Sucking Noise
5 replies to this topic
#1 jells216
jells216
    Newbie
  • New Member
  • Pip
  • 5 posts
  • Ford Model: focus zetec TDCi
Posted 20 March 2012 - 06:00 PM
Can any one help?
My 06 TDCI 1800 focus makes a weird sucking noise when I excelorate, then stops when I take foot off gas!
I'm not sure - It could all be in the mind - but think I am getting a smell like like a blocked hoover!!!
Many thanks.
Jells.
Have something to contribute?
#2 STEADS
STEADS
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,116 posts
  • Name: NEIL
  • Ford Model: FOCUS 1.8 TDCI TITANIUM AND 2.0 TDCI
  • Year: 2009
Posted 20 March 2012 - 06:19 PM
is it a sucking noise or whirring ?
#3 Z3 MON
Z3 MON
  • New Member
  • 328 posts
  • Name: David
  • Ford Model: Ford Mondeo 2.0 TDCI 115 Mistral 2004
  • Year: 2004
Posted 21 March 2012 - 08:20 AM
if its a sucking noise:
there is a air intake at the front under the bonnet (to the right at the top of the headlight, between the ford badge and the passenger side headlight) that takes the air to the bottom of the air box, the scop has a pipe that goes to just underneath the battery, at the bottom of the batter the pipe connects to another pipe, this other pipe joins the bottom of the airbox, the pipe that joins under the battery to the bottom of the air box has probably fallen off (why Ford didnt just do it as once peiece ill never know)
Have a look :)
#4 jells216
jells216
    Newbie
  • New Member
  • Pip
  • 5 posts
Posted 21 March 2012 - 11:03 AM
Its Deffo a sucking noise! it almost sounds like heaters been turned up to 4! or like a boost to the fan. it only happens when you excelorate!
#5 johnH
johnH
  • 1,137 posts
  • Name: John
  • Ford Model: Focus mk2 Zetec 1.8 TDCI (Climate)
  • Year: 2006
Posted 21 March 2012 - 12:58 PM
i had this a while back...basically as above, you have a disconnected hose or split hose. same car (1.8tdci 2006) basically open the bonnet as you look in - left hand, top of the engine is a thick black rubber pipe. it will bend from front of car to right hand side. put your finger (engine off) into the inside bend of this rubber pipe...you may find a split. new pipe from dealer is around £40 mark. you can get far cheaper if you know the dimensions, of the net.
#6 Danny87
Danny87
  • New Member
  • 429 posts
  • Name: Dan
  • Ford Model: Fiesta Freestyle 1.25 Zetec 5-door
  • Year: 2001
Posted 21 March 2012 - 01:39 PM
It might be worth popping open the bonnet and getting someone to rev the engine while you stick your head in for a listen, I was driven mad until I traced a similar noise down to be a pipe going to the PCV valve, I managed to fix my poor starting and oil burning in the process.
Just a thought anyway :)
Not what you're looking for?
