Support the club!
Ford Ka 1.3 1999 - Wont Start When Engines Hot
3 replies to this topic
#1 Nightwalker
Nightwalker
    Newbie
  • Pip
  • 2 posts
  • Name: Matthew
  • Ford Model: Ford Ka
  • Year: 1999
Posted 22 March 2012 - 03:26 PM
I've got this problem can anyone help me to diagnose the problem..
The Car Starts No Problem when cold,it was revving up and down on its own without touching the accelerator
Got told it was the idle air control valve,which i changed still doing the same problem,so i disconnected the battery and reset the ecu
problem is once the car gets hot and you turn it off it wont start,you have to wait 10 mins to let the engine cool down a bit then it will start straight away
im just at a loss now just cant figure out if its the coil pack,or the cooling temp sensor,or is it the ecu..
Any help would be greatly appricated
Edit:
Seems Like no one can help me,so my ka is ready for the scrapyard
Will Appricate if anyone can come up with anything
thanks
#2 Darren T
Darren T
  • 76 posts
  • Name: Darren
  • Ford Model: Ka
  • Year: 2004
Posted 23 March 2012 - 01:12 PM
Try the coolant temp sensor or clean the maf ( mass airflow meter ).
#3 Nightwalker
Nightwalker
    Newbie
  • Pip
  • 2 posts
  • Name: Matthew
  • Year: 1999
Posted 23 March 2012 - 04:17 PM
Thanks I'll Check The Maf
#4 Darren T
Darren T
  • 76 posts
  • Name: Darren
  • Ford Model: Ka
  • Year: 2004
Posted 23 March 2012 - 04:23 PM
Your welcome, Give mass airflow meter a very gentle clean using carb cleaner. DO NOT put any pressure on the thin wire that runs across it or it will snap.
