Where do I find this? I want to reset the service indicator after an oil change. Thank you. Mike
2 replies to this topic
#1
Posted 15 April 2012 - 05:22 PM
#2
Posted 16 April 2012 - 01:24 PM
You should find this somewhere around the drivers side, near the coin scutttle, it should be resessed into the dashboard.
#3
Posted 12 June 2012 - 10:43 PM
OBD plug is on the right hand side of the dash, open the little storage box then above that you'll see a little cover the obd plug is behind that. But you don't need to connect a scanner to reset service light. Turn ignition to ON (don't start the engine) then push the brake and accelerator down together and hold it down for about 30 to 45 seconds the display in the cluster will say "service reset in progress" then after a few seconds it will say "service reset complete" release pedals and the service light will be reset
