Mk2 Facelift - Retrofitting Bi Xenon Headlights
Headlights Headlamps Bi Xenon
38 replies to this topic
#31 chris mitchell
chris mitchell
    Member
  • PipPip
  • 20 posts
  • Ford Model: 08 focus ST2
Posted 07 August 2012 - 10:10 PM
I thought they seemed low but got a mechanic to set them properly and he set they were off by very little. I don't have any levelling adjustment on them at all
How about if you wire the manual headlight adjustment thats on the headlight switch to the electronic adjustment motor on the headlight unit?
#32 jgriff
jgriff
  • 125 posts
  • Name: John
  • Ford Model: Focus 1.6 zetec
Posted 07 August 2012 - 10:39 PM
That could work but it wouldnt be any good with electrics
#33 Haz93
Haz93
  • 445 posts
  • Name: Harrison
  • Year: 2009
Posted 08 October 2012 - 06:43 AM
Need some help please
Anyone know where the headlight levelling control module is located?? I have one on order from the bay but need to know where it plugs into
#34 RB2004
RB2004
  • 51 posts
  • Name: Ronald J
  • Ford Model: Ford Focus 2008 Titanium with Sport Pack
Posted 14 October 2012 - 01:36 AM
You cannot retrofit Xenons successfully.
Engine Bay loom, on some models.. first 3 months of production had the full engine bay loom which supported Xenons, Washer fluid level sensor, and washers etc.. the works. So should have sensor wiring for the front if I can remember that is probably on the engine bay loom. IF you have the top end loom.
but ford cheapened up, and only started using this loom where required after, and had cheaper looms made for the non xenon models... you can get them working with wiring mods, but never properly because....
There is 2 of every loom listed for the dashboard, a xenon/adaptive headlamp version and a halogen version, so even if you have all the wiring in the engine bay you wont have the wiring behind the dashboard... so there will be no sensor wiring from the GEM to the module, and no connectors for the module.
its normally connected behind drivers footwell kick panel to the module which is bolted to the door pillar, but a non xenon loom wont even have a connector for it. because going back there was 2 of each different loom a halogen and xenon loom.
No car was made with a xenon loom behind the dash unless it was spec'd with xenon / adaptive head lamps because the reason for 2 different looms is because having xenon loom wiring without a module plugged in probably creates all sorts of CANBUS communication errors because wiring probably goes into module, out the other side and onto next thing.
Then for the rear sensor, will have to double check that but if i can remember was either a separate xenon floor loom or a jumper loom that plugs into main loom.. same jumper loom as used for the diesel additive module etc but with some extra wires for the rear levelling sensor.
#35 Geo2009
Geo2009
    Newbie
  • Pip
  • 3 posts
  • Name: George
  • Ford Model: Focus CC3
  • Year: 2014
Posted 24 February 2013 - 09:15 PM
Im having ago at fitting Xenon headlights to my Focus CC. Iv'e got the Xenon lamps to light and Im now trying to work out what I need to do to make the leveling motors to work.
Does anyone know what signals/voltages the motors need to function and what pins on the headlamp connector they are feed into?
With a bit of elimination I think pin 7 is (-ve) ground, pin 10 is (+ve) 12v but I can't work out what the other two pins, pins 5 & 9 require.
Strangely I found that pin 5 is low resistance (0.6 ohms) to pin 7 and pin 9 is low resistance (0.6 ohms) to pin 10??
On the halogen headlamps pin 7 is -ve, pin 9 is the signal (0.6v to 12v) from the thumb wheel dash adjuster and the +ve for the motor comes from pin 2 inside the headlamp.
If I can find out what the motors need to move then it should be possible to make a circuit to do it manually.
Any help would be greatfully received.
Geo.
#36 Haz93
Haz93
  • 445 posts
  • Name: Harrison
  • Year: 2009
Posted 24 February 2013 - 09:58 PM
Hi mate
The motors that the xenon units use are completely different to the manual motors. To make this work you would have to change the motors for the halogen ones.
I have just sold my focus so will be selling the parts I have. I have the auto levelling headlight switch and also the auto levelling control module which is mounted up behind the dash near the A pillar. All you would need then is the levelling sensors and to program the GEM to accept the auto levelling system.
#37 Brigante
Brigante
    Resident Ranter
  • 2,108 posts
  • Name: Charlie
  • Year: 2005
Posted 24 February 2013 - 10:08 PM
you've sold it??
when that happen mate?
#38 salsheikh
salsheikh
  • 885 posts
  • Name: Sal
Posted 24 February 2013 - 10:16 PM
you've sold it??
this, Haz whats going on matey?
#39 Geo2009
Geo2009
    Newbie
  • Pip
  • 3 posts
  • Name: George
  • Year: 2014
Posted 01 March 2013 - 10:20 AM
Yup after a bit of investigation I have found that the motors in the xenons are 2 phase stepper motors which explains the 4 wires and the motors in the Halogens are servo motors so only 3 wires.
So as my car doesn't have the wiring for the stepper motors then its either make a driving circuit board to run the stepper motors or get some manual type servo motors and fit them into the xenon headlights.
So Haz do you have a set of manual motors for sale??
Geo.
