Fluid Leak
10 replies to this topic
#1 fintious maximus
fintious maximus
  • New Member
  • 110 posts
  • Name: Andy
  • Ford Model: Modeo Estate 2.0 Zetec
  • Year: 2001
Posted 19 March 2012 - 06:50 PM
Hi all,
noticed a small pool (5ch diameter) of fluid under the car this morning and dabbed a finger in it. Fluid is pinky watery stuff with no strong smell. Had a look under the engine and from the front of the car, the left hand side at the bottom is what I think is power steering pump (?) which has a belt on it and is the lowest pulley of the set on that side of the engine.
a. is that the power steering pump and
b. is that likely to be the leaky culprit?
Can't see where the leak is coming from but the pulley housing is wet underneath.
Thanks in advance
Have something to contribute?
#2 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,105 posts
  • Name: Clive
  • Year: 2015
Posted 19 March 2012 - 08:41 PM
Sounds like hydraulic fluid to me, so probably power steering.
Look at your power steering reservoir under the bonnet, are the colours / texture the same?
You can't miss the reservoir, it has a symbol on top of it like a steering wheel.
#3 fintious maximus
fintious maximus
  • New Member
  • 110 posts
  • Name: Andy
  • Year: 2001
Posted 20 March 2012 - 08:27 AM
checked that last night and they do appear to be the same. PS reservoir is full though?
#4 pragmatix
pragmatix
  • 554 posts
  • Name: Pete
  • Ford Model: Mondea 2Ltr Tdci Titianium Estate
Posted 20 March 2012 - 08:46 AM
Waht colour is your coolant, I ask because mines a pinky colour, if it was hydralic fluid it would have an oily feel
#5 Z3 MON
Z3 MON
  • New Member
  • 328 posts
  • Name: David
  • Ford Model: Ford Mondeo 2.0 TDCI 115 Mistral 2004
  • Year: 2004
Posted 20 March 2012 - 10:28 AM
I recon its coolant aswell, could it be your water pump ???
#6 fintious maximus
fintious maximus
  • New Member
  • 110 posts
  • Name: Andy
  • Year: 2001
Posted 20 March 2012 - 04:25 PM
It is also similar to coolant but the level hasn't changed in there either. If it is water pump is it a big job?
#7 Z3 MON
Z3 MON
  • New Member
  • 328 posts
  • Name: David
  • Year: 2004
Posted 20 March 2012 - 06:00 PM
It might be just the hose going onto the pump has come losse or has da slight split, probably near or under the clip that holds the pipe on judging by the minimal leakage
#8 fintious maximus
fintious maximus
  • New Member
  • 110 posts
  • Name: Andy
  • Year: 2001
Posted 20 March 2012 - 06:12 PM
Got the day off tomorrow so ging to get jacked up (and axle stands) to see what I can find. Just as a pointer, where is the water pump? Not got a Haynes yet...
#9 stef123
stef123
  • Management
  • 5,793 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 20 March 2012 - 08:03 PM
its driven off the auxiliary belt.
#10 Z3 MON
Z3 MON
  • New Member
  • 328 posts
  • Name: David
  • Year: 2004
Posted 21 March 2012 - 07:17 AM
Drivers side :)
#11 fintious maximus
fintious maximus
  • New Member
  • 110 posts
  • Name: Andy
  • Year: 2001
Posted 26 March 2012 - 06:48 PM
Havn't had chance to get under yet but have noticed that the last 5 days there has been no leak! Could it have been overfilled and water was expelling from expansion tank drain? All levels are perfect
Not what you're looking for?
