STINKS and will stain the drive permanently.
Gearbox oil level will only be too low if you have an obvious massive leak.
So what could it possible be , a high pitched whining noise that only occurs in 2nd gear mostly with the clutch padel pressed down, between speeds of 25 to 10 , mostly heard at 22, if I take it out of gear at this stage to N , it goes away, can you explain this d locker ???
I still think it's the speakers personally.
It's not your gear box, and it 100% isn't because of the gear box oil. Could be driveshafts, clutch, etc.
Take it for an italian tune up, or someone who knows what they're talking about it. This is an internet forum after all, not many of us are qualified.
Well we will find out what it is before long
Jamie
would you calm down for one minute D lockers.
Stop saying my posts are either silly or stupid !
Jamie
I'm sorry but removing the reverse switch to see if there is any oil isn't silly or stupid?
Ofc there is going to be oil - where do you think it's gone otherwise? Evaporated? The ford box fitted to these is a sealed unit, aka no maintenance.
I know all of this ok. im sorry too now can we be mates.
Jamie
No it's not a sealed unit at all. I know this from changing the oil in my very own gearbox, dLockers no offence intended, but less of the theory and more practical experience is needed on your behalf I'm afraid.
I personally won't be drawn into a huge 'debate', because I don't know you personally, and to each other we're just a random guy from the FOC - but if people have given advice and tried to help, there's no need to be so downright arrogant and disregard everything they say, it's very, well... arrogant.
The gear box is a sealed unit. The only way to get oil in the box is via the reverse switch being removed or removing a drive shaft (my personal method). There is no sump plug.
Im trying to save you wasting your time. Your not a mechanic, and I doubt you've done anywhere near the stuff I have done (http://www.bitpoint....%20%2873%29.jpg) nor achieved.
It's not arrogance. It's trying to stop you chasing a red herring. Take it to a mechanic.
